      04-06-2013, 05:25 PM   #3169
Elliotdds
Drives: 2013 M5
Hey -
Heading over from the m5 board - I did buy my enet cable from a member listed on this board - but I do not have the required software needed to make this work.
Is there someone here who would be willing to email me exactly what I need?
Thanks so much
Regards
      04-06-2013, 07:55 PM   #3170
yuriy_b
yuriy_b's Avatar
Drives: 2013 BMW 328i
Originally Posted by shawnsheridan View Post
You cannot receive PM's with only one Post. Either increase your Post count, or put up an email address.
nevermind, I read most of the thread and I used BMW_E-Sys_3.18.4 and PSdZData-48.1 for coding.
in couple hours I coded:
- Video in Motion
- Turned the Seatbelt Gong off
- Remove disclaimer
- Tire pressure + temperature in TPMS
- Mirrors close by pressing doorknob (comfort access only)
- Mirrors open automatically when closed with comfort access
- Add HP/LB_FT/KGM/etc to sports display
- Closes windows/roof with keyfob
- Turned left and right front sidemarkers off
etc...
Thanks for all your posts, you doing a really great job.
      04-06-2013, 08:22 PM   #3171
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Originally Posted by Elliotdds View Post
Hey -
Thanks so much
Regards
PM sent.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      04-07-2013, 03:04 PM   #3172
Elliotdds
Drives: 2013 M5
GREAT!
Thanks so much - I will be bringing my netbook from work - total apple geek here at home! - I will use the windows machine to start this, this week.
It does seem daunting at first......
      04-08-2013, 02:09 AM   #3173
eclipsisNA
Drives: 2013 Estoril 328i M Sport
2014 BMW 428i  [3.88]
Can US spec mirrors be programmed to fold on lock and unfold on unlock with the FOB, in cars that don't have Comfort Access?
      04-08-2013, 03:01 AM   #3174
jzwjk
Drives: F18
So good, I can Do it by myself.
Thank you so much!
      04-08-2013, 07:13 AM   #3175
shawnsheridan
Yes, if you have Power Fold Mirrors now, you can code them to work from the Fob.
      04-08-2013, 07:51 AM   #3176
eclipsisNA
Thanks Shawn, do you happen to know the Function Value in the cheat sheet? The only entry I see seems to apply only to Comfort Access cars.
      04-08-2013, 09:24 AM   #3177
shawnsheridan
FEM_BODY => KOMFORTSCHLIESSUNG_FB = aktiv is Fob
FEM_BODY => KOMFORTSCHLIESSUNG_PA = aktiv is Comfort Access
Both require
FEM_BODY => ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = aktiv
FEM_BODY => ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN = aktiv
      04-08-2013, 09:43 AM   #3178
kromix
kromix's Avatar
Drives: '16 340i AW MSport
2016 340i (F30)  [0.00]
Placeholder of things I want to code when my '13 F30 328i arrives in May 2013.
Coders, please let me know if anything on my ToDo Coding list is not possible, on a standard f30 no options other than Lighting Package:
- Disable AutoStopStart
- Key FOB roll up all mirrors
- Key FOB fold/unfold side mirrors
- Lighting: Corner Delete (sidemarkers)
- Turn Seatbelt Gong OFF
- Display Tire Pressure+Temperature in iDrive
- Window rollup safety disabled (while door is opening)
- Default Sport Mode
- Sport Display in HU_CIC
Not sure about this one:
- Code 6NH to 6NK.
I have the standard 6NH bluetooth only(no nav), I read you can code it to 6NK to be able to play music/enable cover art, is this correct? Or does this require a specific hardware other then the standard bluetooth?
      04-08-2013, 10:58 AM   #3179
minjian
Drives: e90
E - sys how to download?
      04-08-2013, 04:15 PM   #3180
crazydiamond
Drives: 2008 335i Sedan
Question re: Recoding of 6NH for Bluetooth streaming and Apple Cable
Hi,
I recently ordered a 2013 F30 (335i) with 6NH, 688 (HK Upgrade) and No Nav.
It appears that 6NH will not let me use the white iphone 5 cable or do streaming BT without a Y-cable and/or BT adapter.
I've read some posts here from folks who were able to recode 6NH to enable BT streaming audio and use of the white apple cable.
Just wanted to check if I will be able to do the same with my config (6NH, No Nav, Unknown Combox) or should i just add 6NL to the order while I still have time and be done with it.
      04-08-2013, 08:20 PM   #3181
shawnsheridan
Well, I'd tell you, but with only 1 Post, you can not receive PM's yet, so either increase your post count, or put up an email address.
      04-08-2013, 08:21 PM   #3182
shawnsheridan
Originally Posted by crazydiamond View Post
Hi,
I think this is only possible with Combox, and the only way to have the Combox is if you had 609 Navigation.
      04-08-2013, 08:39 PM   #3183
crazydiamond
Thanks Shawn. I'll just add 6NL to my order.
      04-08-2013, 08:46 PM   #3184
kromix
kromix's Avatar
That answers my question, that sucks, I was hoping to be able to code bluetooth audio streaming
      04-08-2013, 09:03 PM   #3185
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
That was true for 2012 models, but the 2013 F30's can be ordered with "BMW Assist with enhanced Bluetooth and USB" without ordering navigation.
Hi,
The enhanced Bluetooth that you get with BMW Assist gives you A2DP streaming and second phone pairing and it lets you use the white apple cable, not the Y-cable.
I'd verify this with your CA ASAP.
      04-08-2013, 09:18 PM   #3186
kromix
kromix's Avatar
So what's up with this post?
"Or you could save the money and have it coded if you have the 6NH option on your Vehicle Order. It was coded for free for me by a kind fellow BB'er and it saved me ~1100 dollars (here in Canada Enhanced Bluetooth and USB has to be bundled with BMW assist for a total cost of 1100 I believe). Check your VO and skip out on the option if you can, it's a nice way to save some money." Posted by hrosenberg33.
http://www.f30post.com/forums/showthread.php?t=805746 Original thread.
      04-08-2013, 09:27 PM   #3187
shawnsheridan
I am pretty sure if you order 6NL, it comes with a Combox, as that is where the Enhanced BT and USB originates, so what I wrote is correct in that a Combox is needed. You can of course order 6NL from the factory without 609 Navigation, but the OP was starting already with 6NH.
6NH + No 609 = No Combox = No Codeable A2DP
6NH + 609 = Combox = Codeable A2DP
6NK + No 609 = Combox = A2DP from Factory
6NL + No 609 = Combox = A2DP from Factory
And a car with with 6NH and 609 would be able to be coded for 6NK which supports A2DP, whereas the same car with only 6NH and No 609 can not be.
      04-08-2013, 09:31 PM   #3188
kromix
kromix's Avatar
I am pretty sure if you order 6NL, it comes with a Combox, as that is where the Enhanced BT and USB origiinates, so what I wrote is correct.
Makes sense, I wish I could at least use a White apple cable instead of Y. It's a 40k car! Oh well, I'll just use a 32GB USB stick instead.
      04-08-2013, 09:37 PM   #3189
shawnsheridan
My guess is he has 6NH + 609 Navigation.
      04-09-2013, 12:36 AM   #3190
crazydiamond
I checked with the CA. He says the Y cable is a PITA so added 6NL to the build.
So much for not letting BMW nickel and dime me for something that should have been standard in the first place :-)
