Vorsteiner
      02-26-2013, 11:48 PM   #2817
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by mauricef View Post
I have searched by have not been able to find the E-Sys software. Can someone point me to where I can find it?
Thanks in advance.
PM sent, assuming it is for F10 M5.
      02-27-2013, 08:22 AM   #2818
raj10800
Drives: F30 320D sports Plus
Originally Posted by shawnsheridan View Post
The steps are identical, but you don't have to change the VIN.
That said, whether you have BMW Assist to not, you still need a VIN with factory 614 and 615.
Hi Shawn - pardon my ignorance - why do I need a VIN with 614 and 615 - cant I just copy all the options mentioned in your post and VO code it to make it work.
      02-27-2013, 08:24 AM   #2819
shawnsheridan
Because you car does not have factory 614.
You can try it though, and see if it works.
      02-27-2013, 08:56 AM   #2820
martianpc
Drives: 2013 335i
Yes and no.
F020-12-11-505 = ISTA/P 2.48.3, and you would need the updated Patch / Token for it.
F020-12-11-504 = ISTA/P 2.48.2, and while you don't need the updated Patch / Token for it, the older 48.1 PSdZData may not work.
2.48.1 and f020-11-504 worked for me :-)
2013 MG 335i
      02-27-2013, 09:16 AM   #2821
raj10800
Originally Posted by kon View Post
You'll want to vo code:
614 Internet
615 extended bmw online info
6AL BMW LIVE
Same thing need to code hu_cic & cmb_media
Hi Kon,
I have 6NH and Prof Navigation. To add BmW Live and Internet, do I need to do the following :-
VO code 614, 615, 6AL and then VO code hu_cic and cmb_media in the same way we code from 6NK to 6NK? Anything else I need to do?
Regards,
Rajesh
      02-27-2013, 09:42 AM   #2822
kon
Singapore
Drives: F30 316i
Hi Kon,
Regards,
Rajesh
You mean change 6NH to 6NK? I would definitely try this first. If it doesn't work, then add the ghost vin as shawn suggested.
BTW, after you complete your coding, it is NORMAL to see the option in your idrive and it won't work... something along the line "homepage not available". Leave the car alone overnight or a couple of hours and try again. This is normal behaviour for ALL CARS that i've activated bmw live so far. But immediately after coding you should see the option appearing under BMW Services.
      02-27-2013, 10:28 AM   #2823
shawnsheridan
Yes, it may or may not work. It all depends on the car's options and ECU CAFD's and if it needs one from the newer version or not. 48.2 is the safe bet, and 48.1 is a crap shoot.
      02-27-2013, 02:12 PM   #2824
raj10800
No...add BMW Live and Internet the same way as we 6NH is converted to 6NK
      02-27-2013, 04:38 PM   #2825
pindour
Drives: x5
Hi all,
its possible connection CIC telnet via ICOM?
Thanks
      02-27-2013, 05:08 PM   #2826
tristras
tristras's Avatar
Drives: 328 i Xdrive 2013
Hi all:
I'm new to this forum, I got my cable today, already installed e-sys 3.22.5 on my macbook and copy the psdzdata 48.3 files; my 2013 328i Xdrive will be delivered tomorrow.
What else I need to start coding?
Thanks
      02-27-2013, 05:34 PM   #2827
Yobyot
Yobyot's Avatar
56
Drives: MY12 F30 ZSL
Originally Posted by tristras View Post
Hi all:
Thanks
Patience.
I would strongly recommend that you learn what the car does and gain experience with it in its factory state before you start coding.
MY12 335i ZSL:
Produced: 2012-06-22; ED: 2012-07-19; Arrived in Jersey City: 2012-08-23; Redelivered: 2012-09-12
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29
      02-27-2013, 11:05 PM   #2828
tristras
tristras's Avatar
Hi all:
Thanks
Patience.
Thanks, believe me I have a lot of that.
      02-28-2013, 12:07 PM   #2829
SergioK
Drives: F30 328i
Me too, though I only coded the temp/pressures displayed in the tpms screen.
From my coding notes: F020-12-11-504 - ISTA/P version 2.45.1 PSdZDa: 48.1
Not sure what other coding options would be 'enabled' going from 48.1 to 48.2.
      02-28-2013, 10:00 PM   #2830
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
in case anyone is interested you can make the LED lights on the mirrors be part of the welcome lights.
Fembody 3062 mapping_blinken_z_L_part of WL
Fembody 3062 mapping_blinken_z_R_part of WL
Turn both to "hard on" since they are LED's
      03-01-2013, 12:42 AM   #2831
AntBabeee
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
Question
How do i code it so that my car doesn't check for error in the reverse lights? I put in error free LED reverse light but it flickers when i turn on car and randomly while driving.
Another member told me its the car constantly checking bulbs so it flicks when it check. Said it's possible to code it so it doesn't check.
Is there an option to just code the reverse check only or if code the check off then its for all lights in car?
F30 BMW 335i M-Sport: Estoril Blue II, 19" Rims, Sports Auto, Premium, Technology, Harmon Kardon, Heated Front Seats, Driver Assistance...
      03-01-2013, 07:57 PM   #2832
dos1973
Drives: F30
Cool stuff, will try this
      03-02-2013, 02:06 PM   #2833
raj10800
Kon,
BMW Live is not working. It says internal error. Any suggestions/solutions. I VO coded 614 and 6AL.
Regards,
Rajesh
      03-02-2013, 03:11 PM   #2834
JonoNZ
New Zealand
Drives: F30 335i M Sport, M Perf
Kon,
Regards,
Rajesh
Same problem here, it used to work. I'm wondering if BMW are doing some server-side checks to see if your car can use BMW Live/Online. Mine worked for the first couple of weeks then stopped.
F30 335i M-Sport with Estoril Blue II, M Performance Aero Kit, M Performance Exhaust, M Performance PPK, Adaptive Suspension, Variable Sport Steering, Revised NBT Pro Nav, Sunroof, 19" 403M, HUD, Rear Camera, DAB+, Comfort Access (20121250 Build, Delivered 25 January 2013)
      03-02-2013, 09:06 PM   #2835
manicottiK
Drives: 530i (2017 G30)
I have the software, a cable from One-Stop, and two computers (I first tried with Win8 using Ethernet via a USB dongle and then with Win7 with a built-in Ethernet jack). Neither computer seems to get a connection to my F30 (built in mid-January). ZGW_Search finds nothing and E-Sys won't enable the VIN connection option. The computers both appear to self-assign IP addresses in the 169 space.
Does anyone have any ideas to help get me started?
      03-02-2013, 09:41 PM   #2836
Yobyot
Yobyot's Avatar
56
Is the cable brand new? Has anyone ever used it to connect successfully?
Do you have all other adapters (WiFi, for example) turned off on the machine?
MY12 335i ZSL:
MY18 X3 30i:
      03-03-2013, 02:11 AM   #2837
lokito
lokito's Avatar
Drives: 335i ///M Sport
Also, try disabling your firewall, if you have one installed. I had a similar problem and disabling the firewall fixed it...
2013 335i ///M-Sport |6MT|Mineral Grey|DHP|PDC|HK|
      03-03-2013, 04:05 AM   #2838
raj10800
All the effort to code 6AL and it does ot work. Is the service down? Any workaround?
