      06-22-2012, 03:33 PM   #243
demge01
demge01's Avatar
Drives: F30 320ed
Originally Posted by Erik.klenke View Post
Sean,
I would like to get a cable built for my 2012 328i. Please let me know how to get in touch with you. I can't seem to find anyway to send you a direct message on the forum?
Thanks,
Erik
I ordered mine from the codecard link posted by Svache. Took about 10 days to arrive and it works fine. Costs a little more but another option.
      06-22-2012, 03:40 PM   #244
demge01
demge01's Avatar
Drives: F30 320ed
Originally Posted by svache View Post
Well, it seems you can code with the engine on.. lots of people have been doing this without any issues and I am currently doing this myself as well. It seems to be ok.
But, yeah, you can browse 'offline' as well, it's what I usually do. Basically you need to back up the files (read them) as described in the various guides in the first post, and then you can open them in e-sys by going to 'editors & viewers' and then to 'FDL-Editor'. It will then ask for the pin, then you can click on the button next to the text field where it says 'File Name', just open one of the CAFD files (the ones with the .ncd extentions) and you can browse them
Svache you really are a credit to this site - my thanks to you!
      06-22-2012, 04:59 PM   #245
svache
svache's Avatar
Drives: 2012 F30 328i
Sean,
Thanks,
Erik
4 more posts and you are able to send private messages (it takes 10 posts)
The alternative is indeed what demge01 said =)
@demge01: thanks for the compliments. I'm really just a regular guy who likes to spam a bit on the forums =)
F30 328i Luxury w/ Mojave metallic, beige interior (timeline)
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread
      06-22-2012, 06:20 PM   #246
Silver F30
Silver F30's Avatar
Drives: F30 Sportline
I have been working on using an ICOM from the dealer I work at. I have tried several different laptops with Windos XP and 7. I have assigned the network the IP address of the ICOM. The laptops see the network but will not read the VO. I have finally given up. THE BOTTOM LINE IS THE ICOM FROM A BMW DEALER WILL NOT WORK!
      06-22-2012, 06:21 PM   #247
Silver F30
Silver F30's Avatar
I now am building up my posts so I can get a cable from Sean.
      06-22-2012, 06:22 PM   #248
Silver F30
Silver F30's Avatar
I heard there was a guy in the Tysons Corner, VA area that is coding cars. Anyone know who that may be?
      06-22-2012, 08:43 PM   #249
Erik.klenke
Drives: 2012 328i Sportline
Thanks. I'll see what I can do about that
      06-22-2012, 11:36 PM   #250
Frogman
Frogman's Avatar
Then keep the spam coming!
I ended up building my own cable from the opened ended one available on amazon:
http://www.amazon.com/gp/product/B00...ls_o01_s00_i00
Really easy to do. I just used a 510 ohm .25w 2% resistor and spliced a sacrificed cat5 patch cable that had a ground shield on it already; otherwise I would have just crimped a plain RJ45 connector to it.
The cable worked on the first try and I made 3 separate backup copies of the CAF files just to be safe (I come from paranoid side of IT).
It did take me 3 days after first loading the CAF files to get up the courage to actually change stuff on my car. My wife would kill me if I bricked it!
Now that the changes are in, they are really cool and make the car so much better.
Thanks again for your efforts and the efforts of the F10 guys.
      06-23-2012, 04:36 AM   #251
dtliao
Drives: f10 535xi
FEM_BODY -> 3040 ClMaster -> CLM_TIME_DELAY_BOOTLID
FEM_BODY -> 30D0 RemoteControl -> RC_TIME_DELAY_BOOTLID
Both have as comment "timeout for delayed open control of the bootlid", so it is very well possible this is what you are looking for.
Thanks a lot for looking into that
I'll try to test it this weekend and see how it goes
      06-24-2012, 01:38 AM   #252
RASHID007
Drives: 2014 535d X-Drive
svache, thank you so much for all this amazing information!
I just coded my April 2012 build F30. I did all the mods EXCEPT those under FEM_BODY and REM as when I tried to read the coding data I received an error that it could not find the CAFD file. I checked in the psdzdata folders and I see that the required CAFD files are not in there. Does that mean I need a newer psdzdata file than v46.3? If so, where can I get the newest version?
Please and thank you.
      06-24-2012, 01:41 AM   #253
jpirelli
Power is nothing without control
jpirelli's Avatar
18
Drives: E90 + E92
Quick question for the experts.
Do I need to have one copy of the SWE folder inside C:\ESysData\psdzdata and also inside C:\ESysData?
Just wondering since that folder is 14 GB and it seems dumb that the program requires two copies of it within the same scheme of things.
Thanks.
      06-24-2012, 02:24 AM   #254
NiVeDh
NiVeDh's Avatar
Drives: '08 E90 335i, '99 E36 M3
Thanks.
Not sure, but I use NTFS symbolic links for situations like these where the programmers were not thinking.
It works for me using the symbolic link as I, too, did not want to have two identical copies of 14 GB. I have not tried it any other way.
      06-24-2012, 08:00 AM   #255
demge01
demge01's Avatar
Drives: F30 320ed
After doing some successful coding the other day I was going to do dome more today but the ENET cable connection does not seem to be working?
Local area connection 2 "doesnt have a valid IP configuration"
Any ideas?
Edit - working fine now after restating the lap top, switching off wifi etc.
      06-24-2012, 11:21 AM   #256
NiVeDh
NiVeDh's Avatar
Wait for 46.6 to be leaked.
      06-24-2012, 01:51 PM   #257
RASHID007
I was able to find one (cafd_00000794.caf.002_020_029) of the missing CAFD files (from another forum).
Now all I need is: cafd_000007A1_005_018_028
I coded everything I wanted so far. Check out the mirror folding and window up/down from key fob and from long holding the comfort access!
      06-24-2012, 02:38 PM   #258
jpirelli
jpirelli's Avatar
18
Drives: E90 + E92
AWESOME!!!
Thanks bro. It worked. It's stupid to have two copies IMO.
      06-24-2012, 05:20 PM   #259
svache
svache's Avatar
Thanks.
I agree, it does seem a bit dumb but I just did it anyways lol. I wasn't sure to which directory of the two the program would look at
I heard this one before, after people turn their wifi off it usually works again. Kinda weird, my wifi doesn't seem to bother the connection :S
http://img831.imageshack.us/img831/1804/capture3qq.jpg
http://img443.imageshack.us/img443/7955/capture2u.jpg
http://img72.imageshack.us/img72/116/captureenz.jpg
That's a weird problem.. I'm not exactly sure how that's possible. I doubt it is because of the dataset not being available, it should read the file regardless and if there would be an error, I kind of would expect a different one.. Either way, could you read the i-step number of your car? You can check this by putting your car's profile on an USB stick (by using the port in the glove compartment) and then read the file on a computer with notepad. Somewhere you should be able to read some numbers between these tags: <i-step> </i-step>. This way we can see if it is indeed the dataset or not, I doubt it but just to be sure
edit: well disregard my answer basically.. I just checked with some other people and they too think it might be outdated datafiles. Hopefully the 3.22 version of e-sys and 46.6 datafiles will become available soon. I especially expect problems with the current version once the 2013 cars come out.
(waiting for videos to upload to Youtube then I'll post link)
Just a word of caution: be careful with using CAFD's from other cars on your own car. There's a possibility the CAFD you downloaded does not have all the options enabled that you car may have come with, resulting in a disabled option or error codes (or worse, certain CAFD's contain safety related specifics and if something is changed there, your airbag, for example, could malfunction).
AWESOME!!!
I feel dumb lol
      06-24-2012, 06:25 PM   #260
NiVeDh
NiVeDh's Avatar
AWESOME!!!
Glad I could help! I recommend it to everyone, unless you don't mind having two copies of 14 GB worth of files.
      06-24-2012, 08:56 PM   #261
RASHID007
Added videos of coded results so far. Thanks all!
      06-25-2012, 09:19 AM   #262
Quelque
Netherlands
Drives: F30 330e
Hi Svache, just wanted to say thank you very much for this! It's so cool to modify stuff using a laptop
I have built my own cable using an existing shielded Ethernet cable (I believe they call it CAT6) and with a 511 Ohm resistor. It is working like a charm, I do not even get the yellow triangle with the Limited Connectivity message.
The other day I coded the ASS and when I have time I will do the rear lights as well. Yesterday I was browsing offline, but could not figure out exactly what to set yet as I have werte=14 instead of off. There is also a separate off section
If there are suckers like me that blow the cigarette lighter fuse... The fuse is under the hood at position 66.
Thanks a lot man!
      06-25-2012, 11:47 PM   #263
johntchow
#beastmodeallday
Drives: MW F30 335i
i finally took the plunge and coded our x3. its pretty much like the f10 cheat sheet. i the only part that was the same as the f30 was the hucic. everything else i was able to get from the f10 cheat sheet. pretty sweet
was able to unlock the dvd in motion, trunk closing with remote, etc.
might need to check the f10 forums though because i wasnt able to figure out how to make the top view mirrors stay on.
HIS: 2018 M550 / 2015 535i / 2012 335i / 2009 328i / 2007 X3 / 2004 X3
HERS: 2016 535i / 2014 328 GT / 2012 X3 / 2009 X5
      06-26-2012, 10:50 AM   #264
martinf79
martinf79's Avatar
78
Drives: F30 335i M Sport
Anyone know of a cheaper place to buy this cable (as Sean apparently is no longer making them), and the site in Serbia (or where ever it is) will run me nearly $80 Canadian (w/ shipping and conversion). $80 for a cable seems a bit steep. Any other options?
2013 335i ///M-Sport | + 2015 X3 28i xLine
