      07-06-2012, 06:44 AM   #331
TonyS
Drives: F30 335i
Originally Posted by martinf79 View Post
Sorry - one more question. RE:
06) Copy the contents of the "C:\ESysData\psdzdata\swe" folder into the "C:\ESysData\SWE" folder.
Can I delete the files in "C:\ESysData\psdzdata\swe" once I move them. Files are about 15GB and running on an ultrabook (120GB SSD), so don't want to use up more space if I don't need to. Can you please let me know.
Also - can I actually run all of the folders off of an extneral drive as opposed to my C: drive?
As far as I know it needs those files in both places, which is a ridiculous waste of disk space.
From what others have said, if you are running Vista or Windows 7 you can set up a symbolic link to make Windows think that you have the files in C:\ESysData\SWE without having to make a duplicate copy.
Here's what I did (note that I haven't tested this on the car yet as I'm still waiting for it to be delivered but the program runs fine) :-
Delete the SWE folder under C:\ESysData (it should be empty).
Run a CMD prompt with administrator privileges.
Enter this at the prompt (without the quotes):
"mklink /d C:\ESysData\SWE C:\ESysData\psdzdata\swe"
You should get a message back that says:
"symbolic link created for C:\ESysData\SWE <<===>> C:\ESysData\psdzdata\swe"
Now Windows will think there's a folder C:\ESysData\SWE and it should work.
As always, try this at your own risk ;-)
      07-06-2012, 07:13 AM   #332
Silver F30
Silver F30's Avatar
Drives: F30 Sportline
@ martinf79 You should be able to run the files from an external harddrive provided that you point to where the files are in E-Sys under the options>settings and then there is a tab somewhere there that will let you specify where the files are. Sorry I don't have E-Sys up right now as I am at work right now.
      07-06-2012, 09:28 AM   #333
martinf79
martinf79's Avatar
62
Drives: F30 335i M Sport
Great - thanks. If I run it off of an external hard drive, space isn't an issue (I'll just leave the files in both places). I have the cable ... I have the program installed... now I just need a car!!!
2013 335i ///M-Sport | + 2015 X3 28i xLine
      07-06-2012, 10:16 AM   #334
TonyS
Drives: F30 335i
You and me both!
      07-06-2012, 10:17 AM   #335
Yobyot
Yobyot's Avatar
58
Drives: MY12 F30 ZSL
You and me both!
That makes three of us!
MY12 335i ZSL:
Produced: 2012-06-22; ED: 2012-07-19; Arrived in Jersey City: 2012-08-23; Redelivered: 2012-09-12
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29
      07-06-2012, 11:03 AM   #336
Silver F30
Silver F30's Avatar
I've been driving my 6 speed manual now since May 17th. I've already put 4K on it and primarily city driving. My average mpg is 30 no matter if I drive it in ECO-PRO or SPORT + mode. Not to rub it in or anything lol!
      07-07-2012, 02:49 AM   #337
mmanes1
mmanes1's Avatar
Drives: F30-320D SPORT
Hello,
i need a little bit Help... I cant Write the FF Value... Everytime after Safe its 00?
What must i doo to write the FF Wert for example in DVD in Motin...
thx a lot
marcell
      07-07-2012, 05:41 AM   #338
svache
svache's Avatar
Drives: 2012 F30 328i
Originally Posted by mmanes1 View Post
Hello,
thx a lot
marcell
Did you try it according the instructions in this pdf file: E-Sys - Getting Started Supplement - Part 2.pdf ?
F30 328i Luxury w/ Mojave metallic, beige interior (timeline)
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread
      07-07-2012, 05:41 AM   #339
svache
svache's Avatar
Btw, sorry that I was a bit away the last few days guys. It will probably be the same in the next week(s). Thing is, we recently bought a house and we're actually moving in these days so I'm quite occupied with that
If anyone needs to know anything. Just send me a PM and I will reply whenever I can
      07-07-2012, 12:06 PM   #340
levente
levente's Avatar
Drives: 2013 F30 M Sport
4 of us!
      07-08-2012, 11:32 AM   #341
gnuke
Drives: 2012 328
Another cable option for folks. Purchase this open end obd2 cable:
http://www.obd2cables.com/products/o...-end-10ft.html
Then cut an end off an ethernet patch cable and following the various schematics connect and solder the various cables together. I also used a 470ohm resistor and that seemed to work fine.
On another note the various coding options from the cheat sheet work well. Couldn't find the weather band code though. Anyone else try this one?
      07-08-2012, 02:21 PM   #342
Frogman
Frogman's Avatar
That's the same cable I got from amazon for $8.95 plus shipping. I also spliced 1/2 of a ground-shielded cat5 patch cable to it with a 510 ohm resistor and the appropriate ground connections; works great.
The ground-shied is a good idea as the laptop is not otherwise grounded to the car when you are connected to it. It's not absolutely necessary, but it is good idea.
      07-08-2012, 02:31 PM   #343
Frogman
Frogman's Avatar
On my car (April build 328i), RADIO_WEATHERBAND is in the 3002 AUDIO_TUNER_TRAFFIC section, not 3000 HMI. Maybe it's a typo in the cheat-sheet.
I haven't tried coding it, I just did a search for it.
      07-08-2012, 08:13 PM   #344
gnuke
Drives: 2012 328
Thanks frogman, that's exactly where it was and it totally worked. Now if I can get these rear fogs working.....
      07-09-2012, 08:33 AM   #345
Silver F30
Silver F30's Avatar
Hey guys! I built my cable with one from Amazon; http://www.amazon.com/gp/product/B00...ls_o01_s00_i00 With shipping it was 14.95. I then used a cat 6 cable that I cut in half. I am about to do another cable for one of the techs. When I get the cable in I will post a how-to with pics. I have about 20 bucks in each cable. STAY TUNED...............
      07-11-2012, 04:50 PM   #346
demge01
demge01's Avatar
Drives: F30 320ed
So just wondering if anbody has worked how to code the drive mode to remember the last setting - just as we now can with the ASS? I'm tending to leave mine in Sport mode for most of the time and it seems just as economical as Eco Pro.
Also if Sport+ can be enabled on non Sport models as I was wondering if this is the same as holding down the DSC for a few seconds (shows "Dynamic driving with DSC off on display screen" as opposed to pressing once which gives "Traction" mode)
      07-13-2012, 12:22 PM   #347
Rtseng78
Drives: 2012 328i sedan
Originally Posted by RASHID007 View Post
I was able to find one (cafd_00000794.caf.002_020_029) of the missing CAFD files (from another forum).
Now all I need is: cafd_000007A1_005_018_028
I coded everything I wanted so far. Check out the mirror folding and window up/down from key fob and from long holding the comfort access!
I"m having the same problem as you with the missing CAF files. I really wanted cafd_00000794.caf.002_020_029 since the set ASS default is in that. Do you think you could send me the file? It would be much appreciated.
      07-13-2012, 12:27 PM   #348
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
The full v.46.6 download links are here:
Good News:
This should be the updated v.46.6 PSDZdata:
http://ul.to/cjyr98h0/psdzdata.part01.exe
http://ul.to/t8oifb6f/psdzdata.part02.rar
http://ul.to/qlz3766u/psdzdata.part03.rar
http://ul.to/u71x6twc/psdzdata.part04.rar
http://ul.to/d2zurw2z/psdzdata.part05.rar
http://ul.to/cridpd03/psdzdata.part06.rar
http://ul.to/n16rry6h/psdzdata.part07.rar
http://ul.to/7fbn53nt/psdzdata.part08.rar
http://ul.to/luc2rz27/psdzdata.part09.rar
http://ul.to/74e844w7/psdzdata.part10.rar
http://ul.to/gfvjx6op/psdzdata.part11.rar
http://ul.to/sk6nbj1e/psdzdata.part12.rar
http://ul.to/2brsj8jk/psdzdata.part13.rar
http://ul.to/rsm5bdkp/psdzdata.part14.rar
http://ul.to/pigvcwxc/psdzdata.part15.rar
http://ul.to/95zmnec9/psdzdata.part16.rar
http://ul.to/804ey05r/psdzdata.part17.rar
http://ul.to/pwrdh094/psdzdata.part18.rar
Bad News:
These are on the German uploaded.to site that I can not access from the U.S.
Someone please grab this and put them on RapidShare, or even better, make a Torrent and SEED!
Edit: RapidShare Links Added:
http://rapidshare.com/files/17752485...ata.part01.exe
http://rapidshare.com/files/35223836...ata.part02.rar
http://rapidshare.com/files/33194538...ata.part03.rar
http://rapidshare.com/files/29945526...ata.part04.rar
http://rapidshare.com/files/33259470...ata.part05.rar
http://rapidshare.com/files/12851700...ata.part06.rar
http://rapidshare.com/files/63937664...ata.part07.rar
http://rapidshare.com/files/76748414...ata.part08.rar
http://rapidshare.com/files/40584653...ata.part09.rar
http://rapidshare.com/files/43607244...ata.part10.rar
http://rapidshare.com/files/49728960...ata.part11.rar
http://rapidshare.com/files/31364841...ata.part12.rar
http://rapidshare.com/files/26845889...ata.part13.rar
http://rapidshare.com/files/23853705...ata.part14.rar
http://rapidshare.com/files/12227656...ata.part15.rar
http://rapidshare.com/files/29941955...ata.part16.rar
http://rapidshare.com/files/54458236...ata.part17.rar
http://rapidshare.com/files/39839701...ata.part18.rar
      07-13-2012, 12:44 PM   #349
Rtseng78
Good News:
Bad News:
http://rapidshare.com/files/39839701...ata.part18.rar[/url]
Thanks, I'll eagerly await these getting fully upped to Rapidshare
      07-13-2012, 11:08 PM   #350
RASHID007
Drives: 2014 535d X-Drive
http://www.**************/showthread...ll=1#post32641
Try this.
      07-14-2012, 01:26 AM   #351
Puri1
Puri1's Avatar
Drives: F30 328i 2012
Left this message for Svache.. if any one else has a solution / similar problem, do tell:
Hi Svache..
I started coding today and followed all the instructions and it went beautifully.. thanks so much for this DIY.. it was really great...
We had a coding meet today with Bananachipz Maz and I and we went through this coding stuff..
Banana tried to change my values in FEM_BODY for all the mirror close, etc but it didn't go through.. kept popping error messages...
I cam home and tried it and did everything else apart from touching the FEM_BODY code and when I tried to do code the cafd in FEM_BODY the name had changed and is something like CAFD_FFFFFFFF_255_255_255 and obviously can't be found anywhere now.. very strange..
Is there anyway to get the default one back on.. All other modules and cafd files work fine except for this one..
I'm at a loss as to what to do, any help here would be much appreciated...
Thanks,
2012 F30 328i, Alpine White on Black, Luxury, Premium + Exec. Package...
      07-14-2012, 07:35 AM   #352
Jbrock22
Jbrock22's Avatar
105
Drives: 340i
Anyone in the Bucks County area code their car yet?
