Vorsteiner
      05-03-2013, 12:32 AM   #3455
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
Originally Posted by kromix View Post
Getting my coding list down, confused about the differences between these Key FOB options:
ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN and ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN along with 3053 KOMFORTSCHLIESSUNG_FB are needed to code folding mirrors. KOMFORT_SCHLIESSEN changes the activation delay after pressing the fob or CA.
CAS/3020/ASP_BEIKLAPPEN_B_KOMFORTSCHL IESSEN does not apply to F30's. F30's don't have CAS modules, its all in FEM_BODY.
HU CIC/3000/Macro_fds enables sport mode configuration (drive train/suspension change) in non-sports steering/non-VSS equipped cars where it's not enabled by default.
ICMQL/3000/LCMKOD_B_SPORTLENKUNG enables sport+ mode. I think this is the same as sport mode, but also turns off DTC/DSC.
      05-03-2013, 12:49 AM   #3456
kromix
kromix's Avatar
Drives: '16 340i AW MSport
2016 340i (F30)  [0.00]
Thanks Frogman!
Need some more help,
So when I check my version I am at F020-13-03-503.
I get an error when trying to read FEM_BODY, and I don't even see HU_CIC on the list?
I'm using ESYS 3.22.5 with 49.1_psdzdata, what do I need to do to be able to code FEM_BODY and see HU_CIC on the list?
I selected F020-13-03-502 from the list when connecting, and coded under BKOMBI the BMW_LOGO M performance from AG to mpm, doesn't seem to have worked, and also ACSM SeatBeltReminder_SBR_beifahrer disabled passenger reminder, but haven't tested yet no passenger to sit there,
Did it do anything wrong or mess anything up since I'm on -503 and selected 502?
      05-03-2013, 12:55 AM   #3457
Frogman
Frogman's Avatar
Originally Posted by 10nelyboi View Post
Thanks for the clarification.
If we didnt write a new FA to the car but tell E-sys to use FA files on the disk instead, doesn't this mean that the car now is running on 2 FA files? 1 original from the deal and 1 from our coding session, if so How does the car know which FA files to run from? or Am i going way off topic here
The car will only ever have one FA. We changed the FA in E-sys only and VO coded the ECU's to that temporary FA.
If we knew every single variable that changes when switching from 6NH to 6NK, we could have just manually changed them without changing the FA. We don't, so the easiest and safest way to get the settings changed is to change the FA (temporarily) and VO code HU_CIC and CMB_MEDIA.
As Kon says, the ECU's run from the FDL values, so there is no conflict.
Let says if i was to VO code and a new FA to the car (add 614, 615 , 6AL), and when i take it in for an update, the VO won't match their server so what would happen in this case?
The differences in the FA may or may not cause dealer programming to fail. So the safest thing to do is to revert the FA to the original before taking it in.
If the FA matches, FDL coding changes you made will not cause programming to fail because after uploading new firmware, they just VO the modules back to their FDL defaults anyway. That will simply undo any of the FDL changes you made. You can reapply them when you get the car back.
I'd like to know if you FA was actually written when we VO coded your ECUs.
Can you connect your laptop to the car and re-read the FA? Then see if 6NK is there in the SALAPA elements.
I don't think it will be there (it should still be 6NH), but I guess it's possible that VO coding with the updated VO also forced the FA to get written.
We didn't check that when we coded your car; we did everything in one "session".
Please let us know what's there.
      05-03-2013, 01:01 AM   #3458
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by raj10800 View Post
Shawn, does this mean that all the VO coding I have done like 6NK, 6AL, etc will need to be removed before giving the car to the dealer for software upgrade or will tye just overwrite everything as per the original VO?
With just the VO option code changes and the original Production Date, and no hardware changes, you should be alright to leave it alone for dealer programming.
      05-03-2013, 01:11 AM   #3459
shawnsheridan
Originally Posted by ramonE90-NL View Post
@shawnsheridan, it works again!! Now i can code again
The last thing i'm looking for is this http://www.7-forum.com/news/2011/1er...90078278-b.jpg
It should be in the eco menu. I can only see the car on the screen, not this graph
Check for these and set to aktiv:
HU_CIC / ECO_MODE
HU_CIC / EFF_DYN_SPORT_CID
KOMBI / VERBR_HISTORIE_ENABLE
KOMBI / CTR_HSTY_DISP_KI_APPL
      05-03-2013, 01:11 AM   #3460
Frogman
Frogman's Avatar
Thanks Frogman!
What is the name/number of the FEM_BODY CAFD that failed? It will be something like: cafd_00000794-XXX_XXX_XXX.
My guess is that you need 2.49.2. The easiest way to get it is to PM Shawn.
You won't see HU_CIC unless you have navigation. Without navi, your head unit is called HU_ENTRY. Do you have that?
If you don't have navi, you probably don't have the extended cluster, so changing BMW_LOGO will not have any affect. Is your instantaneous MPG gauge a physical needle, or an LCD image? If it's a needle, you don't have the extended cluster.
I can't tell from your note about the seat belt reminder, did that coding work?
      05-03-2013, 01:14 AM   #3461
10nelyboi
Drives: 2012 - 335I
I will do that this weekend, and let you know. I shouldn't need a token to do it right ?
      05-03-2013, 01:15 AM   #3462
Frogman
Frogman's Avatar
Right.
      05-03-2013, 08:48 AM   #3463
kromix
kromix's Avatar
How do you code either: Remember last setting or default sport mode ? So I don't have to change from Comfort to Sport everytime?
I can't seem to find it via search.
      05-03-2013, 09:30 AM   #3464
4.8 E70
Montenegro
-44
Drives: Alpina B7
Has anyone had the issue where they are unable to Read Code Data from HU_CIC ? I keep getting the 'CADF not found' message when I right click on the green file under HU_CIC folder. I was able to code everything else but the modifications that are in the HU_CIC module. Thanks !
      05-03-2013, 10:21 AM   #3465
Frogman
Frogman's Avatar
That's because no one has found a setting to do it yet.
      05-03-2013, 10:23 AM   #3466
kromix
kromix's Avatar
Ahh Crap I thought there was one? So I have to press Sport Mode everytime? Ugh!!!
      05-03-2013, 10:23 AM   #3467
Frogman
Frogman's Avatar
These kinds of errors occur because your car has newer software than the psdzdata you are using.
What is the I-step version on your car and what version of the psdzdata are you using?
      05-03-2013, 10:27 AM   #3468
Frogman
Frogman's Avatar
It could be worse; I think the UK cars always start in Eco-Pro mode.
      05-03-2013, 10:32 AM   #3469
4.8 E70
Montenegro
-44
Drives: Alpina B7
Ahh okay -PSdzdata is 49.1 and I'm not too sure of the I-Step version. It is a 4/2013 build. I assume I have to wait until the the new Psdz version is released ?
      05-03-2013, 10:48 AM   #3470
vithy
Drives: 2016 F30 328xi
Whats the setting for starting in Eco Pro Mode?
      05-03-2013, 10:50 AM   #3471
Frogman
Frogman's Avatar
2.49.2 has been out for a while and it looks like 2.49.3 just came out.
PM Shawn for it.
      05-03-2013, 10:55 AM   #3472
4.8 E70
Montenegro
-44
Drives: Alpina B7
PM Shawn for it.
Wow - Thanks so much for the info ! PMing him right now. Hopefully this fixes the problem.
      05-03-2013, 12:12 PM   #3473
shawnsheridan
Look for ICM => IcmKod_B_InitEco and set to verbaut.
      05-03-2013, 12:15 PM   #3474
Frogman
Frogman's Avatar
ICM / 3000 / IcmKod_B_InitEco
switch from nicht verbaut to verbaut.
Some people have stated that this keeps the Check Engine Light (CEL) on. I have not personalty tried this, so you're on your own here.
      05-03-2013, 01:36 PM   #3475
kromix
kromix's Avatar
Originally Posted by shawnsheridan View Post
Look for ICM => IcmKod_B_InitEco and set to aktiv.
So you can set Eco Pro Mode as the default start option, but can't make it default to Sport Mode?? Damn that sucks!
Oh and I know your busy Shawn, so thank you for all your efforts in helping the coding noobs in advance, but when you can check your PM's, I was requesting the newer data files so I can code on my version
Thanks!!
Check this out by the way, I got my booklet ready for coding!
      05-03-2013, 03:49 PM   #3476
demge01
demge01's Avatar
Drives: F30 320ed
Only EfficientDynamics (320ed) models start in ECO thank goodness it is possible to code start in comfort.
