Extreme Power House
      03-03-2013, 11:24 AM   #2839
manicottiK
Drives: 530i (2017 G30)
I came back out to the car this morning, tried again, and got a connection. I have no explanation. I know that the cable was on securely yesterday because I need a pliers to get enough grip to remove it.
I'm sitting in the car now grabbing some documentation (which I apparently deleted yesterday). As soon as I grab everything, I'll switch off wifi, reconnect the enet cable, and start making my backups. Wish me luck.
      03-03-2013, 04:40 PM   #2840
manicottiK
Coding went fairly well and I was able to make the key changes that I wanted.
However, I am having trouble changing certain values. I want to make the cameras and DVD work at any speed. (This is for demo purposes, not actual use. I did DVD in motion for my Audi and never used it after proving that it worked.) When I try to change the numeric values, it seems to not "stick." Does anyone have any ideas?
Finally, my warm feet want to offer special thanks to Shawn to for letting me know that the engine and the climate system could be running while I'm coding!
      03-03-2013, 05:29 PM   #2841
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
When you change a Werte Value, you change just that, not the Drop-down box too, and immediately afterwards you must hit the icon in the upper right corner of the lower window that looks like a door with a yellow arrow pointing left, or hit Ctrl-Enter, to save the Werte Value. Then use the Floppy Disc icon on the toolbar to save all FDL changes.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      03-03-2013, 10:11 PM   #2842
legaleye3000
Drives: 2014 328i; 2015 X3
Its been a little while since visiting this thread... Anyone figure out enabling Office and internet features through phone's bluetooth? I have the menu options showing up but haven't got any further... Office only shows my contacts, no sms or anything. When trying to access internet, it says please activate data connection (even though the option is checked when pairing the phone).
Thanks!
      03-04-2013, 12:59 AM   #2843
shawnsheridan
48.3 vs. 49.0 PSdZData CAFD Changes - E-Sys 3.18.4 End of Life
FYI. The difference from 48.3 to 49.0 for the CAFD folder is 56 added and none removed:
Left base folder: C:\48.3_PSdZData
Right base folder: C:\49.0_PSdZData
Left Orphan Files (0)
Right Orphan Files (56)
cafd_0000000f.caf.005_024_225
cafd_000000b5.caf.010_004_004
cafd_000000b6.caf.010_004_004
cafd_000000c9.caf.003_000_000
cafd_000000f9.caf.007_003_031
cafd_000000f9.caf.007_005_003
cafd_000000f9.caf.007_006_008
cafd_00000a07.caf.002_013_002
cafd_00000a48.caf.000_004_009
cafd_00000b0a.caf.000_024_001
cafd_00000b52.caf.002_010_000
cafd_00000c18.caf.013_064_004
cafd_00000ce2.caf.003_001_017
cafd_00000ddd.caf.003_001_017
cafd_00000ded.caf.002_002_007
cafd_00000e69.caf.002_002_004
cafd_00000e69.caf.002_002_005
cafd_00000ed9.caf.002_000_008
cafd_00000fa2.caf.001_004_000
cafd_000001a7.caf.000_012_004
cafd_000007a1.caf.005_028_006
cafd_000007c3.caf.011_000_000
cafd_000007c8.caf.006_008_004
cafd_000007c8.caf.006_009_004
cafd_000008a6.caf.001_005_000
cafd_0000012f.caf.012_006_021
cafd_0000012f.caf.012_006_022
cafd_00000014.caf.004_055_014
cafd_00000014.caf.004_055_214
cafd_00000018.caf.004_010_001
cafd_0000029b.caf.000_008_001
cafd_00000044.caf.008_005_000
cafd_0000067b.caf.002_003_142
cafd_00000069.caf.009_001_004
cafd_00000069.caf.009_001_006
cafd_0000090a.caf.004_001_017
cafd_00000092.caf.004_002_027
cafd_0000106d.caf.012_006_016
cafd_0000124f.caf.000_004_004
cafd_0000157f.caf.008_000_001
cafd_00000163.caf.007_001_009
cafd_00000163.caf.007_001_031
cafd_00000223.caf.013_008_004
cafd_00000286.caf.001_006_000
cafd_00000552.caf.001_029_001
cafd_00000553.caf.001_038_001
cafd_00000694.caf.003_003_042
cafd_00000721.caf.003_006_000
cafd_00000760.caf.006_000_051
cafd_00000794.caf.004_228_005
cafd_00000893.caf.006_050_012
cafd_00000896.caf.006_023_003
cafd_00000912.caf.003_007_009
cafd_00000913.caf.003_004_003
cafd_00001016.caf.001_003_000
cafd_00001060.caf.003_001_003
ISTA/P 2.49.0 Fxx Integration Levels
F001-13-03-501
F010-13-03-501
F020-13-03-501
F025-13-03-501
NOTE: The 49.0 PSdZData release marks the end-of-life for E-Sys 3.18.4. The changes made to the F20 PSdZData in 48.3 are now across the board in the 49.0 PSdZData. Old Patch / Tokens will no longer work for any chassis.
To use the 49.0 PSdZData, you must upgrade.
      03-04-2013, 02:03 AM   #2844
AntBabeee
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
F001-13-03-501
F010-13-03-501
F020-13-03-501
F025-13-03-501
Any help on the reverse light error check coding?
F30 BMW 335i M-Sport: Estoril Blue II, 19" Rims, Sports Auto, Premium, Technology, Harmon Kardon, Heated Front Seats, Driver Assistance...
      03-04-2013, 02:51 AM   #2845
raj10800
Drives: F30 320D sports Plus
F001-13-03-501
F010-13-03-501
F020-13-03-501
F025-13-03-501
Is this applicable to F30? I am using 3.22 plus 48.3 with the code sent to me by Andy just 3 days ago!
      03-04-2013, 04:00 AM   #2846
AntBabeee
do you mind sharing me the code? I installed the 3.22 but had to go back to 3.18 didnt have the code away est file.
      03-04-2013, 04:26 AM   #2847
raj10800
you have to contact Andy and he will make you a code. see Shawn's fiest post - detauls are there
      03-04-2013, 07:48 AM   #2848
shawnsheridan
Sorry, I have no idea on that.
      03-04-2013, 07:49 AM   #2849
shawnsheridan
If you have working 3.22.5 and 48.3, you do not need to upgrade again.
      03-04-2013, 08:43 AM   #2850
avgor123
avgor123's Avatar
Russian Federation
Drives: F30 320D Sport
How do i code it so that my car doesn't check for error in the reverse lights? I put in error free LED reverse light but it flickers when i turn on car and randomly while driving.
Another member told me its the car constantly checking bulbs so it flicks when it check. Said it's possible to code it so it doesn't check.
Is there an option to just code the reverse check only or if code the check off then its for all lights in car?
I think you can try this:
REM>3061>RFS_L_IS_LED
REM>3061>RFS_R_IS_LED
set to active
or
REM>3061>RFS_L_KALTUEBERWACHUNG
REM>3061>RFS_L_WARMUEBERWACHUNG
REM>3061>RFS_R_KALTUEBERWACHUNG
REM>3061>RFS_R_WARMUEBERWACHUNG
set to nicht_activ
      03-04-2013, 09:50 AM   #2851
ykau
Drives: F30 320I
woah@@ . That's was fast! I just got my hand dirty on 48.3 only a few weeks back.
hi bro shawn, can pass me the link for the orphan files and do I just copy into the same folders as 48.3? Thanks bro.
F001-13-03-501
F010-13-03-501
F020-13-03-501
F025-13-03-501
      03-04-2013, 10:35 AM   #2852
legaleye3000
Just wondering... Why would someone need the new version of the software and/or the psdzdata if they have a 2012 F30? Or is it only for newer builds...? Thanks.
      03-04-2013, 01:46 PM   #2853
AntBabeee
set to active
or
set to nicht_activ
THank You i will give that a try. I saw some stuff similar to that online but it wasnt for the f30. but it did come in that type of ending for each code. not an experience coder so didnt want to mess around.
      03-04-2013, 04:23 PM   #2854
Morrisadam
Drives: BMW Z4 sDrive35i
Hello everyone again!
I have an issue I don't know if it can be solved by coding or more likely by programming.
My Driver side seats are moving forward when I push it back words and the same opposite way when I'm tryin to lower it (goes up)
And my moon roof is nut functioning at all no matter how I try to press the button.
Does anybody know anything about the programming or where should I try to find solution for it?
(Its an F13 with panoramic moon roof and comfort seats)
Thx!
      03-04-2013, 09:52 PM   #2855
DXL XLR8
Drives: F30
this a longshot, but is there anyone close to the Omaha, NE area that is able to code my car for $50. I need to remove the drl and parking light error and well as some other mods.
      03-04-2013, 09:59 PM   #2856
kon
Singapore
Drives: F30 316i
Kon,
BMW Live is not working. It says internal error. Any suggestions/solutions. I VO coded 614 and 6AL.
Regards,
Rajesh
some additional details would be helpful.... e.g. internal error, where is this message? When you try to code and the error pop out in eSys, or you coded everything and you see the internal error on idrive?
Some screenshot would be helpful
      03-04-2013, 10:01 PM   #2857
kon
Singapore
Drives: F30 316i
And after so many months... from 48.1 until now 49.0... I'm still waiting for my dealer to let my car in for re-coding
      03-04-2013, 10:53 PM   #2858
JonoNZ
New Zealand
20
Drives: F30 335i M Sport, M Perf
I have the same issue, see my thread here, with screenshot: http://www.f30post.com/forums/showthread.php?t=809851
Everything codes ok, just an error when going into BMW Live/Online. It attempts to open for about a minute, then comes up the error in the picture. Internet browsing works fine so I know the tethering is working ok.
F30 335i M-Sport with Estoril Blue II, M Performance Aero Kit, M Performance Exhaust, M Performance PPK, Adaptive Suspension, Variable Sport Steering, Revised NBT Pro Nav, Sunroof, 19" 403M, HUD, Rear Camera, DAB+, Comfort Access (20121250 Build, Delivered 25 January 2013)
      03-04-2013, 11:09 PM   #2859
raj10800
Kon,
I coded 614, 6AL fine into the car. The Internet browser works fine. When I load BMW Live it tries to load and then gives a nessage sayibg "Internal Error". See this post
http://www.f30post.com/forums/showpo...98&postcount=2
I get the same error.
Regards,
Rajesh
      03-04-2013, 11:41 PM   #2860
kon
Singapore
Drives: F30 316i
Kon,
Regards,
Rajesh
could you also share your vin#?
