      09-08-2012, 02:49 PM   #727
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by john08135i View Post
I see this.. my vin but connect will not let me choose it..
You have no Target PSdZData. Make sure that there is a "Dist" folder in each of the Chassis (F01/F10/F25) folders etc.:
e.g. "C:\ESysData\psdzdata\mainseries\F010\F010_12_03_5 1 1\odx\dist"
      09-08-2012, 03:20 PM   #728
gerbs
woof
gerbs's Avatar
Drives: M6
Send a message via AIM to gerbs
I think you copied some files incorrectly.. make sure you copied the SWE folder.
And/or just go through the install instructions again.
Also make sure you are pointed to the correct code away est file.
2013 F13 ///M6 Sakhir Orange
2013 F30 335i Estoril Blue II
2008 E92 ///M3 Interlagos Blue
2007 E92 335i Montego Blue
      09-08-2012, 03:24 PM   #729
gerbs
woof
gerbs's Avatar
Drives: M6
Nevermind, listen to Shawn he's probably right ^^
      09-09-2012, 05:35 AM   #730
Roubs
Drives: 3srs
Links Please
Will someone be kind enough to email me where I can download
All the required files for 2013 F30
amarru at gmail dot com
Appreciate it
      09-09-2012, 05:44 AM   #731
shawnsheridan
Appreciate it
Email sent.
      09-09-2012, 09:43 AM   #732
code0482
2012 335i sportline every available option
code0482's Avatar
Drives: 2012 335i Sedan
Please!!
Could someone be kind enough to email me where I can download
All the required files for 2012 F30
code0482 at gmail dot com
Thanks in advance
      09-09-2012, 04:16 PM   #733
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
Really gotta get together a group of us for coding in the NY/NJ/PA area. I now have a FSC code for SAT radio thanks to Shawn
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      09-10-2012, 12:50 AM   #734
2k15f30
2k15f30's Avatar
-54
Drives: 2015 335i M Sport
Is there anyone in the Arizona area with a cable? I need to recode due to a problem and unfortunately my cable is back home. I have my laptop with the software I just need a cable for 5 minuets. Anyone?
      09-10-2012, 08:42 AM   #735
shawnsheridan
      09-10-2012, 01:13 PM   #736
kruemel
Switzerland
Drives: M3 Mineral White
stupid question.. if i set an option in e-sys
only the changed setting whould be send to the car and nothing else, correct? ^^
So i can't kill my car with just setting one option ?
      09-10-2012, 01:17 PM   #737
shawnsheridan
So long as you only hit FDL CODE, it will change only what you changed. If however you hit CODE or CODE DEFAULTS, it will code the entire module based on some predefined conditions.
      09-10-2012, 01:20 PM   #738
kruemel
Switzerland
omg ^^
if i hit READ i'll get the files to the CAF folder to back it up and if something go's wrong i have to copy the files back to the CAF folder and have to hit "CODE"?
      09-10-2012, 01:35 PM   #739
shawnsheridan
omg ^^
No. For example, for your HU_CIC ECU, the Coding Application file that is part of the PSdZData and used to code the ECU will be cafd_000000f9.caf.006_008_207. When you read the HU_CIC, you will get the actual Net Coding Data in a file named CAFD_000000F9_006_008_207.ncd.
So when you first get your car, read every ECU, and copy all the .ncd files to a separate safe backup location in a different folder. If you have to revert back to the original coding data, there is a process of inserting that into the CAFD and coding the module. It does not require you copy those files back anywhere.
      09-10-2012, 01:54 PM   #740
kruemel
Switzerland
hopefully i never have to restore something ^^
      09-10-2012, 02:20 PM   #741
gerbs
woof
gerbs's Avatar
Drives: M6
Shawn-
When you unzip a new psdz data version, can you just copy the new psdz folders over the existing data? Or is there a best practice to "replace" the version?
I'm asking because I'd like to keep some of the files that happen to be "missing" with certain psdz releases (like in 47.1 how there was missing cafd files).
      09-10-2012, 02:35 PM   #742
shawnsheridan
Shawn-
No. Don't merge the two. Delete the old PSdZData folder, and replace it with the new one.
If you want though, you can save your old C:\ESysData\psdzdata\swe\cafd, folder only, then copy the new cafd folder into that one, overwriting any older data and keeping any CAFD files that are not in the new data, and then take just that one merged cafd folder and replace the new cafd folder with this merged cafd folder.
Apart from the cafd folder, you want only the latest clean PSdZData folders and files, and not commingled with the previous version.
      09-10-2012, 03:47 PM   #743
jsbmw87
Gear Head
Drives: 2016 M4
Files
Hi,
Could someone please PM me a download link for the required files for a 2012 F30?
Thanks.
      09-10-2012, 04:44 PM   #744
gerbs
woof
gerbs's Avatar
Drives: M6
Great info, thanks.
      09-11-2012, 02:36 AM   #745
AntBabeee
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
Appreciate it
Email sent.
Can you please send me an email also lilant510 @ gmail.com
I need app and data since links were removed. Thanks in advance!
F30 BMW 335i M-Sport: Estoril Blue II, 19" Rims, Sports Auto, Premium, Technology, Harmon Kardon, Heated Front Seats, Driver Assistance...
      09-12-2012, 09:00 AM   #746
shawnsheridan
Did this solve your problem John? Do you have Target data now?
      09-12-2012, 09:06 AM   #747
Jbrock22
Jbrock22's Avatar
105
Drives: 340i
Yes please. I live in Bucks County. Rather not try it myself.
      09-12-2012, 09:13 AM   #748
shawnsheridan
Originally Posted by Seyfeichai View Post
From the bluetooth menu summary, it seems my phone only has
1) audio and
2) phone book enabled.
Can't find the symbol for data connection. So it is not activated.
If you have a Combox, the coding that enables "Data Transfer" under your phone is in the Combox.
DUN_PROFILE = aktiv
This same exact setting exists also in the CIC, presumably for those without a Combox, and Bluetooth built in to the Head Unit.
If you still do not have the "Data Transfer" option, try setting this too:
SIM_ENABLED_MB = CSIM
