Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Rear parking sensor active with shut down engine?
Vorsteiner
      05-09-2012, 04:45 PM   #1
Kristof
Drives: 2012 328i Sport MG
A quick question.. I noticed that the rear parking sensor remains enabled, active and keeps beeping loudly once I parked the car backwards and switched the engine off, assuming that the manual gear switch remains in reverse.
As I have a gear lock which do requires to lock in reverse, I really wonder how to avoid this behavior.. it's pretty annoying. Anyone knows if it's possible to switch this feature off and keep the sensor active only while the engine is turned on?
      05-10-2012, 09:38 AM   #2
robc777
Drives: 320d
I drive a manual and the sensor stays on even when not in reverse and with the engine off. Annoying.
      05-10-2012, 11:05 AM   #3
Weaselboy
Weaselboy's Avatar
Drives: 2016 340i Sedan
You need to press the start button a second time to kill power to the car. The first press just shuts off the engine, but electrical power is still on until you do a second press.
