Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
      02-24-2013, 09:03 PM   #2795
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Originally Posted by Yobyot View Post
A tip: I find that Activating the FA FIRST is less bothersome than doing it when trying to code the FDLs. You can activate the FA anytime -- I do it before I start searching for things to change.
...and did you know also you can double click on FA to activate it instead of Right-Click => Activate FA.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      02-24-2013, 09:15 PM   #2796
Yobyot
Yobyot's Avatar
30
Drives: MY12 F30 ZSL
Cool!
MY12 335i ZSL with a deep dive into the options list
Produced: 2012-06-22
ED: 2012-07-19; Arrived in Jersey City: 2012-08-23
Redelivered: 2012-09-12
      02-25-2013, 12:18 AM   #2797
martianpc
Drives: 2013 335i
I need help connecting. I get ZGW to show my ip info. In Esys it shows my vin but nothing is showing up under target to click for the F20. This is using the new version of esys. Thanks in advance!
2013 MG 335i
      02-25-2013, 12:20 AM   #2798
martianpc
Drives: 2013 335i
Fixed my own problem, had to change esys settings directory. Thanks anyway.
Now when I try to edit fdl I get asked for the pin. I enter 2690 and I get an error. I have I-Step F020-12-11-504 and am using 48.1 data files with 3.22.5 esys. Shouldnt this work? I thought I only needed the new token for 48.3? Any ideas?
2013 MG 335i
      02-25-2013, 01:57 AM   #2799
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
Are you using the Code Away token? Did you verify that E-Sys is setup with the correct path to the .est file?
Options -> Settings, EST tab.
      02-25-2013, 02:18 AM   #2800
shawnsheridan
2690 is the PIN for the Code Away EST Token, which goes with 3.18.4. If you are using 3.22.5, you should have a new Token and corresponding PIN.
      02-25-2013, 02:33 AM   #2801
Frogman
Frogman's Avatar
Plus you'll need the 3.22.5 patch too!
      02-25-2013, 05:18 AM   #2802
ykau
Drives: F30 320I
The program seem not be marrying well with my Win 7. Can teach me how to use E-sys to read VIN IB? thanks
You just need the SWID Reader Program, which works with EDIABAS.
SWID Reader for reading 001B FSC file. Rename file from .pdf to zip
Download: SWID_reader.pdf
I have found a way to do this in E-Sys, but I assure you it is a royal PIA.
      02-25-2013, 08:36 AM   #2803
martianpc
Drives: 2013 335i
Is there any reason I should use 3.22.5 instead of 3.18 if not necessary?
2013 MG 335i
      02-25-2013, 11:13 AM   #2804
Frogman
Frogman's Avatar
Not that I know of. Just use 3.18.4 until you have to go to 48.3.
      02-25-2013, 11:45 AM   #2805
DaKrnz
Drives: 2013 335i M-Sport
ANY South FLorida coders out there who want to help on coding in person??
I just need help to "how to use, do this & that," i want to get into coding but still timid..
so please help me
      02-25-2013, 08:23 PM   #2806
shawnsheridan
For just coding, no....
      02-25-2013, 08:29 PM   #2807
martianpc
Drives: 2013 335i
Thanks for the help, I got it working. Until they update me anyway.
2013 MG 335i
      02-26-2013, 05:37 AM   #2808
ramonE90-NL
Netherlands
Drives: bmw F30 320iA
Originally Posted by pixelfreak0410
1. Does anyone know if internet access uses bluetooth PAN or DUN profile? My phone has only PAN (tethering), but the data option is not shown currently when pairing my phone. But maybe because no internet function is coded, yet?
2. Is it possible to code RTTI (real time traffic information) ?
3. Here they got video from iphone working (watch minute 2:03). Does anyone know how to make it work?
I would like to know this too
      02-26-2013, 08:19 AM   #2809
shawnsheridan
Send me a PM with your email.
      02-26-2013, 08:34 AM   #2810
ykau
Drives: F30 320I
thanks bro. will drop you an email.
      02-26-2013, 12:38 PM   #2811
SergioK
Drives: F30 328i
Originally Posted by venkata View Post
Hi, I have an F30 Msport on order here in the UK (BW10) and expecting delivery end of March. Presumably E-Sys 3.18.4 and PSDZData 2.46.3 will work fine???
2.46.3 is way too old for a new 2013 F30. You will probably have at least 2.48.3.
You'll need a new token and patch to use 48.3. PM shawnsheridan for details.
You should probably go to E-Sys 3.22.5 (after first installing 3.18.4) as it seems to load much faster than 3.18.4 and is more current.
That very well may be the case. Though, my car is a 2013 (nov 2012 build) and after delivery it's 'Integration Level' was only at 12-11-504 so I could still code using 48.1.
Before you start coding check: http://www.f30post.com/forums/showpo...postcount=1403
If my notes are correct after 505 you need 2.48.3 but 504 only needs 2.48.1, correct me if I'm wrong.
      02-26-2013, 04:11 PM   #2812
venkata
venkata's Avatar
Drives: F30 330e MSport
How do you find the integration level of the car?
Driving: F30 330e
// /M-Sport | Mineral Grey | Coral Red Leather | M Sport Plus Pack | Media Pro Plus Pack | Active Security Pack | Adaptive LED Lights | Advanced Parking Pack | Interior Comfort Pack | Enhanced Bluetooth with Wireless Charging| Black Performance Grill | Heated Seats | Heated Steering | Speed Limit Display
      02-26-2013, 04:52 PM   #2813
SergioK
Drives: F30 328i
Follow the link in my post...
It'll be displayed here:
      02-26-2013, 08:58 PM   #2814
08bmw128i
Drives: 2018 X5M
F10 coding
Does anyone know how to code the fog logs on the f10 to be used as cornering lamps when making a left or right turn? Also can you get the door handles to light up when putting the car in reverse?
I know the X3 and X5 uses the fog lights for cornering lamps so I'm sure this is possible. I have other things already coded.
      02-26-2013, 09:23 PM   #2815
shawnsheridan
Yes and no.
F020-12-11-505 = ISTA/P 2.48.3, and you would need the updated Patch / Token for it.
F020-12-11-504 = ISTA/P 2.48.2, and while you don't need the updated Patch / Token for it, the older 48.1 PSdZData may not work.
      02-26-2013, 11:45 PM   #2816
mauricef
Drives: 2013 M5 Black/Black
I have searched by have not been able to find the E-Sys software. Can someone point me to where I can find it?
Thanks in advance.
