01-26-2013, 05:46 PM | #2311 |
Rep 39
FP could not be generated
Anyone know what the problem might be here? I was follow instructions in the supplemental part 3 PDF and encountered this:
I am working with E-Sys 3.18.4, psdz data 48.2. I was able to connect using F020. I then entered expert mode -> coding, then hit "reload". I was not able to click "edit" (it was greyed out) until I saved the read VO to desktop. I then hit "edit" and then right-clicked on FA -> "calculate FP" and then the error above is given, and I cannot progress further. This error also comes up when I try to "activate FA" I am looking to change the change change the SALAPA-Elements to change 6nh to 6nk to enable bluetooth audio streaming features. thanks! Last edited by theothernguyen; 01-26-2013 at 05:53 PM.. |
01-26-2013, 05:55 PM | #2312 | |
Rep 40,733
Under SALAPA-Elements, try again, but where 6NH is, just delete the H, replace it with K, and hit Ctrl-Enter to save it, then try to Calculate FP again.
01-26-2013, 05:59 PM | #2313 | |
Rep 39
Actually, I have not even gotten to the point where I can change the 6NH value under SALAPA-Elements. As of right now, I cannot even get to the point of calculating the FP nor can I activate the FP with an unmodified FA (the steps prior to changing the salapa values as described in supp part 3). Any other thoughts? Last edited by theothernguyen; 01-26-2013 at 06:05 PM.. Reason: FA not modified clarification |
01-26-2013, 06:12 PM | #2314 | |
Rep 40,733
01-26-2013, 06:22 PM | #2315 | |
Rep 39
Like at this point, my vehicle profile window isn't even populated with anything, it is completely blank (i expected something since the supp part 3 had a screenshot showing that after calculating FP, something showed up =/ ). Could this be a problem with initial installation steps? |
01-26-2013, 06:30 PM | #2316 | |
Rep 40,733
01-26-2013, 06:41 PM | #2317 | |
Rep 72
Drives: 08 M Coupe;14 M6;17 X6M;18 X5M
Garage List 2021 BMW X6 M50 [0.00]
2018 Porsche 911 GT3 [0.00] 2015 BMW i8 [0.00] 2008 BMW M Coupe [0.00] 2017 Porsche 911 Tu ... [0.00] 1986 Porsche 911 Sl ... [0.00] 2021 BMW Alpina XB7 [0.00] |
Current Garage: 1986 Porsche 911 Slant-nose; 2017 Porsche 911 Turbo S Cab; 2018 Porsche 911 GT3 manual; 2008 BMW M Coupe; 2015 BMW i8 Coupe; 2021 BMW X6 M50; 2021 Alpina XB7 |
01-26-2013, 06:53 PM | #2318 |
Rep 307
Shawn, Just to be clear....
I'm using 3.18.4 with 48.1..... My car hasn't been to the dealer since I took it home. It's a 2012 F30. I shouldn't have any issues until I actually take it to the Dealership and they upgrade the code? Once that is done (update the code) I would have to use the Esys patch, 48.3 and buy the token? Thanks... |
01-26-2013, 07:12 PM | #2319 | |
Rep 40,733
01-26-2013, 07:16 PM | #2320 |
Rep 51
Hello,
got my new 125d (F20) can someone tell me how to find out which e-sys version and pzdata I need for my car and where to find it? Thanks a lot! |
01-26-2013, 07:17 PM | #2321 |
Rep 39
I just tried it again, and I cannot commit the changes (via activate FA) to the FDL values after I save them. Basically I get stuck at step 19 in the Getting started Part 1.... oyeeee. Appreciate the troubleshooting efforts! Does this help isolate the problem any further?
01-26-2013, 07:22 PM | #2322 | |
Rep 40,733
If you are not opposed to paying 50 Euro for the latest patch / token, which allows you to use the latest E-Sys 3.22.5 and 48.3 PSdZdata, and is a surefire thing, that is the best bet. If you don't want to do that, then try E-Sys 3.18.4 with 48.1 PSdZData, and see if it works.
01-26-2013, 07:28 PM | #2323 | |
Rep 40,733
What error code do you get with the FDL Coding attempt?
01-26-2013, 07:30 PM | #2324 |
Rep 51
Hello, is E-Sys 3.18.4 without PZData enough to find out which version my car really need? Or any more easier any?
Currently i am waiting for my RJ54 cable. Just ordered it today. |
01-26-2013, 07:33 PM | #2325 |
Rep 40,733
No. You need PSdZData just to connect to the car, not to mention the actual ENET Cable too.
01-26-2013, 07:35 PM | #2326 | |
Rep 39
I get the same error when activating FA or calculating FP. |
01-26-2013, 07:38 PM | #2327 | |
Rep 7
Thank you to this address. diophotr@supermailer.jp |
01-26-2013, 07:40 PM | #2328 | ||||
Rep 39
01-26-2013, 07:40 PM | #2329 | |
Rep 40,733
What happens when you Connect to the car, Read FA, Activate FA, and Read VCM? Can you get that far? Also, what is your Target Connection when you connect? It should be the one for your chassis, but without the _DIRECT after it, and it should be via VIN.
01-26-2013, 07:44 PM | #2330 | |
Rep 40,733
01-26-2013, 07:53 PM | #2331 | |
Rep 39
I am able to connect to the car without issue "connection established", I can read the VO, but I cannot Activate the FA. Although I cannot activate the FA, I can still Read VCM after reading the FA just fine. From there I am able to access the CAFD entries and perform "read coding data" and then edit those variables that are generated. After saving said edits, I go back to activating the FA, but it gives me the error: "No FP could be generated from FA "". [C002] no FA2FP known for Entwicklungsbaureihe F030 [858] - SYSTEM_ERROR" That is where I am stuck. |
01-26-2013, 08:11 PM | #2332 | |
Rep 40,733
Is 48.2 the only PSdZData version that you have?
