      02-12-2013, 03:28 AM   #2619
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
Originally Posted by gerbs View Post
Thanks for the advice. I will check the debug file and post it here when I'm back at the laptop.
I did code multiple modules from 48.3 though using E-Sys v3.18.4. (hu_cic, kombi, rem_01).
I don't think my F30 necessarily needs the files from 48.3, maybe a slightly earlier version of 48.x. Or would that not make a difference?
If you are at an integration level less than F020-12-11-505, then you can used 48.1 or 48.2 and you can use the old E-sys token with 3.18.4.
If you are at F020-12-11-505, then you need 48.3.
You can check your integration level of your car using this procedure:
http://www.f30post.com/forums/showpo...postcount=1403
When you successfully coded your CIC and others, did you do it with just the new 48.3 CAFD files, or with a complete 48.3 install?
      02-12-2013, 03:46 AM   #2620
pixelfreak0410
Drives: M235i Convertible
Originally Posted by Aritaurus View Post
You need to program another vehicle's VIN that has the 614 and 615 options since you don't have those option codes on your original VIN. Shawnsheridan has some instructions on how to do that and it should be on page 50 of this thread.
How did you end up getting data transfer to work? Was it available as soon as you VO coded HU_CIC? I've tried pairing a Samsung Galaxy Note, iPhone 5 and a Xperia Arc and all three did not work.
OK, where can I get or generate a working fake VIN? Yes it was not there before, but after adding 6al, 614, 615 and coding hu_CIC and cmb_media it appered but needs to be activated by opening the Option menu on telephone Bluetooth page. On my droid I activated Bluetooth tethering. I am usig cyanogenmod 10.1, but it should work with regular rom, too.
      02-12-2013, 06:13 AM   #2621
raj10800
Drives: F30 320D sports Plus
Originally Posted by pixelfreak0410 View Post
Hello,
I successfully went from 6nh to 6nk some days ago, and now I also added 6AL (BMW Live), 614 Internet and 615 (Extended Online Services) to my car. The data connection via my android phone works fine. Data connection can be established and my phone starts tethering mode.
But in I-Drive I only get these messages:
BMW Internet:
Translation "Internet is not available in this country. Other BMW services can be used."
BMW Live:
Translation: "Home page currently not available. Please try again later."
Hi can you send me a step-by-step instructions on how to code 6NH to 6NK...thanks
      02-12-2013, 07:57 AM   #2622
pixelfreak0410
Have a look some pages before here. Posted my steps there before did it.
      02-12-2013, 08:42 AM   #2623
raj10800
6NH to 6NK
Originally Posted by shawnsheridan View Post
It is the routine in E-Sys for Calculating the Vehicle Profile (FP).
Did you completely delete your existing PSdZData Folder before copying over the new folder?
Hi Shawn,
Can you send me instructions on how to code my car from 6NH to 6NK. I have Prof Navigation with 6NH. Also, where can I find all the coding files and how can I get them.
Thanks
Rajesh
      02-12-2013, 09:56 AM   #2624
Kapitein Iglo
Drives: F31
Might be usefull to add them in the Excel on page 1?
      02-12-2013, 11:11 AM   #2625
pixelfreak0410
There are some steps necessary. Basically you have to follow Guide 3 (E-Sys - Getting Started Supplement - Part 3.pdf ) of the documents which are attached on initial post of this thread to change from 6nh to 6nk. Afterwards you just hit the code button for HU_CIC and CMB_Media in the code section in expert mode.
      02-12-2013, 11:21 AM   #2626
pixelfreak0410
Hello,
BMW Internet:
BMW Live:
That was last night. This morning started my car and went to BMW Live. Now I got a wizard for selecting my country and so on. But after setting up - I now get a different error message. Whats up there? Do I still need to change VIN? The wizard did not came up last night.
      02-12-2013, 12:27 PM   #2627
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by raj10800 View Post
Hi Shawn,
Thanks
Rajesh
I can't send you anything as your Post Count is too low. So, either increase your Post Count, or put up an email address.
Changing from 6NH to 6NK is quite simple. Edit your FA (VO) to replace 6NH with 6NK. Load and activate modified FA, and VO code Head Unit and Combox if you have one.
      02-12-2013, 01:29 PM   #2628
Kapitein Iglo
Drives: F31
Being quite new to this, I wonder what replacing 6NH with 6NK actually does to your car. Does this mean you get voice control?
      02-12-2013, 01:31 PM   #2629
shawnsheridan
No. Assuming you had the hardware required for Voice Control, Voice Control requires an FSC Code Imported and Activated in CIC or NBT.
      02-12-2013, 02:12 PM   #2630
gerbs
woof
gerbs's Avatar
Drives: M6
Send a message via AIM to gerbs
Thank you for all the helpful info. I'll run that procedure shortly and see what I get in return. I'm starting to think if I can find the 48.2 or 48.1 psdzdata files I would be in good shape.
When I coded my CIC, I did not do a complete install. Just removed the old psdzdata folder, and moved in the 48.3 psdzdata folder -this is the method which worked for cic, rem, kombi, but not fem_body.
I attached the log here. It's capturing when I try to code fem_body and it's consequent failure.
2013 F13 ///M6 Sakhir Orange
2013 F30 335i Estoril Blue II
2008 E92 ///M3 Interlagos Blue
2007 E92 335i Montego Blue
      02-12-2013, 02:23 PM   #2631
Kapitein Iglo
Drives: F31
Then why would one change 6NH to 6NK?
      02-12-2013, 02:23 PM   #2632
shawnsheridan
To get BT Streaming.
      02-12-2013, 02:28 PM   #2633
Frogman
Frogman's Avatar
FEM_BODY (794) 004_124_042 was added in release 48.1. Try reverting to a full release of 48.1 and try coding it again.
Don't hassle with 48.3 until you need it.
      02-12-2013, 02:40 PM   #2634
RayF31
Netherlands
Drives: F31 320iA HE M-sport
I configured and installed a virtual XP and 7 with E-sys 3.18.4 and psdz 48.1 on my MacBook with both Parallels and VMware fusion but I was unable to get a working connection. Now troubleshooting back I found I do not even receive an ip address on my MacBook 's network adapter other as a 169.254.x.x (apipa address). This basically explains why it is not working in a virtual windows xp/7 as I do not receive an IP address on a normal network adapter.
Now I am wondering if anybody knows which IP address, subnetmask has to be configured manually to make a connection if dhcp is not working ?
Grtz,
Ray
      02-12-2013, 03:09 PM   #2635
gerbs
woof
gerbs's Avatar
Drives: M6
Sounds good.
Would anyone mind PMing me the download links for 48.1?
      02-12-2013, 03:28 PM   #2636
RayF31
Netherlands
PM sent
      02-12-2013, 05:49 PM   #2637
gerbs
woof
gerbs's Avatar
Drives: M6
Spanks!
      02-12-2013, 05:50 PM   #2638
hrosenberg33
Drives: BMW 328i Xdrive Sport Line
Also use of the iPhone white cable and not having to buy a y-cable.
      02-12-2013, 05:56 PM   #2639
Merlinx1
Italy
Drives: Bmw F20 125i Msport
Hello everybody. I'm an F20's 125i italian owner.
I looked for a topic where introduce me but didn't find anything.
I have some problem with my car:
I bought it in Germany and it's fully specced with all the necessary for connectivity: nav prof,internet,bmw online, bmw live,apps etc...
The problem is I can't connect to bmw online via bluetooth connection of my phone, neither I can access to emails and text messages from it.
I can just look at my contacts but nothing more and so I cant access internet via my phone neither via car's connection.
I've read that maybe there's something to code to make internet or bmw live or bmw online (didn't understood well ) works on my car.
Can someone help me?
Thanks very much!
      02-12-2013, 07:15 PM   #2640
chriskd
Drives: 2016 340i M Sport
I'm using Macbook Pro with Bootcamp on Win7 and have no problems coding.
