      08-01-2012, 02:09 PM   #463
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Originally Posted by rentonrider View Post
Question: Does it matter that in step 4 and the est path in step 10 doesn't match?
Step 4) Copy "est" folder from "\\E-sys 3.18.4\est" to "C:\ESysData\e-sys est"
Step 10) Run "C:\EC-Apps\ESG\E-Sys\E-Sys.exe" (It will take E-Sys a while to write the log file) and Under Options, Settings: On the ODX Tab, set the ODX Rule Path to "C:\ESysData\Rules" On the EST Tab, set the Developer-Soft-Token EST Path to "C:\ESysData\est\Code Away.est"
Yes, it does. If you follow Step 4, then Step 10 has to be:
On the EST Tab, set the Developer-Soft-Token EST Path to "C:\ESysData\e-sys est\Code Away.est"
That is how my original instructions were written, but someone made a mistake restating them.
That said, you can put "Code Away.est" token anywhere you want so long as you give E-Sys the correct path to it's location.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      08-01-2012, 02:39 PM   #464
gerbs
woof
gerbs's Avatar
Drives: M6
Send a message via AIM to gerbs
Anyone had any success w/ either disabling bulb errors or changing resistance values?
I know the resistances can be changed for a fact, just not sure how (the error disabling is the easy one, changing voltage/wattage/resistance is different) - There is an active member of another forum that works @ a dealership and charges $30-40/hour to change the resistance values.
On the e9x, disabling bulb errors is as follows:
FRM (NFRM) FEHLERMELDUNG_CC_SL_V_L X
FRM (NFRM) FEHLERMELDUNG_CC_SL_V_R X
FRM (NFRM) KALTUEBERWACHUNG_SL_V_L X
FRM (NFRM) KALTUEBERWACHUNG_SL_V_R X
FRM (NFRM) WARMUEBERWACHUNG_SL_V_L X
FRM (NFRM) WARMUEBERWACHUNG_SL_V_R X
^* E9X ONLY UNTESTED ON F30 *^
2013 F13 ///M6 Sakhir Orange
2013 F30 335i Estoril Blue II
2008 E92 ///M3 Interlagos Blue
2007 E92 335i Montego Blue
      08-01-2012, 02:40 PM   #465
Puri1
Puri1's Avatar
Drives: F30 328i 2012
Originally Posted by BMWs View Post
Anyone know how to remove digital clock from BC? It's not needed since its on center screen. I would like to show miles to empty & digital speed (already coded) at same time on BC.
How'd you get the digital speed on there?
2012 F30 328i, Alpine White on Black, Luxury, Premium + Exec. Package...
      08-01-2012, 02:43 PM   #466
BMWs
Drives: 2012 X3 35i
It's on cheat sheet...
KOMBI | 3000 Anzeige_Konfiguration | BC_DIGITAL_V | aktiv / Werte=01 | ( default = nicht_aktiv / Werte=00 )
      08-01-2012, 02:50 PM   #467
rentonrider
Drives: E92 M3
2011 BMW M3  [3.50]
Much appreciated. Thx.
      08-01-2012, 05:32 PM   #468
demge01
demge01's Avatar
Drives: F30 320ed
Hi could I ask a favour of someone with adaptive headlights?
Looking at following folders in FEM BODY can you give me your werte values:
AHL_DRIVER
LWR_DRIVER
AFS_DRIVER
Cheers
      08-01-2012, 06:32 PM   #469
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
AHL_DRIVER
LWR_DRIVER
AFS_DRIVER
Cheers
These are in the 3067 LceTmsCoding2 section:
AHL_DRIVER is AHL, Werte is 01
LWR_DRIVER is initwerte, Werte is 01
AFS_DRIVER is initwerte, Werte is 00
      08-01-2012, 07:00 PM   #470
Zirenz2006
Zirenz2006's Avatar
Drives: 328i Sport Line, On Order M40i
Is there anyone in MA, CT or RI who is doing this who could help me out? I'll supply beer. I'm not sure I want to try this.
On Order: G01 M40i Phytonic Blue|Black with Blue Stitching
Current: '12 F30 328i Sport Line Sapphire Black|Black-red
Retired: '09 E90 335i M-Sport AW|Oyster, '07 E92 335i Graphite|Saddle, '05 E60 545i TiAg|Black, '01 E46 325i Jet Black|Black
      08-01-2012, 07:35 PM   #471
demge01
demge01's Avatar
Drives: F30 320ed
AHL_DRIVER
LWR_DRIVER
AFS_DRIVER
Cheers
Thanks Frogman
OK so mine is the same for LWR and AFS but at "00" for AHL.
It seems that's these are driver settings to power motors in headlamps.
LWR is vertical adjustment I'm pretty sure.
AHL I'm guessing Adaptive Headlights?
Maybe AFS is for other models.
      08-02-2012, 10:01 AM   #472
Robertck
Drives: 328i Luxury Line
Hi Guys, I just tried coding the closing mirrors when you lock the door, either by Key Fob or by Comfort Access, but it doesn't seem to work.
I have the 328i Luxury Line, with Comfort Access, so I assume there is a motor in the mirrors, but how do I confirm this?
I know for one, I do NOT have a button to fold the mirrors in manually, near the side mirror controls on the arm rest, which I noticed in an X5 is there.
Any help would appreciated.
Other than that, I have successfully coded other features like no more disclaimers, the WeatherBand, and the Sports Display Units changing to HP and Ft-Lbs.
haven't tried DVD in Motion, but it is coded, and the elimination of the turn signals when not using them to turn or turn on hazard.
2012 F30 328i Luxury Line - Alpine White on Black, Premium Pkg
      08-02-2012, 10:27 AM   #473
shawnsheridan
I just coded an F30 Luxury Line the other night, and his folded just fine, but still I do not know if it is standard equipment or an option, nor did I even look to see if he had an armrest button.
Does you car have SA430 Auto-dimming mirrors, as the power-folding function it is part of it, at least on the F10 it is?
      08-02-2012, 10:49 AM   #474
Robertck
I'm not sure if it has the SA430, but it has Auto-dimming mirrors.
How do I find out the options codes?
i'm new to BMW Coding, as I just picked up my BMW a month ago.
So trying to learn as I go.
I live in Canada, so maybe it's a difference between USA Spec'd and CA Spec'd F30's?
      08-02-2012, 11:06 AM   #475
Frogman
Frogman's Avatar
You can go here: http://www.rubmw.ru/vincode/eng/ to get your build details.
I have:
S430A Interior/outside mirror with auto dip
S431A Interior mirror with automatic-dip
I've coded the mirrors and have CA. I do have the button on the driver armrest.
      08-02-2012, 11:10 AM   #476
Frogman
Frogman's Avatar
There is also a typo in the cheat sheet. See post #311 in this thread.
Also, you have to hold the button (fob or CA) down for 2-3 seconds before the mirrors will start to fold in and the windows to close.
      08-02-2012, 11:21 AM   #477
Puri1
Puri1's Avatar
Is this for the F30?
      08-02-2012, 11:26 AM   #478
BMWs
Drives: 2012 X3 35i
It's on the F10 cheat sheet but worked on my F25. Perhaps it doesn't on the F30.
      08-02-2012, 01:18 PM   #479
Puri1
Puri1's Avatar
Thanks, I'll try it tonight.
      08-02-2012, 01:31 PM   #480
Robertck
I have:
Thanks,
Just did it, looks like I didn't get S430A, only S431A.
So I'd assume then, that I do don't have the ability to auto fold the mirros. Even though I have comfort access. Bummer
      08-02-2012, 02:12 PM   #481
shawnsheridan
Thanks,
Unfortunately, the power-fold mirrors are not part of CA, but rather part of the Auto-Dimming option, presumably as they are already running electronics to the mirrors for the dimming, whereas with CA they don't.
What's odd though to me is that Auto-Dimming mirrors aren't included as standard equipment in the Luxury Line.
      08-02-2012, 04:27 PM   #482
Robertck
Maybe becuase mine is the launch edition "premium package" it came with the rear-view camera, and auto-dimming rear view mirror, but seems like it doesn't come with external auto-dimming mirrors, although on the options list from the dealership it says int/ext auto-dimming mirrors. Maybe this is something I can argue and get them to retrofit?
      08-02-2012, 05:39 PM   #483
svache
svache's Avatar
It does seem like this but they are actually auto-dimming. They make use of the same sensor as the rear view mirror, if you shine a bright light into that sensor, you'll notice the outside mirrors will dim a little bit... and yes, it's only a little bit... compared to how it was on my X5, the external mirror dimming on the F30 really sucks big time
F30 328i Luxury w/ Mojave metallic, beige interior (timeline)
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread
      08-02-2012, 08:19 PM   #484
08bmw128i
Drives: 2018 X5M
I have the cable in RI and can lend you it. I did my f10
