Login
06-19-2013, 11:08 AM | #3852 | |
![]() ![]() ![]() ![]() 2847
Rep 15,620
Drives: 2016 650i GC M-Sport
![]() 2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc. |
06-19-2013, 01:55 PM | #3853 |
Rep 2
BMW F20 EU model 2012
I'm new to this forum. Driving a 2012 BMW F20 EU 116d. Since I cannot find a similar topic in the F20 forum, could you please help me out?
I have already purchased a cable. Would coding work on my car using E-Sys 3.18.4 and PSdZData 48.3? Could someone please send me a mail how to obtain these files? My email address is paulusma@hotmail.nl Many thanks! |
06-19-2013, 09:16 PM | #3854 | |
Rep 15,620
So, try 48.2, and hope it works. If the car was last programmed with ISTA/P >= 2.48.3, you will need to update to E-Sys 3.22.5 and the latest PSdZData. Email sent.
06-19-2013, 11:35 PM | #3855 |
Rep 2
coding newbie
Hi,
I have no experience with coding but exploring as my F30 328 is currently being built and I want to be prepared. Am I right in assuming that I will need to use E-sys 3.22 with my car when it arrives in late August and how do I get this version. My friend has a late 2012 build 328 - will 3.18 work with his? Thanks in advance for your help |
06-20-2013, 12:12 AM | #3856 | |
Rep 15,620
As for your friend's F30, it is impossible to guess. The build date is completely irrelevant. What matters only is what version of ISTA/P was last used to program the car. If it was >= ISTA/P 2.48.3, he too will need E-Sys 3.22.5 and the latest PSdZData.
06-20-2013, 02:25 AM | #3857 | |
Rep 2
Ok Thanks for that. I will use the E-sys 3.18 that I have to check his version. Where can I get version 3.22.5 and latest PSdZdata? Thanks again for your help! |
06-20-2013, 10:21 AM | #3858 |
Rep 15,620
PM sent.
06-20-2013, 12:21 PM | #3860 |
Rep 15,620
PM sent.
06-20-2013, 12:33 PM | #3861 |
![]() 2
Rep 47
Drives: 2013 328i M Sport
Question on light sequence coding: can you code the front eyebrows (technical term for light strip above halos?) and rear running lights to blink as your lock/unlock/alarm visible verification?
06-20-2013, 12:51 PM | #3862 |
Rep 16
could I also have a link for the latest e-sys + PSdZdata?
also can anyone tell me the password for opening the pdf docs e.g. E-Sys - Getting_Started-Coding.pdf ... |
06-20-2013, 01:30 PM | #3863 | |
Rep 15,620
http://www.f30post.com/forums/attach...2&d=1338274757 PM sent.
06-20-2013, 02:39 PM | #3865 |
Rep 15,620
Add Option Code S322A Comfort Acess to VO, and VO Code car.
06-20-2013, 03:07 PM | #3867 |
Rep 15,620
06-21-2013, 06:59 AM | #3868 |
![]() ![]() 1
Rep 121
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
Hi all!
I have retrofitted my F30 CD-Radio with used NBT. I have not TCB. I add 609, 6NK, 6NR and 620 options to VO and VO coded the HU_NBT. 1. The Navigation tab is not active. Have I to buy FSC code or CAN-filter to activate Navigation? 2. Does voice command 620 require FSC code too? 3. There is not Internet tab in menu. How can I get it? 4. My HTC HD2 phone connecting to NBT via BT as handsfree and audio streaming but not as internet modem. And there is not globe icon near my HTC phone in BT menu. Help, please. Last edited by avgor123; 06-21-2013 at 07:14 AM. |
06-21-2013, 04:48 PM | #3869 |
Rep 20
06-21-2013, 09:30 PM | #3870 | |
Rep 15,620
The proper thing to do is flash the head unit and write your car's VIN to it, and then buy from BMW all new FSC Codes for both Nav Application and Voice Control (and SAT Radio, and BMW Apps if needed), and then Import and Activate them in the head unit. This will be very expensive. The alternative is to use a CIC PnP Activation Module (aka CAN Filter), which will fool you car's CAS Module into thinking the NBT VIN matches CAS VIN, and then you do not need to replace the FSC Codes: http://www.bimmer-tech.net/shop/bmw-...ivation-module
06-21-2013, 10:02 PM | #3871 | |
Rep 15,620
![]() Granted this is an E66, but to give you an idea of what's involved, see this video: http://www.youtube.com/watch?feature...&v=EjSDhpyAH5g
06-22-2013, 08:01 AM | #3872 | |
Rep 20
