Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
Vorsteiner
      04-03-2013, 11:13 PM   #3125
Chris@codemybimmer
Chris@codemybimmer's Avatar
Drives: AW F30 328i Xdrive
if i got a token for 48.1 do i need a new otken for 49.1?
      04-03-2013, 11:56 PM   #3126
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
No, the token is tied to E-Sys, not the data set version.
      04-04-2013, 01:41 AM   #3127
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Originally Posted by Aritaurus View Post
Thanks Frogman.
Can I still VO code an ECU with the lite version? By reprogramming the ECU software, does that mean updating it to the latest version?
Originally Posted by Frogman View Post
Yes, you can still VO code with the lite version.
ECU programming/flashing is what the dealer does when they update the software. I have not seen any procedures for doing that here, but I've seen Shawn mention it a few times, so I think some people are doing it. It's not something I would want to play with, especially with a car that's still under warranty. I think the .swfl files are being used by people doing retrofits.
I would think that flashing an ECU would be much a more risky operation than normal coding and I don't know what BMW service would do if the car software level didn't match their records.
BTW: The full 49.1 dataset is 17.6GB, 13.6GB of which are the .swfl files.
As Frogman wrote, flashing an ECU is risky. If something goes wrong, the ECU can be bricked, and you may have some trouble getting a replacement under warranty.
The vast majority of people need only the Lite Version.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      04-04-2013, 01:43 AM   #3128
shawnsheridan
True, the EST Token is tied to the E-Sys version; however, a move from 48.1 to 49.1, will necessitate newer E-Sys, which in turn will necessitate a new EST Token and Patch.
      04-04-2013, 02:16 AM   #3129
steve@codemybimmer
steve@codemybimmer's Avatar
Drives: 2016 M235i xDrive Cabriolet
I think the Lite version is more than enough for me. I was just worried that I can't code VO's or read certain ECU's with the lite version; now that you guys confirmed that I can code FDLs and VO's I'm good!
By the way, I went to a dealer two weeks ago and they mentioned that there's another recall on the F30 (Not the FEM recall). They never explained to me what it was but if it requires a software update, I might as well just get the EST Token and patch just in case.
Would it be safe to say that if the dealer updates my car next week, I should be able to use 49.1 to reapply all the coding to my car? Also, do you think it's necessary to just VO code all my ECU's to default before taking it in for service? The M Performance logo on the instrument cluster is probably a big clue that I coded the car.
      04-04-2013, 02:33 AM   #3130
shawnsheridan
For me, I would just change the ///M Logo back, but you can VO Code all ECU's you coded to reset them.
49.2 was pushed to dealers on 3/29, but you should be all right with 49.1.
49.2 has only one new CAFD:
cafd_000000f9.caf.007_006_009
If you need it, you can most likely get away with just adding it to your existing 49.1 CAFD library.
      04-04-2013, 05:27 PM   #3131
F30_Performance
F30_Performance's Avatar
Switzerland
Drives: F30 335i M Sport
Can i code on f30 when i put in the reverse gear that the rear camera start automaticly? Now i must select it everytime.
      04-04-2013, 05:48 PM   #3132
Frogman
Frogman's Avatar
Mine automatically turns on when I put the car in reverse, no coding was needed.
I wonder if it's a regional thing?
      04-04-2013, 06:40 PM   #3133
F30_Performance
Switzerland
Mine dont dont do this for me
Any helpers here for coding the rear camer automatically???
      04-04-2013, 09:21 PM   #3134
kon
Singapore
Drives: F30 316i
It should activate automatically, if the reverse cam came originally with the car, time to visit your dealer rather than programming it yourself...
      04-04-2013, 10:39 PM   #3135
INDOOS
Drives: f30 red/red 335i msport
ive been looking far and wide but i cant find the damn psdzdata files can anyone send me any location where i can find a working download please - thanks again P.S Im using e-sys version 3.18 is that ok?
      04-04-2013, 11:12 PM   #3136
shawnsheridan
Maybe, and maybe not. What version of ISTA/P is on your car?
      04-04-2013, 11:34 PM   #3137
INDOOS
Got the car in December of 12 custom ordered built in sept. never have been into the dealership yet. Idk
      04-04-2013, 11:40 PM   #3138
shawnsheridan
Hmmm...it's hard to say then, as you could have 48.0, 48.1, 48.2, or 48.3, and E-Sys 3.18.4 for F30 is only good up through 48.2.
Do you have any version of PSdZData now to go with your E-Sys 3.18.4? If so, what is your I-Level:
http://www.f30post.com/forums/showpo...postcount=1403
      04-04-2013, 11:46 PM   #3139
INDOOS
I don't have any psdzdata files, if anything could you possibly give me an update e-sys and psdzdata files?
      04-04-2013, 11:49 PM   #3140
shawnsheridan
I can, but the updated version requires you buy a new Patch / Token, while the older one does not, so I was trying to help you avoid that.
Your call, old or new?
      04-04-2013, 11:51 PM   #3141
INDOOS
Screw it lets test it out tomorrow on the older psdzdata files. Old it is for now, btw how much is the token? Etc
      04-04-2013, 11:54 PM   #3142
shawnsheridan
$65, good for 1 year from date of issue.
48.2 it is then. PM sent.
      04-04-2013, 11:56 PM   #3143
INDOOS
Your the man, btw are you in the northeast? Exotic motor world a leasing company whom for which I work for are having a meet coming Sunday for f30/f10 and e9x cars.
      04-05-2013, 12:06 AM   #3144
shawnsheridan
      04-05-2013, 12:11 AM   #3145
INDOOS
iPhone fail lol
      04-05-2013, 12:14 AM   #3146
kromix
kromix's Avatar
Drives: '16 340i AW MSport
2016 340i (F30)  [0.00]
Hey Shawn,
For someone just starting getting into coding are the guides on the front page still relevant? Should I even look through those PDFs? I'm an IT Professional so I should figure this out, just want to know what documentation is good to start reading?
Thanks.
