Extreme Power House
      01-20-2013, 04:59 AM   #2179
simonchs
Drives: BMW 118i F20
i can confirm e-sys 3.18.4 + psdzdata 48.3 + newly purchased token with patch works on my F20
      01-20-2013, 05:34 AM   #2180
SandmanJK
Russian Federation
Drives: 320d
Originally Posted by john08135i View Post
I AM GOING TO PULL MY HAIR OUT..
After buying my token and testing by coding one setting.. i had to go back and watch my kids. Well now it wont connect to eh car..
NO ZGW AVAILABLE... i didnt change anything. I just closed esys.
What causes this?
Try switching off/on wifi adapter and ethernet adapter via Device Manager.
      01-20-2013, 08:43 AM   #2181
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Send a message via Yahoo to john08135i
THANK YOU KON..its fixed.. all set now..
my whole edbias folder was gone.
Extract from installation instruction (from esys 3.18.4)
Run "C:\EDIABAS\Hardware\Ediabas-Konfigurator\Ediabas-Konfigurator.exe" and make sure "Interface:" is set to "INTERFACE=ENET".
Originally Posted by kon View Post
I don't have the new token file to try, but are testing the new esys on a machine that never had esys installed... did you have the EDIABAS folder copy to the root directory? All I wanted to know, i long is a long shot, is able to read FA & CAF file since this new machine is desktop and cannot be used for coding at all
Did you also update the esys program properties to point the token & ods to the right file/directory?
Let's just say you had a bad day.... I do sometime fail to get IP from the car, what I did to make sure I ALWAYS get an ip is start the laptop AFTER the cable is connected to the car & computer, and turn on the car (not start engine)...
CHECK to make sure your computer is receiving an IP with "limited connectivity"
I'll be around for the next few hour... will be heading out to a coding party thereafter, hopefully none of the car will have 505!
M Sport Line Estoril Blue
      01-20-2013, 09:27 AM   #2182
kon
Singapore
Drives: F30 316i
this is reassuring, will get my token the day the dealer program my car above the dreaded 505, otherwise, no point for me to jump in right yet
      01-20-2013, 09:29 AM   #2183
ykau
Drives: F30 320I
yes it works seamlessly. Please do ensure it setup correctly, the computer required a static ip assigned and in this case i issue a class C 24bit network. and also ensure that all connections are disable other than the local connection.
I launched the esys's connection and every time connection established successfully but not sure why ZGW_search.exe not able to dig out the vin number.
      01-20-2013, 09:34 AM   #2184
kon
Singapore
Drives: F30 316i
hmmm 3.18.4? I thought you need to upgrade to 3.22.5?
      01-20-2013, 09:40 AM   #2185
john08135i
john08135i's Avatar
i had to upgrade to 3.22
      01-20-2013, 12:21 PM   #2186
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Errr...what happened to your EDIABAS folder?
It does not uninstall when you remove E-Sys 3.18.4, so did you delete yours?
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      01-20-2013, 12:23 PM   #2187
shawnsheridan
You can use any version of E-Sys, but the Patch / Token you buy is married to that E-Sys version, so you might as well use the latest version, 3.22.5. While 3.18.4 works today for coding, it can not be used for flashing, and who knows if if will continue to work for coding for the next 12 months.
      01-20-2013, 12:23 PM   #2188
john08135i
john08135i's Avatar
I have no idea..
      01-20-2013, 01:02 PM   #2189
SkaTeeB
Drives: 335i MSport
My BMW got new maps and patch from dealer; lost all settings and comings.
Couldn't code so I got new psdzdata, then got the same errors that others got.....but Shawn's help and a patch and token from akiss and all is well again.
Thanks guys!
-Scott
      01-20-2013, 01:37 PM   #2190
john08135i
john08135i's Avatar
Thanks guys!
-Scott
funny how it was exactly the same for me.. i am not taking mine in for any more updates for a long time..
      01-20-2013, 01:57 PM   #2191
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
Adding a DHCP server to the laptop should make the connection to the car come up a little faster as I believe the car does try to get an IP from DHCP.
Beware through that if you plug the laptop with the DHCP server enabled into a normal network with other machines on it, you risk creating havoc by having 2 conflicting DHCP servers on the same sub-net.
      01-20-2013, 03:26 PM   #2192
Raspartan
Drives: F15 X5
I was recently updated to integration F020-12-11-505 and now I can't read coding data. Does this mean I need the 48.1 or higher version of the psdzdata files? Shawn, can you pm me a link? Thanks!
      01-20-2013, 04:08 PM   #2193
Frogman
Frogman's Avatar
You need 48.3 plus a new E-Sys token.
start here:
http://www.f30post.com/forums/showpo...postcount=2135
      01-20-2013, 04:16 PM   #2194
Raspartan
Drives: F15 X5
start here:
Thanks, do you have a download link for 48.3?
      01-20-2013, 04:27 PM   #2195
shawnsheridan
PM sent.
      01-20-2013, 04:28 PM   #2196
Frogman
Frogman's Avatar
start here:
Unfortunately no, you'll need to get it from the almighty Shawn.
You'll also probably want to get the updated E-sys release 3.22.5 and buy a new token. Shawn can send you all of the details. He's across the pond at the moment, so it may take a while.
Edit: Oops, I was too slow, he already replied. I don't think Shawn actually sleeps.
      01-20-2013, 05:05 PM   #2197
Raspartan
Drives: F15 X5
PM sent.
Thanks Shawn!
      01-20-2013, 08:45 PM   #2198
Frogman
Frogman's Avatar
I upgraded to 3.22.5 (with a new token) and 2.48.3 today and successfully coded an F020_12-11-504 car where it previously failed before with 3.18.4 and 48.3. So I can confirm that the new releases (software and data) can code earlier versions (of course it should have, but you never know...)
I have not seen a car coded with F020_12-11-505 yet, so I have not been able to verify that that works yet, but based on the success reported here, it sounds like there aren't any problems.
      01-20-2013, 08:48 PM   #2199
Brian55
Drives: '14 F15, '13 335Xi, '06 911S
configuration problem, or 48.3 token issue?
I have the 48.1 data set, and just tried to connect for the first time to my F30 that arrived a couple of weeks ago. The software connects to the car, but I can't read any modules- I get a C060 error. Is this a symptom of the 48.3 and new token issue, or is there something else I should check? I get the same error when trying to read the I-step level, so I don't know how to check that.
      01-20-2013, 09:10 PM   #2200
Frogman
Frogman's Avatar
What's the error text for C060? I've only seen that when reading the FA, not any of the ECUs.
Make sure you connecting via the VIN.
Are you able to read the FA?
Does "Read (VCM)" succeed?
The issues with 48.3 were 1) having trouble connecting to the car, and 2) Coding the FDL. I never had an issue reading the ECUs with 48.3. That's all moot as you are using 48.1.
What is your I-Step version? That will tell you what version your car has.
