European Auto Source
      01-31-2013, 01:09 AM   #2399
kon
Singapore
Drives: F30 316i
Originally Posted by 1lyfe View Post
Hi, can anyone give me some insight here?
i tried coding my car just now and everything is fine until i click "code FDL"
the pop up comes up and it goes through the process but in the i keep on getting this error:
FEM_BODY [40]
cdDeploy ProcessedWithError
cafd_00000794-004_122_083 Not Executable
Whats the cause for this?
i tried coding amber delete and key fob close windows/sunroof and this got this message
any help would be great thanks!
Let me guess, yours is F20/F30 using eSys3.18.4 couple with psdzdata 48.3 WITHOUT buying the new password/token
      01-31-2013, 01:11 AM   #2400
kon
Singapore
Drives: F30 316i
Originally Posted by simonchs View Post
Hi kon,
hold the lock button on key fob will close the windows / glass roof (if opening) and fold the mirror as well, does this code affect to windows and glass roof closing too?
thanks
Not sure, never tried that, but I suppose it should since we're merely changing the werte value to reduce the waiting/pressing time. I have personally kept mine at 0.5 sec as I doesn't want the mirror fold to activate every single time as it will just accelerate the motor wear & tear.
      01-31-2013, 01:12 AM   #2401
Chris@codemybimmer
Chris@codemybimmer's Avatar
Drives: AW F30 328i Xdrive
yea i jsut read the whole thread on bimmerfest
waiting for shawn to send me a reply with the info to purchase
also sucks casue my istep is 505...if it was 504 i could use 48.1 and i would work --.--
      01-31-2013, 01:48 AM   #2402
mrtanz
Australia
Drives: BMW 2008 325i upgrade
HAHA
Check my other thread where i ask this question and provided the solution.
      01-31-2013, 01:49 AM   #2403
mrtanz
Australia
Originally Posted by reidpath View Post
The holy grail of coding...sport mode default :-(
Yes i think i have to look at my mates car again and see if i can find it
Any ideas about the auto start stop in all modes
      01-31-2013, 02:15 AM   #2404
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
just wonder if any coding could bring the "backup profile" function back?
there're no profile backup function in iDrive, it only allowed to create profile, but not backup
Settings -> Profiles should look something like this:
Import is restore, Export is backup.
Are you saying that you don't have the Import or Export profile lines?
I've done lots of coding to my car and I have never seen an option disappear.
      01-31-2013, 02:21 AM   #2405
Frogman
Frogman's Avatar
There are 2 ASS modes you can code:
1. Default off is just that, the car starts with ASS off.
2. Memory remembers the last ASS setting.
But...
ASS will always turn back on when you select Eco-Pro mode. the ASS setting does not change when switching between Comfort and Sports(+) modes.
I don't think anyone has found a way to disable ASS being turned on again when selecting Eco-Pro mode.
For now, if you want ASS off in Eco-Pro mode, you have 2 button pushes to do.
      01-31-2013, 02:51 AM   #2406
clarence
Drives: F30 328i M-Sport
Originally Posted by demge01 View Post
Question:
I don't have bluetooth Audio but I noticed something today.
During a phonecall with my Tom Tom iphone app running, spoken directions and sounds come through the car speakers over BT - it actually reduces the volume of the phonecall slightly with the spoken directions or alerts.
Only during calls though but the system is handling both phone audio and Tom Tom audio at the same time.
Makes me wonder if I can code BT audio?
I think it's the app playing the instructions via bt handsfree profile rather than actual bt audio streaming, cos even if u have combox when u first pair ur fone the bt audio is not enabled by default - u have to manually enable it from the bt config menu for that particular handset.
      01-31-2013, 02:53 AM   #2407
clarence
Some spec combination doesn't allow profile backup, e.g. if u don't have nav but have 6NK/NL then there's no option to backup ur profile. This is due to the usb port being connected to the combox instead of the headunit.
      01-31-2013, 03:37 AM   #2408
demge01
demge01's Avatar
Drives: F30 320ed
it depends on your equipment spec, but from observation, the easiest method seems to be to change your VO from 6NH to 6NK, again it really depends on what already exist in your ride.
I'll give it a go and see what happens.
      01-31-2013, 03:46 AM   #2409
demge01
demge01's Avatar
Drives: F30 320ed
But...
If you use ECO PRO a lot (more than comfort or sport) another way round this would be to code the car so it starts in ECO pro mode (which is possible) and code the ASS so that its default is always off.
That way you start the car in ECO and ASS is always off. However downside is you always start in ECO PRO. If you then switch to comfort and sport it remains off but still if you then switch back to ECO it still switches the ASS back on.
      01-31-2013, 05:39 AM   #2410
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
FEM_BODY [40]
PM sent.
      01-31-2013, 07:23 AM   #2411
simonchs
Drives: BMW 118i F20
Correct.
We don't have import/export profile function (stock F20 from Hong Kong )
So seeking for any coding to make these appear again.
      01-31-2013, 07:29 AM   #2412
simonchs
then I can just give up
      01-31-2013, 08:10 AM   #2413
pixelfreak0410
Drives: M235i Convertible
Bought the EST token für e-sys 3.22 now. Coding can start tonight
      01-31-2013, 12:53 PM   #2414
clarence
I don't think ur car have combox if it's stock HK-spec. Can u run ur VIN on bmwvin.com & email me the VOs?
      01-31-2013, 04:53 PM   #2415
pixelfreak0410
So first coding done I was able to code BC_Digital_V and M Performance Logo.
But somehow setting DVD in Motion did not work. I set Speedlock_X_Kmh_min and max to nicht_aktiv. But still the message appears when driving and the picture goes away. Any idea?
      01-31-2013, 04:55 PM   #2416
shawnsheridan
This type of FDL Code is different. You need to change only the Werte Value of each to FF, and leave the drop-down box setting as they were.
      01-31-2013, 05:42 PM   #2417
RayF31
Netherlands
Drives: F31 320iA HE M-sport
Hi everybody,
New here and a happy owner of F31 M-Sport.
Looking into coding, got the cable and currently downloading latest versions as I am typing
Will seed the torrent cross atlantic of course
Grtz,
RayF31
      01-31-2013, 06:52 PM   #2418
pixelfreak0410
Works like a charme, thanks!
Do you know if the mp3 cover also work with mp3s from an usb stick? Or does it only work with an I-Phone conntected?
How can I activate bluetooth streaming?
      01-31-2013, 06:55 PM   #2419
theothernguyen
Drives: '12 Jet Black 328i Sedan
There have been reports that MP3 cover works with MP3s from USB as well natively, but I haven't tried that out.
Directions to add Album art, Bluetooth audio streaming and white apple USB cable capabilities are here if you have the combox:
http://www.f30post.com/forums/showpo...postcount=2041
and
http://www.f30post.com/forums/showpo...postcount=2043
      01-31-2013, 11:20 PM   #2420
Chris@codemybimmer
anyone with a 2013 get window roll up and folding mirrors through fob to work?
i have the two set to activ and wert 01 but it doesnt do anything when i press the lock button on my key
