Vorsteiner
      03-31-2013, 04:03 AM   #3103
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Originally Posted by ykau View Post
hi Shawn & guys,
Any idea from HU_CIC, how to turn off the control display by default? And turning on the GPS for F10? thanks
I am not sure I understand. You want your CID screen to be off by default?
What do you mean by enabling GPS? You mean Navigation?
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      03-31-2013, 03:02 PM   #3104
daveh85
Drives: 335d
Will this work on the F31?
Originally Posted by shawnsheridan View Post
So, its $1,850 with new parts.
But now I am also in the middle of a 4U1 Ceramic Controls retrofit, and I already have the Ceramic Radio and AC Knobs, and the iDrive Controller, but now I will need to buy and replace my gear shift a second time with one that is both 2TB and 4U1, or just buy the ceramic face plate for the one I have.
But, I think the cermaic is worth it, and it will look damn good with my new European 6WB Instrument Cluster that just showed up...
Attachment 838948
Attachment 838949
      03-31-2013, 03:08 PM   #3105
shawnsheridan
Will what work?
      03-31-2013, 03:37 PM   #3106
daveh85
Drives: 335d
Will what work?
The European 6WB Instrument Cluster. I love the look.
      03-31-2013, 03:39 PM   #3107
shawnsheridan
Not in F30. It is for F10, F07, and F01.
      03-31-2013, 06:54 PM   #3108
Fluffy bastard
Fluffy bastard's Avatar
Russian Federation
Drives: Pony
Send a message via ICQ to Fluffy bastard Send a message via Skype™ to Fluffy bastard
You forgot about f06/f12/f13
Fluffy Russian СaT
      03-31-2013, 08:41 PM   #3109
ykau
Drives: F30 320I
hi shawn , my intention was because to prolong the CIC screen lifespan. yes bro, wat i meant was to enable the navigation. thanks (-:
      03-31-2013, 09:45 PM   #3110
kon
Singapore
Drives: F30 316i
What lifespan? your screen is running 24x7 a days? I thought most of us only have it running a few hour a day max...
Prof Navigation? If OEM doesn't have it, you're probably looking at retrofitting the entire HU_CIC, i-drive controller (lack the additional buttons for Nav), and screen (if it doesn't already come with the 8.8" screen)... good idea to go straight to NBT!
      03-31-2013, 10:31 PM   #3111
shawnsheridan
You are correct...I forgot about the 6 Series too. Thanks.
      03-31-2013, 10:33 PM   #3112
shawnsheridan
Plus adding all the FSC Codes and Maps.
      03-31-2013, 11:08 PM   #3113
ykau
Drives: F30 320I
what's wrong! i'm driving it for 30years...
      04-01-2013, 11:29 PM   #3114
steve@codemybimmer
steve@codemybimmer's Avatar
Drives: 2016 M235i xDrive Cabriolet
I assume that in 10 years from now, you're going to be driving the remainder of the 30 years in Malaysia or Africa or wherever the car gets exported to
      04-02-2013, 12:28 AM   #3115
Gt5422md
Gt5422md's Avatar
Drives: 2013 335xi Sedan
File Locations?
Hi, new user here. Would appreciate it greatly if somebody would PM me where I can get the required files, thanks!
      04-02-2013, 09:12 AM   #3116
martinf79
martinf79's Avatar
78
Drives: F30 335i M Sport
Hi Guys ... have been out of the loop on the coding for a while. Quick question... I programmed the "M Performance" logo on the cluster and HUD display a few months ago, but recently read (in anotehr thread) that someone had also programmed his Nav to display the "M Performance" logo.
Based on everything I had read a few months back, this wasn't possible. Has this since changed? Would appreciate any insight anyone could share. Thanks.
2013 335i ///M-Sport | + 2015 X3 28i xLine
      04-02-2013, 12:04 PM   #3117
michaelsoft
Hi everybody, please PM where can get the software for coding F30 with newer coding level (i-level), Thank you!!
      04-02-2013, 05:57 PM   #3118
shawnsheridan
PM's sent.
      04-03-2013, 01:00 PM   #3119
steve@codemybimmer
Hey Shawn, what's the difference between 49.1 lite and 49.1? Will I still be able to code all the ECU's with 49.1 coming from 48.1? I already requested for my token and patch and I'm upgrading to 3.22.
      04-03-2013, 04:00 PM   #3120
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
The "lite" version has the ECU flash files removed as they account for the majority of the size of the dataset
You can code do everything with the "lite" version except flash (reprogram) the ECU software.
      04-03-2013, 05:24 PM   #3121
steve@codemybimmer
Thanks Frogman.
Can I still VO code an ECU with the lite version? By reprogramming the ECU software, does that mean updating it to the latest version?
      04-03-2013, 06:19 PM   #3122
deb10042
Drives: F20
cheats for F20
Hi!
I am new to all that coding stuff...read a lot in this thread and I am impressed by all the knowledge of you guys!
Is it possible to have a complete list of all modifications that are proved as working for a completely new F20 model?
Thanks!
      04-03-2013, 06:24 PM   #3123
Frogman
Frogman's Avatar
Thanks Frogman.
Yes, you can still VO code with the lite version.
ECU programming/flashing is what the dealer does when they update the software. I have not seen any procedures for doing that here, but I've seen Shawn mention it a few times, so I think some people are doing it. It's not something I would want to play with, especially with a car that's still under warranty. I think the .swfl files are being used by people doing retrofits.
I would think that flashing an ECU would be a much more risky operation than normal coding and I don't know what BMW service would do if the car software level didn't match their records.
BTW: The full 49.1 dataset is 17.6GB, 13.6GB of which are the .swfl files.
      04-03-2013, 07:29 PM   #3124
steve@codemybimmer
I would think that flashing an ECU would be much a more risky operation than normal coding and I don't know what BMW service would do if the car software level didn't match their records.
Thanks Frogman! I'll just get the lite version then. It sure beats downloading 17GB since we have limited bandwidth here in Canada.
