BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 328i 2012, how to make playlist?
Extreme Power House
      05-18-2012, 06:17 PM   #1
Gel214th
Drives: Melbourne Red BMW 328i sport
Hello all,
I have placed songs on a USB stick in a separate folder. I've created a playlist in windows media player and copied it to the USB stick.
When I place the USB stick into the car, it reads all the songs in the folder, but when I move to playlists I see nothing.
I have to manually cycle the songs which are placed in alphabetical format .
What am I doing wrong, how can I get the playlist to display and load?
      05-18-2012, 07:19 PM   #2
justinnum1
Drives: 2015 328i Msport 6mt
i use a mac, i make different folders on the usb stick and ut the songs int he folders.
F30 328i Alpine white/Coral red Msport 6MT, HK, Zenons, msport brakes, black grills and black side sills. mperformance exhaust
      05-18-2012, 08:11 PM   #3
Gel214th
Hello,
Yes I can do that. But there is an option on the list called Playlists. When I click that it says Not Found in gray lettering.
So the system supports some sort of playlists, which means that it should load that playlist file and play the songs in that order.
But I can't figure out what format it expects the playlist file to be in. I just used itunes on a mac to create a playlist file and Exported it to the USB stick, car still cannot read it.
      05-18-2012, 08:26 PM   #4
justinnum1
I dont think it says playlists, it says something like browse directory, at least in my car it does.
      05-18-2012, 09:04 PM   #5
's Avatar
61
Drives: ✚
Originally Posted by Gel214th View Post
Hello,
Playlists work fine in my car using an iPod or iPhone. I haven't tried it with a usb stick yet. But I'll try it out over the weekend.
      05-19-2012, 03:57 AM   #6
simonh100
Drives: BMW 318d
Hello all,
Took me a while to get the playlists to work for me, but perseverance paid off. Once you have copied the playlist file from the PC to the USB stick, you will need to open the file using Notepad to edit the file locations as the playlist will reference the songs on the C: drive (or other drive) and not the USB stick.
The text should look like this:
<?wpl version="1.0"?>
<smil>
<head>
<meta name="Generator" content="Microsoft Windows Media Player -- 12.0.7601.17514"/>
<meta name="ItemCount" content="0"/>
<title>Car Playlist</title>
</head>
<body>
<seq>
<media src="M.I.A\Bad Girls.mp3"/>
Once you have the file open you can manually add songs to the play list by repeating the last line above with the new song title. Of course the folder and filename must be exactly the same as on USB stick
      05-21-2012, 11:55 AM   #7
Gel214th
Hmm, just tried this and the car does not display any entries when I click Playlists.
All I see is "No Entries"
I copied three files to the USB stick in the root directory, one .m3u , one .wpl and one .txt
Still seeing No Entries.
Should I at least see the filename in the playlist even if it can't find the song files?
      05-21-2012, 12:18 PM   #8
alex2364
alex2364's Avatar
Drives: 2017 M4 ZCP
2017 BMW M4  [0.00]
Is your USB stick formatted in FAT32? And it reads playlists from m3u files, not wpl or txt.
      05-21-2012, 01:35 PM   #9
Gel214th
Yes..Fat 32. But don't call it that, it's sensitive.
It shows ZERO playlists. I can delete the other three files, don't know if that may be messing it up.
      05-21-2012, 03:02 PM   #10
justinnum1
you need to make folders...put the playlist in a folders
      05-21-2012, 08:42 PM   #11
Gel214th
BWAHAHHAHHAA!!! :-)
It worked!!
I had to put the playlist files inside a folder in order for the car to read them!
      11-02-2014, 08:33 AM   #12
DJ Rocc
DJ Rocc's Avatar
Jamaica
118
Drives: BMW 428i Gran Coupe (2015)
BWAHAHHAHHAA!!! :-)
It worked!!
What format did you put them in m3u?
My Ride! : 2015 428i Gran Coupe (F36) - MSport, Alpine White, Black Leather, MSport Brakes, Adaptive Suspension, 8 Speed Sport Auto w/Paddles, Sport/Mem. Seats, Hex. Alum w/Black Piano, HK Sound, 18" 400m's, Alarm, Xenon, Fogs, Comfort Access, >Storage, >Instr. Panel.
Upgrades: Fog Bulbs. Coded: Alarm Chirp, Sport Displays, M4 Sound, Trunk Button Close,
      11-02-2014, 10:31 AM   #13
Gel214th
Yes, I believe it was m3U format. At one point I used iTunes to spit out the playlist, but I remember having to edit the playlist line by line to get it to work properly.
I still have not found a hassle free, seamless way to do it.
Now, I use my iPhone connected in the car to play the music. I would prefer to use the USB, but the iPhone play is just less hassle.
I think this should be upgraded by BMW, their system should be more flexible with file formats and locations.
      11-02-2014, 12:36 PM   #14
DJ Rocc
DJ Rocc's Avatar
Jamaica
118
Ok thanks, what I will do to edit the file is use find and replace, to find and delete the wrong path names. Yes it should be easier. Also what ever happend the "on the fly". Program option we had with CD's, where you could make a playlist order on the fly, and hear 5th edition tune you wanted to right then?
