BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Best Tire Pressure for Ride Quality?
      05-18-2012, 09:15 AM   #1
jpa74
Drives: F30 328i sports line
I'm used to keeping tire pressures about 1 - 3 psi above the recommended tire pressure on my previous cars.
Being new to BMW and run-flat tires, I'm curious to know if doing this is a bad idea.
Would it alter the handling characteristics drastically or be unsafe?
What do you keep your RFT pressures at? How often do you check?
Thanks. Love this forum!
      05-18-2012, 09:36 AM   #2
TEAShea
Drives: 2012 328i
I keep mine at 3 psi above the recommended pressure - for slightly better handling
run flat tires, tire pressure
