VIBE Motorsports
      02-05-2013, 11:53 PM   #2553
Puri1
Puri1's Avatar
Drives: F30 328i 2012
Originally Posted by kon View Post
do you have the code away.est file and have esys program properties point to this. This is the password pin file to code, but only works with esys 3.18.4 and up to psdzdata 48.2 (48.1 to be absolutely safe)
I was thinking that's what it was.. I'lll give it a shot again tomorrow.. Thanks kon..
2012 F30 328i, Alpine White on Black, Luxury, Premium + Exec. Package...
      02-06-2013, 12:37 AM   #2554
steve@codemybimmer
steve@codemybimmer's Avatar
Drives: 2016 M235i xDrive Cabriolet
Originally Posted by shawnsheridan View Post
For my car with Combox:
Change VO as follows:
- 639 (or 633 or 612 if present)
+ 644
+ 614
+ 615 (Required but already present)
+ 6AL
+ 6AB (Required but already present)
VO CODE HU_CIC
VO CODE CMB_MEDIA
FDL CODE CMB_MEDIA:
- TELEMATIK_VIN = Coding_VIN
FDL CODE CMB_MEDIA:
Use modified VO with VIN that has factory options 614 and 615 as explained in my post here:
For writing a VIN to the Combox in E-Sys, I figured that out, and it is very simple:
So simple in fact, that I am mad I spent so much damn time in Tool32, CMEDIA.prg and E-Sys trying to figure it out.
First you must code CMB_MEDIA / TELEMATIK_VIN = Coding VIN using your real FA VIN. Then, open your FA up in the FA-Editor, change the VIN, Caluclate FP just to make sure there are no problems with it, and then save the FA with a new name, i.e. FA_VIN_FAKE. Lastly, go to the coding module, and under Vehicle Order load your new FA_VIN_FAKE, activate FA, and then FDL code CMB_MEDIA. Lastly, read CMB_MEDIA coding data, and verify the new VIN in brackets. In the attached picture, you can see my Combox and Head Unit are showing two different VIN's.
Afterwards, either shut down E-Sys, or load your original FA back and activate it before coding anything else. DO NOT code anything else with this FA, and DO NOT write this FA to the car.
For Internet and BMW Live to work, you need a VIN with factory options 614 and 615.
Read CMB_MEDIA and verify Short VIN in brackets [xxxxxxx] is FAKE VIN.
*** Use only to FDL Code CMB_MEDIA; DO NOT write this FA to the Car
1) Enable Data Transfer Option Under Phone
2) Enable Bluetooth Data Tethering on Phone
3) Under Connected drive; Update services (should show BMW Live and Internet services)
4) Go to BMW Live and Internet and make sure it it working
After it is working, use original VO with car VIN:
FDL CODE CMB_MEDIA:
- TELEMATIK_VIN = MOST_VIN
Read CMB_MEDIA and verify Short VIN in brackets [xxxxxxx] is REAL VIN.
DO NOT update services again or you will loose BMW Live and Internet.
*** If you do not return the Combox VIN to car VIN, you will encounter problems with future dealer programming, as the Combox will not be recognized, and programming will hault.
Hey Shawn, is this 100% reversible? Also if you don't mind me asking, where did you find the VIN with the telematic options?
      02-06-2013, 01:24 PM   #2555
steve@codemybimmer
Shawn, I changed my VO to the following but instead of connected drive, it's giving me BMW Assist again on the main menu. After writing the ghost VIN to the combox, I still don't have the option for BT data transfer under telephone.
Below is my current VO with all the modifications; is there something I need to remove?
1CA,205,216,249,255,258,2H2,302,322,403,423,430,43 1,441,459,465,494,4B8,4DM,4NE,507,520,521,522,534, 544,548,563,5DS,609,614,615,644,645,676,693,697,6A B,6AL,6NK,6VA,6WA,7S2,823,838,845,853,876,8KC,8SM, 925,992,993
      02-06-2013, 07:09 PM   #2556
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Yes, it is 100% reversible. Just use your factory VO, and VO Code Combox and Head Unit ECU's.
I have PM'd you a VIN to try with Factory 614 and 615.
      02-06-2013, 07:17 PM   #2557
shawnsheridan
Why do you have both 644 and 6NK? I think you need only 6NK.
Neither though includes BMW Assist, so I am not sure why it is appearing, unless it just cant handle the conflict between the two.
You can also just FDL Code HU_CIC / CONNECTED_DRIVE = aktiv to get ConnectedDrive Option.
      02-06-2013, 07:55 PM   #2558
steve@codemybimmer
My BMW Assist menu used to just list phone numbers for my nearest service centre and dealer. After coding the VO's, BMW Live and Internet now show up under that BMW assist menu but I still don't have the Bluetooth Data option available on my bluetooth profiles.
My Combox is currently running on the VIN you gave me and same result. I'm starting to think it's maybe the phone I'm using. When you got this to work, was this on a iPhone?
      02-06-2013, 07:57 PM   #2559
shawnsheridan
No, I have a corporate Blackberry.
Why do you have 644 and 6NK though?
      02-06-2013, 08:13 PM   #2560
steve@codemybimmer
6NK was changed from 6NH. The 644 was added there from from your original post; I never had it on my original factory VO. I'll try taking out 644 and just leave the 6NK and see what happens.
      02-06-2013, 08:36 PM   #2561
shawnsheridan
My car had 639, which is Bluetooth with Assist, and I replaced it with 644, which is Bluetooth without Assist.
Since you already have 639, which is Bluetooth without Assist, you don't need to add 644.
Also, do you have Mobile Hotspot and Tethering service on your iPhone, and do you have them enabled?
      02-06-2013, 08:49 PM   #2562
steve@codemybimmer
hmm I don't have 639 on my VO but I'll take out 644 and see what that does. I do have mobile hotspot and tethering enabled on my iPhone.
My understanding is, if you don't use the EU VIN but have BT Data enabled, it will give you an error messaging saying that BMW is not support in your region right?
      02-06-2013, 09:48 PM   #2563
ykau
Drives: F30 320I
hi shawn & kon,
yesterday, my dealer is trying to program my cic after mperformance kit installed. But however, they cannot complete the diagnostic test after its prompted out combo signal failed. eventually they put the blame on my 3rd party sound audio installed.
My bluetooth is working , any clue what is happening ? anything to do with the VO i i have changed previously from 6NH to 6NR?
PS: I ended up doing the Mperformance kit coding myself,as you have tips me to add SPBR and code DSC, but i want future new ilevel update. Thanks
      02-06-2013, 10:29 PM   #2564
TCC328
Malaysia
Drives: F30 328i
Hi all,
Finally read through the 2563 post in this thread, took me a while and downloaded E-Sys & PDZ data in between. Was amaze by the information and knowledge gain from reading.
Coded my F30 328i yesterday for the ASS and Delay time for folding mirror using Keyfob.
I am located in Malaysia, below is the SALAPA List I have:-
216,249,255,258,2A5,2PA,2TB,2VL,415,423,428,430,43 1,441,459,481,493,497,4AE,4AT,4DN,508,520,521,522, 534,544,548,563,575,609,614,615,676,699,6AA,6AB,6A L,6NF,6NK,6NR,6VA,6WA,7AC,823,825,853,861,874,880, 8KA,8S3,8SC,8TG,8TN,9C4
Kon,
I saw in a post that your bluetooth show additional phone, my don't have, any idea how to get that?
And another top in my list will be the Asian font thingy, seem like there is no solution yet, is there?
      02-06-2013, 11:08 PM   #2565
ykau
Drives: F30 320I
helping kon's replied, he may tell you to enable HU_CIC MACRO_PIM , but at your own risk again. My office pop up just like tat.
btw, which part of malaysia you are at, maybe can pop by pay you a visit when i'm there during chinese new year. (-:
Originally Posted by TCC328 View Post
Hi all,
Kon,
      02-06-2013, 11:36 PM   #2566
TCC328
Malaysia
Drives: F30 328i
I'm in KL, but away from 8 Feb, back on 12.
      02-07-2013, 01:32 AM   #2567
shawnsheridan
I meant to say you had 6NK (changed from 6NH), not 639. The point is that you only need one Bluetooth code, and 6NK is the one for you. I went from 639 to 644, just to eliminate BMW Assist. Likewise, if someone had 6NL, they would want to change it to 6NK.
      02-07-2013, 01:39 AM   #2568
shawnsheridan
hi shawn & kon,
I think you mean 6NH to 6NK, not 6NR.
I have no idea what caused ISTA/P to fail. It is possible 6NK written to the car may have, but I just don't know for sure.
      02-07-2013, 03:49 AM   #2569
steve@codemybimmer
I took out the 644 and VO coded HU_CIC and CMB_MEDIA with 614 and 615 added to my VO and I get the same thing. Enabling Connected Drive does allow me to see the connected drive menu with BMW Live and Internet there.
When I went back into HU_CIC, I noticed that BT Data Transfer and BT DUN weren't set to Aktiv so I changed those and I get the same result. Every time I pair my iPhone 5 to the car, I only have the audio and telephone options.
Not sure how you were able to get the BT Data Transfer option to become available on your BT profile but I can never get that to show up. I do have tethering and personal hotspot enabled on my device. Any more ideas?
On a note, I did change Language 1 to English UK and my voice control and navigation speaks with a British accent
      02-07-2013, 06:14 AM   #2570
kon
Singapore
Drives: F30 316i
he should have 6NK originally, to be absolutely sure, ykau check your current FA against bmwvin.com to confirm what you have altered
      02-07-2013, 06:17 AM   #2571
kon
Singapore
Drives: F30 316i
hi shawn & kon,
they must have their reason to blame the audio, best is check with your audio shop, alternatively, ask your audio shop to take out whatever they've add-on/connect to the combox or other parts of the vehicle and return to the dealer to verify. As mentioned earlier, you might also want to check what VO item you change, and restore it as well (compare against BMWvin.com)
      02-07-2013, 06:22 AM   #2572
kon
Singapore
Drives: F30 316i
Kon,
I'm envy, didn't know BMW Malaysia are pre-equipped with BMW Apps (6NR).
From your option list, I cannot see why you don't have additional telephone. Possible reason is that your I-step is too old, and BMW Malaysia has not activated it, or you didn't activate it yourself. Look inside Telephone / Bluetooth menu. Hit Option button > Bluetooth Settings, and make sure your "Additional Telephone" is selected.
      02-07-2013, 06:26 AM   #2573
kon
Singapore
Drives: F30 316i
pple ask for Additional Telephone, you teach pple Office... or bi good! (Singaporean slang)
      02-07-2013, 07:04 AM   #2574
TCC328
Malaysia
Drives: F30 328i
My bad, you are right, I didn't look into the setting, it was there. Thanks.
