European Auto Source
      02-19-2013, 11:03 PM   #2729
reidpath
Drives: 328i
Originally Posted by martianpc
These torrents are really looking good. Any idea how many seeders we have? I may have to back off, my network has been giving me trouble. I have uploaded 244GB so far over the 4 files since started seeding though! I think we have a lot of people who want to code.
I have Fios and they don't care
      02-20-2013, 12:26 AM   #2730
martianpc
Drives: 2013 335i
I use a HTPC and stream my live TV and recordings to other Tv's in the house over my network. I have been having trouble with bandwidth internally and I am thinking that the torrents could be part of the problem. No other good explanations are coming to mind. I wish I had FIOS though, unrelated but great stuff....
2013 MG 335i
      02-20-2013, 12:28 AM   #2731
kon
Singapore
Drives: F30 316i
Originally Posted by shawnsheridan View Post
Some people will want to know what was done to enable "truck engine" option...so they can do it too.
I think maybe the N20 motor came with ASD to mask the truck sound, but was turn off accidentally Maybe ykau can change the settings to M5 or M6, then instead of truck, he'll get vrrrrrooooom
      02-20-2013, 03:16 AM   #2732
buildbright
buildbright's Avatar
92
Drives: F80 M3 MG
Anybody have an idea or a lead to changing the VO to add option 710 or S710A the M Sport Steerinig Wheel?
      02-20-2013, 03:23 AM   #2733
ramonE90-NL
Netherlands
18
Drives: bmw F30 320iA
Since a few days my usb music streaming with iphone 4s stopped working.
I always use the white usb cable, i also dont get a V in the media menu where you can see if the phone is connected.
This always used to work, i didnt code it.
The bluetooth streaming still works.
I did code the connected drive and internet. Could this have to do something with the usb connection?
      02-20-2013, 07:06 AM   #2734
raj10800
Drives: F30 320D sports Plus
Originally Posted by ykau View Post
hi raj10800, this topic can be back trace from the front... For not troubling our seniors, i will answer for them that you need 3.18 and 48.1 will do.
For the connection wise, please refer to front thread. hope my explanation helps.
P.S. Think twice before you convert 6NH to 6NK, may risk failure cic update from dealer.
My Idrive software is 2.48.3. Now which version will I need?
      02-20-2013, 07:26 AM   #2735
raj10800
For my car with Combox:
Change VO as follows:
- 639 (or 633 or 612 if present)
+ 644
+ 614
+ 615 (Required but already present)
+ 6AL
+ 6AB (Required but already present)
VO CODE HU_CIC
VO CODE CMB_MEDIA
FDL CODE CMB_MEDIA:
- TELEMATIK_VIN = Coding_VIN
FDL CODE CMB_MEDIA:
Use modified VO with VIN that has factory options 614 and 615 as explained in my post here:
For writing a VIN to the Combox in E-Sys, I figured that out, and it is very simple:
So simple in fact, that I am mad I spent so much damn time in Tool32, CMEDIA.prg and E-Sys trying to figure it out.
First you must code CMB_MEDIA / TELEMATIK_VIN = Coding VIN using your real FA VIN. Then, open your FA up in the FA-Editor, change the VIN, Caluclate FP just to make sure there are no problems with it, and then save the FA with a new name, i.e. FA_VIN_FAKE. Lastly, go to the coding module, and under Vehicle Order load your new FA_VIN_FAKE, activate FA, and then FDL code CMB_MEDIA. Lastly, read CMB_MEDIA coding data, and verify the new VIN in brackets. In the attached picture, you can see my Combox and Head Unit are showing two different VIN's.
Afterwards, either shut down E-Sys, or load your original FA back and activate it before coding anything else. DO NOT code anything else with this FA, and DO NOT write this FA to the car.
For Internet and BMW Live to work, you need a VIN with factory options 614 and 615.
Read CMB_MEDIA and verify Short VIN in brackets [xxxxxxx] is FAKE VIN.
*** Use only to FDL Code CMB_MEDIA; DO NOT write this FA to the Car
1) Enable Data Transfer Option Under Phone
2) Enable Bluetooth Data Tethering on Phone
3) Under Connected drive; Update services (should show BMW Live and Internet services)
4) Go to BMW Live and Internet and make sure it it working
After it is working, use original VO with car VIN:
FDL CODE CMB_MEDIA:
- TELEMATIK_VIN = MOST_VIN
Read CMB_MEDIA and verify Short VIN in brackets [xxxxxxx] is REAL VIN.
DO NOT update services again or you will loose BMW Live and Internet.
*** If you do not return the Combox VIN to car VIN, you will encounter problems with future dealer programming, as the Combox will not be recognized, and programming will hault.
Hi Shawn - how do I activate the above in my car which does not have 614 or 615 - has only 6NH and Prof Nav? Which VIN can I use in my car?
      02-20-2013, 11:53 AM   #2736
playmobilboy
Drives: 2012 BMW 118i sport
I have a F20 with standard steering, is there any way I can code my car to have servotronic steering? I think this is more a software thing while the variable sporting steering is hardware thing which cannot be coded for sure.
      02-20-2013, 11:59 AM   #2737
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
To log into3.18.4, I am using the password lo8F3lsVVg per the directions and it's not working
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      02-20-2013, 11:59 AM   #2738
335XI-n-VA
Drives: 2013 Active Hybrid 3 - Sport
Can somone send me a VIN to try for BMW Live?
Could someone send me a VIN I could try for BMW live activation with Bluetooth Networking?
Thanks in advance,
Dave
2013 Active Hybrid 3 -Sport|Mineral White|Dakota Black|Tech|Premium|Cold|Park Distance|Rearview Cam|Harmon Kardon|Sport Transmission
      02-21-2013, 03:21 AM   #2739
kon
Singapore
Drives: F30 316i
that password is to install 3.18.4, if you're trying to do FDL code, you need to have the codeaway.est file, and have esys pointing to this file in the preferences, password is 2690
      02-21-2013, 03:23 AM   #2740
kon
Singapore
Drives: F30 316i
Never tried before, but have you tried searching in EPS module? that seems to be only one steering related.
      02-21-2013, 03:24 AM   #2741
kon
Singapore
Drives: F30 316i
Thanks in advance,
Dave
Shawn mentioned using BMWvin.com and a bit of luck to get the VIN, start with a few number off from your VIN hopefully, you'll nail one
You can start with this: F09XXXX (replace XXXX with 4 random digit)
      02-21-2013, 03:25 AM   #2742
kon
Singapore
Drives: F30 316i
You are in India right? I assume BMW doesn't offer BMW Assist in your country? In that case, you don't need a ghost vin. Ghost vin is really only valid for US (and maybe Canadian vehicle) as their data is via the inbuilt data plan (car), not via telephone like the rest of the world.
      02-21-2013, 03:26 AM   #2743
kon
Singapore
Drives: F30 316i
that's a hardware change right? why is coding involved?
      02-21-2013, 10:43 AM   #2744
Jamesons Viggen
I got it to work yesterday.
Thanks to lots of guidance from Shawn, I coded the Satellite radio to work.
      02-21-2013, 11:21 AM   #2745
Ali.K_BMW
Ali.K_BMW's Avatar
Drives: 2016 BMW 428xi
2013 BMW 335i  [0.00]
anyone in the South Jersey area? neeeed some coding! thanks
Former BMW Client Advisor
2018 M3 CP (soon) , 2016 428i xD, 2016 328i XD
2013 335i, 2013 335i AH, 2013 328i, 2011 M3 CV, 2009 335i
      02-21-2013, 11:22 AM   #2746
ykau
Drives: F30 320I
if changing of steering with OLED display, need to code. Otherwise plug and play. my dealer told me one.
      02-21-2013, 11:28 AM   #2747
kon
Singapore
Drives: F30 316i
But m sport steering wheel no display. With display is m performance version
      02-21-2013, 01:17 PM   #2748
buildbright
92
Drives: F80 M3 MG
Airbag is different one is a dual phase the other is a single phase. Everything works I just have an airbag error. Can you see if there are any airbag variables?
      02-21-2013, 02:49 PM   #2749
Puri1
Puri1's Avatar
Drives: F30 328i 2012
Could you please post a step by step for this? Thanks
2012 F30 328i, Alpine White on Black, Luxury, Premium + Exec. Package...
      02-21-2013, 04:52 PM   #2750
Jamesons Viggen
You have to start with purchasing an FSC code lol.
