BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Air Filter Replacement
Evolution of Speed
      05-16-2012, 09:15 PM   #1
Rick4345
Rick4345's Avatar
Drives: 2017 M2 6MT LBB
Has anyone been brave enough to figure out how to change the air filter? I just ordered a K&N filter for my car and was wondering how difficult it is. Thanks in advance!!
      05-26-2012, 10:16 AM   #2
Rick4345
Rick4345's Avatar
Done
I found out how to do it. I gave a call to Robert at K&N. I sent him a picture of the engine bay. First, unsnap the four silver clips on the left. Then you have to loosen up the intake tube from the mass air flow sensor. Give a gentle tug on the rubber mounts and you're in business. The mounts are pliable enough you can pinch them together and make the process a little easier.
      05-26-2012, 05:50 PM   #3
MikeVictor
Australia
97
Drives: anything given a chance
A drop in filter should be easy to do, are you trying to explain removing the air-box and fitting a cone setup?
      05-26-2012, 06:30 PM   #4
Rick4345
Rick4345's Avatar
drop in
No, Just the drop in filter. For some it's easy and obvious. For people like me, not so much.....
      06-01-2012, 01:52 PM   #5
jj970
Drives: Black F30 N20
2007 335i Coupe  [0.00]
Why did you change the filter already?
      06-01-2012, 07:15 PM   #6
Rick4345
Rick4345's Avatar
I replaced the filter for hopefully a little better performance and mileage. I have them in everything from my work car to my motorcycle. It may just be my imagination, but I have used them for about fifteen years easy. They have a million mile guarantee and can go about 50,000 miles without cleaning. Plus, under the Magnuson Moss Warranty Act, it won't screw up your warranty.
      06-21-2012, 07:20 AM   #7
MikeVictor
Australia
97
I was doing some searching on this a few days ago, as I'd like to put a K&N or BMC filter in my car when it arrives.
I believe the flat-panel replacement for the E9x will fit in the F30.
      08-04-2012, 09:35 AM   #8
BRM6
BRM6's Avatar
Brazil
Drives: 328/335/M235i/M4 - Current M6
Wonder if BMC already makes one that fits the 328i / F30?
      08-28-2012, 01:37 AM   #9
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
afe makes replacement filters for the f30. there's the option of a wet and dry filter material.. haven't done this mod yet, but will soon. stock air filters always hinder a little performance (and overall sound imo)
the only thing in this world that gives orders is balls. You got that? Balls.
      09-18-2012, 03:32 PM   #10
Mrcarcrazy
Sarcasm free with all posts.
-55
Drives: 05 Elise REV310
Dyno proof?
      09-20-2012, 04:54 PM   #11
legaleye3000
Drives: 2014 328i; 2015 X3
So is it really worth it to put an aftermarket (K&N, etc.) air filter in? Thanks.
      09-29-2012, 10:38 PM   #12
ocso1606
ocso1606's Avatar
Drives: 2013 335i M
2007 BMW 525xi  [0.00]
2010 Volvo  [0.00]
2013 BMW 335i M-Sport  [0.00]
There cant be much diff in performance with a drop in filter..can there?
M5 with lots of goodies
      01-03-2013, 01:37 AM   #13
schnell13
schnell13's Avatar
Drives: 2013 335i M Sport
Install Guide
Gentlemen and Ladies,
This guide is intended to help anyone install their new K&N, aFe, etc. replacement air filters. This is also intended for the 335 with a standard air box, or, NOT replaced with a CAI.
Reasons for getting a high-flow filter:
1. Our cars have a TURBO. This means that they'll run a bit hot over their NA cousins, along with needing more air for more proper combustion with the forced induction. I say let's give it to them!!
2. As others have said, it won't void your warranty, will give you (slightly) more hp, (slightly) better gas milege, and doesn't have to ever get replaced. So it pays for itself after 2-3 replacement filters. I've had a K&N in my Corvette, Mazda3, Altima SE-R and previous 328Ci, and have experienced noticeable gains in hp, torque, and fuel economy after their installation.
3. It's so easy (yes, if a caveman drove an F30, he could do it to!)
Steps:
1. Pop the hood
2. Locate the 4 silver tabs holding the top of the air cleaner box in place. If you are facing the vehicle looking into the engine bay, there will be two on the right side, one on the top left, and one on the left side.
3. Pry them loose using finger pressure. Be careful that they stay in place. I almost lost one into the depths of the engine bay!!
4. Gently lift up the top of the air cleaner box and remove the stock filter. I found that I had plenty of room to remove the old filter without disconnecting anything.
5. Place your replacement filter, drop the lid on top of it (it guides itself back into place with its tabs), lock it back in place with the tabs, and you're finished!
6. Place the accompanying sticker somewhere conspicuous on the car. You'll get 10 hp from that mod alone!!
Enjoy, and happy motoring!
Individual Order 2013 335i M-Sport through BMW Military Sales / Mineral Grey / Coral Red / 4MR / ZMM / ZPP / ZTP / ZDH / 2TB / 494 / 688 / ///M Performance / ///M5 Blue Brakes / K&N / aFe / H&R / Turner Motorsports / SportLine Wheels / Details, details, details...
      01-03-2013, 01:41 AM   #14
schnell13
schnell13's Avatar
As an addendum to the previous install guide, here is the part number for the K&N filter: 33-2997. I used the configurator tool on K&N's website and had it shipped directly from them. The filter fit perfectly. Hope this helps!
      01-21-2013, 07:24 PM   #15
dipak
Drives: 2013 F30 328Xi M Sport EBII
I did a search on K&N website for my 328 and the number is K&N 33-2990
      01-21-2013, 08:01 PM   #16
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
I'll do it after the 50k service is up...why pay to replace a filter they'll replace for free?
SOLD: 2012 335i Mineral Gray
      02-19-2013, 01:15 AM   #17
Jeff_in_Oviedo
Delivered!
Jeff_in_Oviedo's Avatar
Drives: '13 F30 335 M Sport
Note, The K&N 33-2997 Filter is available on amazon for ~$37, versus the ~$55 on the K&N website.
Amazon link below, for those interested.
http://www.amazon.com/33-2997-Replac...=K%26N+33-2997
Delivered!: 2013 F30 335i M Sport, 8-speed Sport Trans, Estoril Blue/Coral Red, 403M, Premium Pkg, Dynamic Handling Pkg, Driver Assist Pkg, HK Sound, Enhanced BT & USB
      03-19-2013, 04:51 AM   #18
momo3605
Drives: 2016 M4
I know horsepower isn't a reason to get the filter, but can anyone who's installed an aftermarket filter comment on sound or fuel economy?
      03-19-2013, 05:23 AM   #19
Kankles
Rear Admiral
Kankles's Avatar
Drives: Bavarian Milk Wagon
2016 BMW M3  [0.00]
2002 BMW M3  [0.00]
I put the K&N filter in my 335 (Amazon $37) when I did my oil change. much higher quality over the stock Mahle paper filter. Very easy, straight forward remove and replace air filter.
      05-27-2013, 04:50 AM   #20
SteveChester
Steve Roberts
SteveChester's Avatar
Drives: F82 M4
Steps:
1. Pop the hood
Is this the same for the 330d motor? Are there any guides or pictures explaining it? Thanks Steve.
Steve Roberts
F30 330D.
E90X5.00
      06-13-2013, 10:57 AM   #21
rustyminded
rustyminded's Avatar
175
Drives: BMW 328i
I have the afe dry filter, it's very good in my sandy weather and you have to put in consideration K&N is oiled so most oil is sucked up on your MAF and it will be clogged sooner that's for any oiled filter
      06-29-2013, 03:56 PM   #22
SmokeShank
Drives: 328xi M-Sport
Aftermarket filter on the N20/26 IMO is a waste of money.
BMS found no power gains over the stock air box setup. Maybe if sound is changed then sure... but I'm not spending money on something that has minimal gains and is covered under factory maintenance.
