Login
05-13-2013, 12:18 PM | #3631 | |
![]() ![]() 130
Rep 1,893
You need to upgrade to 3.22.5 and get the patch and a new token. PM shawn for links. |
05-13-2013, 12:45 PM | #3632 | |
![]() ![]() 9
Rep 126
Drives: E85 Z4 / F20 M135i
Could the token cause the problem ? |
05-13-2013, 12:50 PM | #3633 |
![]() ![]() ![]() ![]() 2843
Rep 15,604
Drives: 2016 650i GC M-Sport
Yes, if you are still using the old one, or if you did not install the new one properly.
![]() 2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc. |
05-13-2013, 12:51 PM | #3634 |
![]() ![]() 130
Rep 1,893
05-13-2013, 12:59 PM | #3635 |
![]() ![]() 9
Rep 126
I used the token i had from the 3.18 version, that should caused the problem then. However what i do not understand is why i can not code with 3.18 and 48.2 with valid token.
05-13-2013, 03:51 PM | #3636 |
Rep 7
Hello friends. I made a retrofit professional navigation CIC. What steps do I need to do to properly encode it in a car? What should I do? If I have the instrument panel is not extended, it would work fine CIC?
05-13-2013, 04:37 PM | #3638 |
![]() ![]() 130
Rep 1,893
05-14-2013, 06:40 AM | #3639 |
![]() ![]() ![]() 23
Rep 381
Can anyone please PM me:
cafd_00000794.caf.004_228_005 I am on 49.1 and this was removed in this release
05-14-2013, 06:50 AM | #3640 |
![]() ![]() 9
Rep 126
Hi,
I just read the current I Step : F20-13-03-503 I was able with Esys 3.18.4 and psdzdata 48.2 to read and alter the seatbelt warning but that is just all i can do. When trying to read other caf i got on error while trying to read them. Kris |
05-14-2013, 10:11 AM | #3641 |
![]() ![]() 130
Rep 1,893
You definitely need 2.49.2. That means you need a new token too and upgrading to 3.22.5 will also be a good idea. PM Shawn.
05-14-2013, 12:29 PM | #3642 |
Rep 15,604
PM sent.
05-14-2013, 12:32 PM | #3643 | |
Rep 15,604
PM sent.
05-14-2013, 12:37 PM | #3644 |
Rep 15,604
PM sent.
05-15-2013, 07:54 AM | #3645 |
![]() ![]() 3
Rep 167
hi,
i've got a cable to program... and i'm taking delivery of my car tomorrow. so who do i contact for the software and anything else i need? thanks received your PM... thanks shawn!
'13 F30 335xi • white/black • m-sport
05-15-2013, 09:52 AM | #3646 |
Rep 15,604
PM sent.
05-15-2013, 12:44 PM | #3647 |
Rep 7
Hi friends, I equip the auto option 609 (professional navigation), added to FA 609 option. Coded Kombi, FEM, and CIC. Everything works fine, but do not display the tracks of songs on the instrument panel when surfing songs on the steering wheel. The kombi panel I have a standard, not extended. There is a way out of this situation?
05-15-2013, 06:39 PM | #3648 |
![]() ![]() 41
Rep 278
I just noticed this today while coding. my istep 13-03-503.
I used to be able to roll the windows and moon roof down and up. After update i'm only able to roll the front windows, back passenger seat side are not opening or closing. Anyone else experienced this? Very strange.. |
05-16-2013, 12:36 AM | #3649 |
![]() ![]() 9
Rep 126
I have 3.22.5 with psdzdata 49.23 working now with new EST and pin. I can acces everything and programmed yesterday the HKFM 3010 SCH_TOEHKI to close trunk door with the button ond driver side. That all worked fine, but now my question is i want to disable start/stop but cant find it, I see no CAS module where the FA must be located in.
regards Kris |
05-16-2013, 01:28 AM | #3650 | |
![]() ![]() ![]() ![]() 12
Rep 467
05-16-2013, 02:09 AM | #3651 | |
![]() ![]() 9
Rep 126
![]() Update: just finished coding with succes. These things i coded so far: Start/stop disabled Closing windows when the door is closed or open Speed in bc DVD in motion Seatbelt warning disabled Trunk open and closing with interior button Now i gonna read some more to find other things i can code ![]() Last edited by MoneyFor; 05-16-2013 at 12:20 PM. |
