Extreme Power House
      05-17-2013, 05:01 PM   #3653
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Originally Posted by Aesculapius View Post
Shawn,
Would you mind sending me the file link as well?
I would have PM'd you directly, but I am still suffering through my NOOB stage.
And since you can't send or receive PM's, how do you propose I do that?
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      05-17-2013, 11:30 PM   #3654
Aesculapius
Drives: 2013 335xi Sport
Well, I feel sheepish. I thought the restriction was only on the sending and not receiving side.
I'll just sit in the corner and wait the 24 hours.
      05-18-2013, 01:24 AM   #3655
kon
Singapore
Drives: F30 316i
you could just post your email here
      05-18-2013, 11:48 AM   #3656
gemgroup
Drives: F30 328I
Can you PM me PSDZdata 49.3 rar password?
thank!
      05-18-2013, 12:03 PM   #3657
shawnsheridan
thank!
No, I can't. You have but one Post, so you can not receive PM's.
      05-18-2013, 12:15 PM   #3658
gemgroup
Drives: F30 328I
Thank you!I think I understand
      05-19-2013, 03:37 PM   #3659
legaleye3000
Drives: 2014 328i; 2015 X3
Office: just vo coded to 6nk . Wen I go into office it just shows address book. After vo coding, I checked to make sure SMS, calendar, etc., was enabled. I also unpaired and repaired my phone. Any other suggestions? Thanks.
      05-19-2013, 04:06 PM   #3660
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
Did you VO code both HU_CIC and CMB_MEDIA?
      05-19-2013, 04:52 PM   #3661
legaleye3000
Ya. After you change to 6nk and save FA, you then right click on hu_CIC and CMB_media and click code, correct? Thanks.
      05-19-2013, 06:08 PM   #3662
Frogman
Frogman's Avatar
Yep.
I think the things you are missing require BMW Apps (6NR). All I get with office (and I don't have BMW Apps) is SMS and (sometimes) e-mail.
      05-19-2013, 06:09 PM   #3663
legaleye3000
I was able to do it a couple of months ago without vo coding or any fsc code. I returned it to default before bringing my car into the dealer and forgot what I did.
      05-19-2013, 09:26 PM   #3664
08bmw128i
Drives: 2018 X5M
Anybody know the code to get the door handle lights to come on when the car is put into reverse on a 2013 x3?
      05-19-2013, 11:16 PM   #3665
shawnsheridan
Not sure on F25. For F10, it can't be coded.
Did you look for OVT_BEI_RUECKFAHRLICHT in FRM?
      05-20-2013, 12:48 AM   #3666
npgatech
npgatech's Avatar
Drives: 2012 BMW 335i
I have noticed that my adaptive headlights don't swivel left/right while driving since I had started coding. Does anyone know any parameters that I might have accidentally overwritten that disabled it? I did get an "Adaptive Headlight Failure" message when I was FDL coding but it went away.
Any parameters that I should check?
      05-20-2013, 01:39 AM   #3667
ykau
Drives: F30 320I
Hi Shawn , I hit an error msg yesterday. It prompted that FDL sign error with CL158 code. It happened with I was trying to save the code. I'm using 49.1 , any idea what has happened? thanks
      05-20-2013, 01:47 AM   #3668
shawnsheridan
Either you are trying to use the old .EST Token from 3.18.4, which you can not do, or you have a new updated Patch / Token, but have not installed it correctly, which would involve replacing the two .jar files (with PATCHED removed from their names) and setting E-Sys => Options => Settings => EST Tab => EST to point to the new .EST Token file.
      05-20-2013, 02:24 AM   #3669
ykau
Drives: F30 320I
Thanks bro . I will try again.
      05-20-2013, 07:18 AM   #3670
legaleye3000
Office: just vo coded to 6nk and vo coded hu_cic and cmb_media . When I go into office it just shows address book. After vo coding, I checked to make sure SMS, calendar, etc., was enabled. I also unpaired and repaired my phone (Nexus 4). Any other suggestions? Thanks.
      05-20-2013, 11:26 AM   #3671
Koer
Drives: 335i 2012 luxury line white
I cant seem to find that particular code on my f30 aswell, i can find the interior and exterior brightness codes and have modified them with success! Any ideas?
      05-20-2013, 11:33 AM   #3672
ad78
Yr1OfD1
ad78's Avatar
Drives: 2015 F34 M Sport
Send a message via AIM to ad78
Fembody 3070 OVT_BEI_RUECKFAHRLICHT set to aktiv.
on my F30 Feb 2013 build by default its aktiv.
      05-20-2013, 11:38 AM   #3673
shawnsheridan
What I-Level are you on? I think it was added in fairly recent ISTA version, so you may have older FEM BODY firmware.
      05-20-2013, 11:44 AM   #3674
Koer
Ohh shoot, its a 2012 build before the gps maps upgrade, how can i get an update without the dealer messing up my coding?
Must be because you have the 2013 model! Lucky hehe
