VIBE Motorsports
      09-16-2012, 03:09 PM   #793
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by dinnef30 View Post
1) Can you please explain how I can check if S6UHA is in VO? Where do I find VO in E-SYS? Is this Coding/FAList/FA/FZAuftrag/Type/SALAPAElement/*? There I only have the 3-char values there..
2) Do you mean with "VO Code" to do a "Code FDL" after reading FA, activating FA, Read (VCM), NEW/FDL on the CAFD, then CodeFDL?
No FDL Coding here.
Read your VO (FA), then hit the save button, then the edit button, and it will open in the FA-Editor. Expand FAList, scroll down to SALAPA-Element, and just double check that 6UH is listed.
Assuming it is, go back to the Coding module, read your VO and VCM, Activate FA, then highlight the ECU itself (Not the underlying CAFD entry), and right-click on it and select CODE. It will code the entire ECU based on the VO (Options and Production Date primarily).
DO NOT Mistakingly hit the "Code Default Vaules" button, or you will regret it.
      09-16-2012, 03:19 PM   #794
dr_squalo
Drives: F10
Originally Posted by shawnsheridan View Post
You do not have enough posts for PM. Post your email.
Probably I'll do some posts more
I'm not sure, if I will actually need even 47.5, cause mine is build up finally this week.
(For sure: better first wait for the car to get and then read the proper ISTA/P Version. But it was so boring to wait, so I thought I could at least meanwhile download those huge pszdata files before )
      09-16-2012, 03:24 PM   #795
dinnef30
Drives: F11 528i
No FDL Coding here.
Oh oh. I checked SALAPA and there is no 6UH.
I run E-Sys 3.18.4 with pszdata 47.4 and the missing file for FEM_BODY that you sent me. The car is a 328i with production date 22-June-2012 (according to hidden menu). Delivery was End of July 2012.
It's the german version, what is 6UH exactly? Perhaps we get different modules here?
PS: But I have 6NF which is "Handyvorbereitung Bluetooth incl. BMW Assist"
      09-16-2012, 03:40 PM   #796
shawnsheridan
S6UHA = Traffic Information. What is your short VIN? I will check for you.
      09-16-2012, 03:48 PM   #797
gerbs
woof
gerbs's Avatar
Drives: M6
Send a message via AIM to gerbs
I started coding my F30 328i today. I use psdzdata 47.4 plus the one missing file provided by shawnsheridan (thnx!).
now I lost RTTI, I see now TMC :-(
and: BMW Online does not work any more.
Find-my-car via iPhone still works, so the internet seems working somehow.
Any ideas what went wrong and what to check?
Similar thing has happened to me on my 2013.
I no longer have sat radio and traffic info isn't appearing on the map anymore. Didn't touch any coding besides the lighting/comfort access and poof now it's gone.
I can check TI_CA_TMC, anywhere else come to mind for me to check?
2013 F13 ///M6 Sakhir Orange
2013 F30 335i Estoril Blue II
2008 E92 ///M3 Interlagos Blue
2007 E92 335i Montego Blue
      09-16-2012, 04:12 PM   #798
shawnsheridan
I have no idea. There is simply no logical explanation for this. Is it possible the RTTI system is just down right now, and it is defaulting back to TMC for the time being?
      09-16-2012, 05:11 PM   #799
Yobyot
Yobyot's Avatar
56
Drives: MY12 F30 ZSL
My MY2012 F30 has just been redelivered. And I'd love to code the mirrors to auto-fold and also to get rid of the iDrive accept screen.
But this thread has gone on for some time, wandered a little bit and has so many very detailed questions, that I don't know where to begin.
As of today, where would a newbie:
1) Get the correct E-Sys application?
2) Find and download the correct level of psdzdata for an MY12?
I am especially concerned about "missing" files that some people are discussing. What does this mean? That the level of psdzdata is wrong? That it was an incomplete download?
Thanks in advance for your help.
MY12 335i ZSL:
Produced: 2012-06-22; ED: 2012-07-19; Arrived in Jersey City: 2012-08-23; Redelivered: 2012-09-12
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29
      09-16-2012, 05:17 PM   #800
gerbs
woof
gerbs's Avatar
Drives: M6
Will check around today to see what works and post back w/ results.
      09-16-2012, 05:22 PM   #801
shawnsheridan
Get E-Sys 3.18.4 and grab the current latest PSdZData 47.4.
Your car though may come in having been programmed with ISTA/P 2.47.5, in which case you too will be missing some CAFD files. It is not an issue or concern. You simply have to wait to code any module that requires a newer CAFD until the new 47.5 PSdZData becomes available for download. It won't harm anything by using the older PSdZData and encountering a missing CAFD file. Worst case is you are limited in which ECU's you can code.
      09-16-2012, 07:25 PM   #802
BMWs
Drives: 2012 X3 35i
I got bluetooth data activated using DUN_PROFILE = aktiv. But still says Browser not enabled, contact service center. I believe I activated the browser using OnlineBrowser=BMWOnline but still now working. Any ideas?
      09-16-2012, 08:01 PM   #803
shawnsheridan
Set ONLINE_BROWSER = beide_aktiv
Do you have 6VC Combox, and did you write a new VIN with factory 614 and 615 to it?
      09-16-2012, 08:14 PM   #804
BMWs
Drives: 2012 X3 35i
I did try that setting also. I'm not sure what Combox I have. Non-NAV, non-BMW Asist, US X3. Don't know how to write new VIN.
      09-16-2012, 08:40 PM   #805
Yobyot
Yobyot's Avatar
56
Thanks, I'll give this a try.
MY12 335i ZSL:
MY18 X3 30i:
      09-16-2012, 09:07 PM   #806
shawnsheridan
Internet / BMW Live can be done on Combox equipped cars, but it is not a simple FDL Code.
Read my Post 568 here to understand what is involved:
http://www.f30post.com/forums/showpo...&postcount=568
It may also be possible on cars without a Combox, certainly it is from the factory, but I do not know how it could be done outside of the OEM solution in this case unless somewhere in the CIC you can write an alternate VIN that is used only for this purpose, as that is how it is done on Combox equipped cars.
As for having a Combox or not, check and see if you have option 6VC.
      09-17-2012, 12:23 AM   #807
dinnef30
Drives: F11 528i
is this the short VIN: xxxxxxxx (last 7 characters?)
      09-17-2012, 12:38 AM   #808
shawnsheridan
is this the short VIN: XXXXXXX (last 7 characters?)
Yes, that is what I needed. Damn, your car is loaded.
I was not aware 6WA Instrument cluster, expanded equipment was available on the F30, but since you have the 610 Heads-up display, it makes sense. Is 6WA in the F30 though a full Black Panel Display?
As for 6UH Real Time Traffic Information, you do not have it as an option, but I don't know what that means on a German car, as in I don't know if it just comes standard with no option, or if you can, and have to, specify 6UH in order to get RTTI. Maybe someone else from Germany who knows can chime in.
      09-17-2012, 12:47 AM   #809
Micleg
F11 2015 X08
Sweden
28
Drives: 520d F11 msport, 520d F11 X08
6WA is included in "ACC stop & go" 5DF, Navigation and HUD. It can be bought as a standalone option though. It is called extended black panel since the panel in F10/F11 is called full black panel and is considerably larger.
      09-17-2012, 12:54 AM   #810
shawnsheridan
Interesting. On the U.S. F10, you can only get 6WA if you order the HUD. It might be the same for the U.S. F30 where it is not a standalone option.
Still, it is a Black Panel Display, and when the Instrument Panel is off, the gauges show no numbers on the dials for Speed and RPM?
      09-17-2012, 01:14 AM   #811
Micleg
F11 2015 X08
Sweden
28
Some pictures and a lot of info in this thread:
http://www.f30post.com/forums/showthread.php?t=693933
      09-17-2012, 01:37 AM   #812
shawnsheridan
Thanks. That cleared it up.
It's nice, but it is not a black panel display like this, which is what I was wondering:
http://f10.5post.com/forums/showthread.php?t=500027
      09-17-2012, 03:17 AM   #813
dinnef30
Drives: F11 528i
Yes, I put quite some extras into the car as I prefer features more than a even more loaded engine :-) So I took 328i instead of 335i but more features...
Yes, I have the "enhanced display", it is black when off. But it is available even without HUD and it makes sense without.
      09-17-2012, 09:58 AM   #814
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Send a message via Yahoo to john08135i
I can turn on my bmw online without paying? I have connected and all but it prompts me to order the online $199 thru bmw assist to get my google turned on..?
BTW.. my dvd player stopped working this AM.--UPDATE..nm it works fine again
M Sport Line Estoril Blue
