      07-14-2012, 09:25 AM   #353
levente
levente's Avatar
Drives: 2013 F30 M Sport
Originally Posted by shawnsheridan View Post
The full v.46.6 download links are here:
Good News:
This should be the updated v.46.6 PSDZdata:
http://ul.to/cjyr98h0/psdzdata.part01.exe
http://ul.to/t8oifb6f/psdzdata.part02.rar
http://ul.to/qlz3766u/psdzdata.part03.rar
http://ul.to/u71x6twc/psdzdata.part04.rar
http://ul.to/d2zurw2z/psdzdata.part05.rar
http://ul.to/cridpd03/psdzdata.part06.rar
http://ul.to/n16rry6h/psdzdata.part07.rar
http://ul.to/7fbn53nt/psdzdata.part08.rar
http://ul.to/luc2rz27/psdzdata.part09.rar
http://ul.to/74e844w7/psdzdata.part10.rar
http://ul.to/gfvjx6op/psdzdata.part11.rar
http://ul.to/sk6nbj1e/psdzdata.part12.rar
http://ul.to/2brsj8jk/psdzdata.part13.rar
http://ul.to/rsm5bdkp/psdzdata.part14.rar
http://ul.to/pigvcwxc/psdzdata.part15.rar
http://ul.to/95zmnec9/psdzdata.part16.rar
http://ul.to/804ey05r/psdzdata.part17.rar
http://ul.to/pwrdh094/psdzdata.part18.rar
Bad News:
These are on the German uploaded.to site that I can not access from the U.S.
Someone please grab this and put them on RapidShare, or even better, make a Torrent and SEED!
Edit: RapidShare Links Added:
http://rapidshare.com/files/17752485...ata.part01.exe
http://rapidshare.com/files/35223836...ata.part02.rar
http://rapidshare.com/files/33194538...ata.part03.rar
http://rapidshare.com/files/29945526...ata.part04.rar
http://rapidshare.com/files/33259470...ata.part05.rar
http://rapidshare.com/files/12851700...ata.part06.rar
http://rapidshare.com/files/63937664...ata.part07.rar
http://rapidshare.com/files/76748414...ata.part08.rar
http://rapidshare.com/files/40584653...ata.part09.rar
http://rapidshare.com/files/43607244...ata.part10.rar
http://rapidshare.com/files/49728960...ata.part11.rar
http://rapidshare.com/files/31364841...ata.part12.rar
http://rapidshare.com/files/26845889...ata.part13.rar
http://rapidshare.com/files/23853705...ata.part14.rar
http://rapidshare.com/files/12227656...ata.part15.rar
http://rapidshare.com/files/29941955...ata.part16.rar
http://rapidshare.com/files/54458236...ata.part17.rar
http://rapidshare.com/files/39839701...ata.part18.rar
Just wondering if a July built My13 would work with this version?
      07-14-2012, 10:47 AM   #354
dacider
Drives: 2012 328i
Just attempted my first go at the coding this morning and I couldn't get the cable to bring up a connection. Not sure if it's the cable, how do I check to see if it's working correctly? Is anyone coding in the Los Angeles Area?
      07-14-2012, 11:06 AM   #355
phillyd2
Drives: 2012 335
Originally Posted by Jbrock22 View Post
Anyone in the Bucks County area code their car yet?
Not yet. Connected but have not coded anything yet. Did you get your car? If so, read back a page or two and lets set up a coding party!
      07-14-2012, 12:09 PM   #356
John001
Drives: 2012 328i Sport Line
Originally Posted by Puri1 View Post
Left this message for Svache.. if any one else has a solution / similar problem, do tell:
Hi Svache..
I started coding today and followed all the instructions and it went beautifully.. thanks so much for this DIY.. it was really great...
We had a coding meet today with Bananachipz Maz and I and we went through this coding stuff..
Banana tried to change my values in FEM_BODY for all the mirror close, etc but it didn't go through.. kept popping error messages...
I cam home and tried it and did everything else apart from touching the FEM_BODY code and when I tried to do code the cafd in FEM_BODY the name had changed and is something like CAFD_FFFFFFFF_255_255_255 and obviously can't be found anywhere now.. very strange..
Is there anyway to get the default one back on.. All other modules and cafd files work fine except for this one..
I'm at a loss as to what to do, any help here would be much appreciated...
Thanks,
Exact same thing happened to me today. I tried coding the mirrors and a few other things. When I clicked the CODE FDL button, I got an error at the end "cdDeploy ProcessedWithError" "cafd_00000794-002_020_029 Not Executable"
None of the coding changes worked, but everything in the car still works as far as I can tell, but I can't get back into FEM_BODY now since it renamed itself to CAFD_FFFFFFFF_255_255_255 (the original name was cafd_00000794-002_020_029).
This was done using ver 46.6 of PSDZdata posted today. 46.3 didn't have the cafd_00000794-002_020_029 file.
John
****Update****
I just figured out how to fix it. Check out the attached PDF for instructions.
****Update #2****
I just went back and coded the mirrors and Auto Start Stop and it was successful this time. I think I took too long the first time and the car turned off before or during the CODE FDL portion.
      07-14-2012, 12:39 PM   #357
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
Did you wait for Windows to assign an IP address? It can take a minute or so. Verify that you have an IP before trying to connect. Remember that the car ignition must be on; it doesn't need to be running.
I'm in Ventura County which is sort of in the "LA" area. I've done about 5 coding sessions without any issues.
      07-14-2012, 01:35 PM   #358
bananachipz
Drives: F30 Mineral Gray 335i
Folks,
Has anyone encountered an issue where e-sys couldn't find the proper CADF file for FEM_BODY?
I've successfully coded my March build 335i Sportline. Yesterday, I met up with two guys from the forum, and helped them code their car (using my laptop and cable). One was a 335 and the other a 328.
The 335:
- connected fine
- read the ECU fine
- Failed when trying to "Read coding data" from the CADF under FEM_BODY
- interestingly enough, other modules read fine
The 328
- Connected fine
- read the ECU fine
- loaded coding data fine
- changed values fine
- when attempted to do the final "code", it failed in the end. Something about not being able to execute the CADF (unfortunately I don't have the exact error)
Some notes:
- I ran the app with admin privileges (originally I thought it might be a permission issue)
- I've successfully coded my car in the past without a hitch
- My guess is there are new and different versions of the data files?
Thoughts?
Thanks in advance.
      07-14-2012, 01:37 PM   #359
bananachipz
John
****Update****
ha! I just saw this!!
      07-14-2012, 01:38 PM   #360
Marathon Man
Drives: 2013 X3
John001,
It is great that you figured out how to solve your problem and even better that you documented it so clearly for the rest of us. Thanks!
I'm waiting for my first BMW, and we just got our Performance Center Delivery date set for August 16th. But I'm all ready to do the coding, including cable in hand.
      07-14-2012, 01:50 PM   #361
dacider
Drives: 2012 328i
I waited for windows to detect but eventually it just gave up and said no connection. I'll have to double check it to see what the exact message was but I waited until it stopped several times.
      07-14-2012, 02:59 PM   #362
Puri1
Puri1's Avatar
Drives: F30 328i 2012
[quote=John001]
Hi Svache..
Thanks,
John
****Update****
Hey John.. That worked flawlessly .. Thanks a lot man..
2012 F30 328i, Alpine White on Black, Luxury, Premium + Exec. Package...
      07-14-2012, 03:05 PM   #363
Puri1
Puri1's Avatar
John
****Update****
Thanks for following up man... John's solution worked without any issues.. The car is all coded now.. ASS last setting remember.. DVD in motion.. Orange light delete.. Mirror close/open with KF/CA.. Gong delete.. Warnings delete.. Etc etc..
I'm gonna download the new files next week and try and get Maz's car coded..
      07-14-2012, 03:06 PM   #364
Puri1
Puri1's Avatar
Originally Posted by Marathon Man
John001,
+1
      07-14-2012, 03:06 PM   #365
John001
Cool, I'm glad it worked for you too.
John
      07-14-2012, 06:02 PM   #366
Yobyot
Yobyot's Avatar
56
Drives: MY12 F30 ZSL
Does manufactured date matter?
I am going to attempt to code a very-late-date MY12 F30 (made 6/2012). I doubt anyone coding has one of these F30s yet. If you do, please let us know how it went.
But I wanted to know if anyone has seen a problem with the 46.3 psdzadata that svache was successful with in a more recent F30 (recent in terms of manufacturing date). The people discussing 46.6 aren't talking about F30s but it seems some other F series cars are sensitive to the level of psdzdata by manufacturing date. That makes sense to me: ideally one would match the files to the car precisely. I don't have a car (yet) to see how this works, but if anyone can share their experiences, I would appreciate it.
MY12 335i ZSL:
Produced: 2012-06-22; ED: 2012-07-19; Arrived in Jersey City: 2012-08-23; Redelivered: 2012-09-12
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29
      07-14-2012, 07:01 PM   #367
Frogman
Frogman's Avatar
You should get a message like "This connection has limited or no connectivity". That's normal as there is no DHCP server on the car.
If you click on the network icon and then click on details, does it show an IP address? It should be 169.254.x.x which means Windows assigned an address. If not, then you may have a bad cable.
Other things:
1. Is the ignition on?
2. Did you do the ZGW_SEARCH.exe command first?
3. Did you select F020?
3. Did you select connection via VIN?
Good luck. PM me if you want more help.
      07-14-2012, 09:10 PM   #368
RASHID007
Drives: 2014 535d X-Drive
46.3 worked for all except the FEM BODY and REM files in my late April 2012 335i.
Just downloaded 46.6 and will try it tonight.
      07-14-2012, 09:27 PM   #369
Puri1
Puri1's Avatar
Do let us know how it goes.. Could you let me know what cafd# you have under FEM_BODY..
Also which month was your car produced in? Thanks
      07-14-2012, 10:03 PM   #370
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Good News:
Bad News:
FYI. I downloaded this and based on the fact that the F10 CIC CAFD file is the same in this "new" version as it is in v.46.3 (cafd_000000f9.caf.007_002_006), and not matching the newer F10 builds (cafd_000000f9.caf.007_002_157), and the fact that when I look at it in E-Sys, it still shows the old F010_12_03_512 v.46.3 Integration Level, I am convinced it's v.46.3 and not 46.6. I would avoid downloading this.
      07-15-2012, 08:55 AM   #371
John001
I downloaded it as well and it does have the cafd_00000794.caf.002_020_029 file (which is missing in 46.3) I needed to code FEM_BODY on my F30.
So there is something different between ver 46.3 I got from the links on the first page of this post and 46.6 I got from the posts above.
John
      07-15-2012, 10:29 AM   #372
mod2133
Drives: BMW 320D EDE (F30)
With the 46.6 files I could successfully code FEM_BODY. Something that didn't work with 46.3. As reported before by others.
Other modules worked with 46.3 before.
So I'm happy and finally have my car the way I want it. Thanks to all making this possible.
      07-15-2012, 01:40 PM   #373
RASHID007
I just used 46.6 to successfully code FEM_BODY and REM to areas I could not code before with 46.3. Now my rear daytime running lights stay on during the day.
Thanks!
      07-15-2012, 03:10 PM   #374
shawnsheridan
So there is something different between ver 46.3 I got from the links on this post and 46.6 I got from the previous page.
John
There is no doubt this version is newer than the previous version, as the new version is from 6/20 while the previous version was from 4/20, and the following 13 CAFD files were added are in this latest version:
cafd_000000ae.caf.005_004_000 249,837
cafd_000000f9.caf.007_003_009 2,955,507
cafd_00000bce.caf.005_012_000 721,717
cafd_0000007e.caf.002_003_007 44,945
cafd_000007a1.caf.005_018_028 2,014,103
cafd_000009ef.caf.000_016_003 1,180,127
cafd_000014a8.caf.100_000_001 21,185
cafd_0000068d.caf.001_006_003 58,585
cafd_00000163.caf.007_001_006 1,344,995
cafd_00000171.caf.002_002_001 37,729
cafd_00000223.caf.013_006_006 1,986,099
cafd_00000794.caf.002_020_029 6,060,497
cafd_00000985.caf.003_001_111 88,591
The actual PSdZdata version though remains unclear to me as the F10 Integration Level remains unchanged. It is quite conceivable this is v.46.6 and still I-Level F010_12_03_512, but if that is the case, since we are seeing new F10's having even newer CAFD files (e.g. CIC CAFD file cafd_000000f9.caf.007_002_157) than what is in this new release (e.g. CIC CAFD file cafd_000000f9.caf.007_002_006), it would indicate that there exists a version somewhere, perhaps in Munich only, that is higher than this release, maybe the rumored v.47.x.
