European Auto Source
      08-07-2012, 07:40 PM   #507
F30Spida
Drives: 2012 BMW 328i Sport
Hey guys,
Has anyone come across an issue with the auto-sensing lights after removing the speed limit on the cameras.
Last night I make a cable and change the following settings...
V_SCHWELLE_1
V_SCHWELLE_2
D_SCHWELLE_1
D_SCHWELLE_2
SPEEDLOCK_X_KMH_MAX
SPEEDLOCK_X_KMH_MIN
VIDEO_NUR_MIT_HANDBREMSE
LEGAL_DISCLAIMER_TIME
So the disclaimer, and the vision in motion works great, but the camera speed limits remain in force and now the headlights will not turn off with set to auto, even if the hud and nav change to Daylight mode.
Any thoughts?
F30 328i Sports - Mineral Grey
      08-07-2012, 07:44 PM   #508
SmoothSteeringHopeful
SmoothSteeringHopeful's Avatar
Originally Posted by Puri1 View Post
I don't think the F30 has a Kombi named module in it. Could you give instructions on how you got the Digital Speedo in there? Thanks
I found it, check the photo. I enabled the sports display, but it doesnt show any information. Just gives an option under vehicle info for sports display, opens up, but isn't working.
Base model, no nav
      08-08-2012, 07:50 PM   #509
I've come across quite a bit today. I'll put all the codes together in a list but I've enabled CD/DVD function on the main screen when choosing between CD and radio. I don't think the base system can read DVD's as disks were unreadable.
I've enabled BMW Live, but am unable to get an internet connection through my phone.
I've changed the way the external media screen looks. Now it doesnt start from the search menu, but different screen where I can choose to search, skip or go back tracks, and select video. I'll be testing out if I can watch videos from my iphone soon.
As far as the sports display goes I have the option to view it, and change from kW and Nm to Hp and Ft Lbs, but I am getting no readings on it. The display just shows up with no needles.
Anyone else have any luck with these?
      08-09-2012, 02:30 AM   #510
demge01
demge01's Avatar
Drives: F30 320ed
Sports display showed no readings either on mine. Screen is displayed plus option to select in sport mode.
So coded it off again for now.
So can you code working Internet or live even if you don't have Nav?
Cheers.
      08-09-2012, 03:28 AM   #511
Quelque
Netherlands
Drives: F30 330e
I would be interested to try that out too!
WRT Sports Display and speed in BC, my car is a base version (i.e. no Line) too, but with Business Navi as part of the Executive package, maybe that is of importance here?
      08-09-2012, 09:56 AM   #512
Cheers.
I noticed some guys in the 5 series doing it. Then I looked at a retrofit site that adds a combox to get the internet working, charge quite a bit too. Calling my dealership soon to find out the cost for it. The combox enables internet via bluetooth tethering and possibly a few other things. right now I can't watch video on my screen, I think with the combox I will be able to.
      08-09-2012, 11:49 AM   #513
Stokkes
Grand Pumba
Stokkes's Avatar
Drives: 2013 328xi Sport Line (GS/Red)
Although I'm in Canada, my F30 is a base model (no nav) and would need a combox retrofit + a few other things (and some wiring) to bring it "up" to the equivalent F30 + Prem package.
The cost of this is about $3900 which isn't really worth it. Basically, if you have a base model, you can code your car and get Sirius and that's about i (at least what I've found).
      08-09-2012, 12:44 PM   #514
I have satellite radio and premium pack, by base model i mean no sport, luxery, or modern line.... $3900 for what exactly?
I spoke with my dealer, the combox is $300. Ordering it today.
      08-09-2012, 01:31 PM   #515
089ebir
Drives: 330d
Hello,
Maybe somebody can help me.
Is ist possible to install INPA and E-SYS on the same Computer on the Same device in C:\ , because i think
there are different ediabas.ini Files ? Isnt it ? -> because different Interface ?
If this Not work, is it possible to Install E-SYS on device D:\ ?? Or E-SYS on C: and Inpa in D:\
How can i getting started with working INPA and ESYS on the same Laptop?
Tanks
      08-09-2012, 02:19 PM   #516
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
I too have the base system and was wondering about DVD's.
What if I have a DVD on a thumbdrive, will it play on the screen off of that?
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      08-09-2012, 02:41 PM   #517
I'm guessing you mean you downloaded a movie,not actually have an 8 gig dvd file on a thumb drive. To play DVD's I believe you have to have NAV as from what I gather the base system only reads CD's. To play video from an iPhone or something of the sort I believe you need the combox, which I have ordered and will have more on next week when I install it.
part number 84109257150 is the combox. Hopefully it works.
      08-09-2012, 02:42 PM   #518
demge01
demge01's Avatar
Drives: F30 320ed
How do you code Sirius or do you have to get hardware too?
      08-09-2012, 02:54 PM   #519
Jamesons Viggen
The part for $300 is fine, but what about installing it?
      08-09-2012, 03:33 PM   #520
I'll write it up next week. On other F series cars it did not seem to be that complicated.
      08-09-2012, 08:10 PM   #521
Stokkes
Grand Pumba
Stokkes's Avatar
You probably have an option that the Prem package in the US gives you that we don't have on our base models here.. If you look at (based on the combox item number 84109257150):
http://www.realoem.com/bmw/showparts...=84&fg=10&hl=1
The combox is for all the vehicles that have either of those configurations. If you look through the list and compare with your car (http://www.bmwvin.com/), you'll probably have one of the options listed from RealOEM.
On the RealOEM page, of all the "vehicles with" options, I don't have any of the options on that page, so the combox wouldn't work in my vehicle. I'm pretty sure the Prem package in the USA gives you the extra equipment in some form to enable the extra functionality.
That's why the 3900.. I would need a complete retrofit with the professional screen (I only have the business smaller screen).
      08-11-2012, 11:07 AM   #522
carconvert
Drives: 2012 328i Luxury Line
hmmm... I'd be intertested in this but what about warranty? I have the professional nav, Hands-free with USB interface, and CIC-Zusteuerung.
Actually I ony want album art to display and I cant believe it doesnt on a car like this. Apparantly my CA says BMW Canada is aware of people wanting to add BMW apps after the fact and they're working on something... take that for what its worth. Interested to see the write up on this install... thanks
      08-11-2012, 11:24 AM   #523
As far as warranty goes I am unsure. I'm not doing it to my car so I'm not so worried about it!
I am not familiar with the difference between business and professional nav. Were these options in the USA?
      08-11-2012, 11:27 AM   #524
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
BMW has had an official 6NR retrofit since 10/11 as attached:
BMW Apps Retrofit (SA6NR)
BMW 1 Series (E 81, E 82, E 87, E 88) built after 3/2011
BMW 3 Series (E 90, E 91, E 92, E 93) built after 3/2011
BMW 5 Series (F 07, F 10, F 11, F 18) built after 3/2011
BMW 6 Series (F 12, F 13) built after 3/2011
BMW 7 Series (F 01, F 02, F 03, F 04) built after 3/2011
BMW X1 (E 84) built after 3/2011
BMW X3 (F 25) built after 4/2011
BMW X5 (E 70) built after 4/2011
BMW X6 (E 71, E 72) built after 4/2011
BMW Z4 (E 89) built after 3/2011
The F30 wasn't out yet, but it should be the same.
This is to run the Video cable from the 6NF Baseplate to the CIC, so 6NF is required.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      08-11-2012, 01:08 PM   #525
tukerstown
Drives: BMW 330i
Fog lights
Hi all. Has anyone looked into a way to code the fog lights so they automatically come on with the headlights? Is it possible?
      08-14-2012, 08:32 PM   #526
BruceFerjulian
Drives: 535i xDrive GT
Supplier for the 511 Ohm .6 Watt Resistors
Just ordered a few of the resistors off of this web site. Paid more for shipping that for the parts.
<http://www.newark.com/jsp/search/productdetail.jsp?sku=74C0216&CMP=AFC-NEDA>
Yes, it looks like there are very few folks making this exact item. It was easier looking for a ( 600mw ) in the search, rather than a ( 0.6 watt ).
Manufacturer: VISHAY BEYSCHLAG
Part Number: MBB02070C5110FRP00
Description: RESISTOR, METAL FILM, 511OHM, 600mW, 1%
Makes sense that one of the few companies making this resistor is German, and the car is German.
Vishay Electronic GmbH
Dr.-Felix-Zandman-Platz 1
Selb
D-95100
Phone: 49-9287-71-0
Fax: 49-9287-70435
      08-14-2012, 09:35 PM   #527
pcbrew
pcbrew's Avatar
25
Drives: 2012 335i 6MT
Digi-key also carries them:
http://www.digikey.com/product-detai...1ZCT-ND/595057
2012 F30 335i 6MT - Imperial Blue w/Everest Gray: Sport, Adaptive M, Premium, Tech & Parking Pkgs, Assist, Apps
      08-15-2012, 12:01 AM   #528
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
Selb
D-95100
Phone: 49-9287-71-0
Fax: 49-9287-70435
The tolerance on typical resistors is 2%, so that's about +/- 10 ohms. Even a 1% resistor is +/- 5 ohms.
A standard 510 ohm resistor worked fine for me.
