VIBE Motorsports
      10-02-2012, 06:29 AM   #947
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Originally Posted by dc_bmw View Post
Can I code my F30 with a OBDII cable that has a USB conector on one end?
No. It has to be ENET, which is OBD x Ethernet.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      10-02-2012, 06:30 AM   #948
legaleye3000
Drives: 2014 328i; 2015 X3
Shawn- do you ever sleep? Lol.
      10-02-2012, 06:50 AM   #949
shawnsheridan
Not much my friend.
      10-02-2012, 08:41 AM   #950
legaleye3000
Can anyone post a pic with the car's xenon headlights on (standard) vs. on with the parking lights disabled via coding? Thanks. Front and side (or angled) if possible...
      10-02-2012, 09:18 AM   #951
dinnef30
Drives: F11 528i
Coding with engine off or on?
As far as I've understood it is possible to do the coding with a) only the ignition on and b) engine running.
What is recommended and what are pro/cons?
      10-02-2012, 09:22 AM   #952
shawnsheridan
I keep my engine running always, unless I am messing with DME. For one, it's too damn hot here to be without AC, but more importantly it also keeps the required voltage level on the car. Having the battery drain, or the car go to sleep while coding is not good.
      10-02-2012, 09:31 AM   #953
BMWs
Drives: 2012 X3 35i
Anyone find coding to keep steering feel on Sport? I don't have a mode switch but steering firms up when I turn DSC off (Sport mode). Would like to have firm steering always by default.
      10-02-2012, 09:48 AM   #954
dc_bmw
Netherlands
Drives: BMW 330e
Has anybody found a setting to:
- open the trunk with the trunk unlock button, and
- leaf all other doors locked?
This was the case with my E46 and very convinient as the trunk was locked again once closed.
AND
Has anybody found a setting to enable Bluetooth Audio, even if the phone was connected via USB in the meantime? I really hate it that the USB connection remove the check mark from the Bluetooth audio. The next time you jump in your care for a short ride, you have to connect via USB in order to hear music, or re-check the checkmark.
      10-02-2012, 02:08 PM   #955
demge01
demge01's Avatar
Drives: F30 320ed
Sport +
I've managed to change the drive mode so I now have:
Sport +
Sport
Comfort
Eco
I didn't have Sport + before and all the others are ok except Sport + (DSC off) is greyed out and I can't select it with the drive mode rocker switch.
Any ideas?
Cheers.
EDIT: The settings are in:
CAF [KOMBI L7_BASIS] > 300C ECO_FDS, 30
      10-02-2012, 03:21 PM   #956
demge01
demge01's Avatar
Drives: F30 320ed
Originally Posted by shawnsheridan View Post
I don't see a whole lot in your CIC that would cover Combox functions. Can you post a picture of your E-Sys screen showing all your ECU's? Just the module names for now, no CAFD data.
Sorry Shawn totally forgot about this.
Is this what you need?
      10-02-2012, 03:27 PM   #957
legaleye3000
Demge01 - So you have the option of Sport+ showing up in the display by the speedometer, however, its greyed out and it won't let you select it? Thanks.
      10-02-2012, 03:44 PM   #958
demge01
demge01's Avatar
Drives: F30 320ed
Yes that's right but I can't select it.
      10-02-2012, 05:52 PM   #959
TonyS
Drives: F30 335i
I too would love to have this work like it did with my E46. Unlocking all the doors when you unlock the boot (trunk) is really stupid, why would you want to do that?
      10-02-2012, 10:03 PM   #960
legaleye3000
Anyone now how to keep items on the HUD up longer? Thanks.
      10-03-2012, 12:57 PM   #961
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
Just looking around in KOMBI, I found:
KOMBI, 3110, HUD_CC_MAX_DISPLAY_TIME
The comment says it's in units of 0.1 seconds and the Werte value is 50 (hex, 80 decimal), so it looks like the default is 8 seconds.
I just timed my HUD display (radio preset list) and it stay up for 8 seconds.
I have not tried changing this value and I have no idea if it will work or not, but if you are adventuresome, try it and let is know if it works or not!
      10-03-2012, 01:22 PM   #962
Frogman
Frogman's Avatar
Another coding that I found on a different forum can change the one-touch turn signal count from 3 to whatever you want it to be.
FEM_BODY, 3064, PIA_DEFAULT_TIPPBLINKEN
change the first label from Einfachblinken to Mehrfachblinken (Werte will change to 01). This enables the second setting below.
FEM_BODY, 3060, BLINKZYKLEN_ANZAHL_TIPP
change the Werte value to the number of blinks you want minus one. I have mine set to 4 which gives me 5 blinks. The label will show UNKNOWN, that's ok.
      10-03-2012, 01:36 PM   #963
legaleye3000
If the units are in 0.1 seconds and the value is 50, wouldn't it be 5 seconds rather than 8? Just double checking... If not, please explain what value I should put in if I want it to stay up for an additional 2 seconds from default. Thanks.
      10-03-2012, 01:56 PM   #964
Frogman
Frogman's Avatar
E-Sys shows values in hexadecimal (it's a computer thing). 50 is (5 * 16) + (0 * 1) = 80, or 8.0 seconds.
If you want 10 seconds, then try setting the value to 64 (hex). (6 * 16) + (4 * 1) = 100.
      10-03-2012, 01:59 PM   #965
legaleye3000
Ok, so just to confirm, for 10 seconds, I'll set the value to 100? Thanks.
      10-03-2012, 02:03 PM   #966
Frogman
Frogman's Avatar
No!!! If you want 10 seconds, set it to 64 in E-sys.
If you don't understand hexadecimal, look here:
http://en.wikipedia.org/wiki/Hexadecimal
      10-03-2012, 02:07 PM   #967
legaleye3000
Ahhh ok- good thing I asked.....lol. Ok, so I'll set the werte (value) to 64. Thanks!
      10-03-2012, 02:33 PM   #968
Frogman
Frogman's Avatar
Let us know if this works for you or not.
Is changing it from 8 to 10 seconds really going make that big of a difference for you?
