proTUNING Freaks
      02-17-2013, 07:33 PM   #2707
kon
Singapore
20
Drives: F30 310i > G20 310i
Originally Posted by john08135i View Post
i did and i drove across time zone few times with no change..
I might sounded silly but do you have nav/gps?
have coded mine a few months now, it still somehow sync with my iphone time exact down to the second (the minute tick together)
      02-17-2013, 07:44 PM   #2708
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Yes of course. I set it and drove across few time zones no change at all.
M Sport Line Estoril Blue
      02-18-2013, 02:06 AM   #2709
lokito
lokito's Avatar
Puerto Rico
Drives: 335i ///M Sport
Originally Posted by Frogman View Post
For the mirror folding and windows up/down via the fob, you also have to code FEM_BODY / 3053 PwMaster / KOMFORTSCHLISSUNG_FB to aktiv (Werte=00).
Note that Werte=00 is not a typo, it's a strange one in that usually aktiv has a Werte=01 and nicht_aktiv has a werte of 00). This one does not!
Just code the function value to aktiv and leave the Werte alone and you will be fine.
I can't help you on the FEM_BODY / 3050 / FH_TUERAUF_STOP_MAUT, that only needs that one value to be changed. Note that you need to set it to nicht_aktiv (default is aktiv). You should double check that it's actually coded to nicht_aktiv by re-reading the coding data from the car.
Awesome, thanks! That fixed the problem with the mirrors. About the windows roll up, the value is set to nicht_aktiv. Not sure why is not working, I might change it back to default and try again.
2013 335i ///M-Sport |6MT|Mineral Grey|DHP|PDC|HK|
      02-18-2013, 04:45 AM   #2710
raj10800
Drives: G20 330i
Originally Posted by shawnsheridan View Post
A2DP requires 6NK or 6NL. If you have only 6NH, I do not think you can code it.
BMW Apps will require you to purchase a 6NR FSC Code and Import and Activate it, and if you want the Video / PlugIn functionality too, you have to retrofit 6NF Ejector Box (Base Plate), or replace the 6FL USB/Aux-In port with the Mini USB/AV-In port and run FBAS video line from new connector to the CIC.
Shawn,
As mentiuoned earlier I have 6NH and Prof Navigation. Will I be able to code 6NH to 6NK (as sent tome by you earlier) or is it not possible as per your this quote.
Regards,
Rajesh
      02-18-2013, 09:17 AM   #2711
ykau
Drives: F30 320I
that is strange. I have my Ilevel upgraded to 505 today and all settings are reverted back. the strange thing was I as usual set the INHK -> memory_off -> the air con setting and suddenly the air con heater button went blinking. Try to set it back but the INHK-CAFD-SVT are gone or rather its no longer green anymore.
what worst is blowing warm air instead of air con. What happened to it guys. I'm using 3.18 and 48.1. thanks
      02-18-2013, 09:29 AM   #2712
shawnsheridan
shawnsheridan's Avatar
Not sure, but you need to add CAFD back.
Connect => Read FA => Activate FA => Read VCM => Left-Click on INHK => Click on "Detect CAF for SWE" => Select the CAFD matching your I-Level => Select OK => Right-Click on INHK (the ECU itself not the underlying CAFD) => Select CODE.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      02-18-2013, 09:31 AM   #2713
ykau
Drives: F30 320I
thanks bro. it works!! You have saved me once again!!
      02-18-2013, 06:26 PM   #2714
ykau
Drives: F30 320I
Hi shawn, I wondered if i'm being paranoid, the car engine sounded more noisy than before after the ilevel upgrading. It sounded more like a truck now. Anything to do with INHK? thanks
      02-18-2013, 06:46 PM   #2715
shawnsheridan
Originally Posted by raj10800 View Post
Shawn,
Regards,
Rajesh
With Nav Pro, you should have a Combox, so you should be able to go from 6NH to 6NK.
      02-18-2013, 06:48 PM   #2716
shawnsheridan
I don't see how. This ECU is for the Integrated automatic heating/air conditioning system.
      02-18-2013, 07:01 PM   #2717
ykau
Drives: F30 320I
thanks bro. I think could be the normal characteristic of the car .
      02-18-2013, 07:35 PM   #2718
kon
Singapore
20
The dreaded 505. You should be using esys3.22 and 48.3 already. But it's interesting that you could still code, all we get was error when trying to code. And since you've moved up to 505, safe to assume dealer upgraded your car I-level successfully then.
      02-18-2013, 07:57 PM   #2719
ykau
Drives: F30 320I
Originally Posted by kon View Post
The dreaded 505. You should be using esys3.22 and 48.3 already. Button it's interesting you could still code, all we for was error. And since you've moved up to 505, safe to assume dealer upgraded your car I-level successfully then.
hi kon, yes. I can still code INHK, FEM_BODY and KOMBI but except for HU_CIC. Upgrading was first failed until I have reverted back the VO settings including the office or the bmw apps.
Now the problem is it seem the engine is louder than before. sigh... can i pay you a visit?
You guys may want to take note before the upgrading process. thanks.
      02-18-2013, 08:36 PM   #2720
kon
Singapore
20
For? I can't fix loud engine noise
      02-19-2013, 08:37 AM   #2721
raj10800
Drives: G20 330i
Originally Posted by Aritaurus View Post
I was actually on 6NH and changed it to 6NK. I just FDL coded a few things on HU_CIC and got connected drive to come up.
I think this is the part where I need to use a ghost vin like you said earlier. For me, I have nothing to lose since I don't have BMW assist. It just shows up on my menu with some phone numbers to call for service.
Hi Aritaurus - what do I need to code to get Connected drive enabled. I have a F30 with 6NH and Prof Nav.
      02-19-2013, 08:45 AM   #2722
shawnsheridan
Some people will want to know what was done to enable "truck engine" option...so they can do it too.
      02-19-2013, 01:35 PM   #2723
dcg71
Australia
72
Drives: F15 X5
DIES_IST_TRUCK -> activ
2015 F15 X5 25d Space Gray | Pure Excellence | Dakota Leather/Brushed Aluminium | Anthracite Head Liner | Fender Flares | Connected Drive + Real Time Traffic
2012 F30 335i Sapphire Black
2006 E92 325i Titan Silver
2000 E46 318i Cosmos Black
      02-19-2013, 03:03 PM   #2724
eclipsisNA
Drives: 2013 Estoril 328i M Sport
2014 BMW 428i  [7.76]
Can anyone confirm that a USB OBD2 cable would work instead of an ENET? I was looking at this:
http://www.ebay.com/itm/DIAGNOSTIC-C...item43b194141a
      02-19-2013, 03:36 PM   #2725
shawnsheridan
Work for what? E-Sys? No. It must be an ENET Cable. That cable is a VAG-COM Cable for VW & Audi.
      02-19-2013, 03:39 PM   #2726
martinf79
martinf79's Avatar
189
Drives: 2020 G05 X5 M50i
I'd like to know what option this is....
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
      02-19-2013, 08:28 PM   #2727
martianpc
Drives: 2013 335i
These torrents are really looking good. Any idea how many seeders we have? I may have to back off, my network has been giving me trouble. I have uploaded 244GB so far over the 4 files since started seeding though! I think we have a lot of people who want to code.
2013 MG 335i
      02-19-2013, 08:30 PM   #2728
shawnsheridan
My server is still serving up around 500 Gb per day.
