      10-03-2012, 02:59 PM   #969
legaleye3000
Drives: 2014 328i; 2015 X3
Well, I find that it disappears pretty quickly- Just want it to stay up a lil longer. Someone above mentioned they were able to make Sport+ appear but its greyed out. I'd like to have that one figured out
      10-03-2012, 05:22 PM   #970
SandmanJK
Russian Federation
Drives: 320d
I've found a way to disable triple seatbelt gong, when you start your engine with unfastened seatbelt.
It's ACSM | 3000 Ausstattungsflags | Initialwarnung_GWF_IW | nicht_aktiv / Werte=00 | ( default = aktiv Werte=01 )
      10-03-2012, 05:29 PM   #971
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
Cool.
The settings in the cheat sheet just turns off the constant nagging sounds, but it still blings 3 times if you start without the seatbelt on. It looks like this new setting turns that off too.
Does this setting affect both the driver and passenger sides?
      10-04-2012, 12:37 AM   #972
2k15f30
2k15f30's Avatar
-54
Drives: 2015 335i M Sport
I have found a way to modify the time the seatbelt gong goes off. Default time is 90s and Ive changed it to 20s.
ACSM / 3001 Seat_Belt_Reminder, 0C / GWF_SBR_WARNDAUER / Kommentar=Dauer der SBR-Warnung (typisch 90s) / unknown Werte=14 (default wert_01 Werte=5A)
Change the 14 to whatever hex you want for time. Default will replace wert_01.
      10-04-2012, 03:12 AM   #973
SandmanJK
Russian Federation
Drives: 320d
Originally Posted by Frogman View Post
Cool.
I believe it does, but I'm not sure, because passenger's seatbelt warnings were turned off from factory in my car.
      10-04-2012, 04:05 AM   #974
demge01
demge01's Avatar
Drives: F30 320ed
Does anyone know the difference between Sport and Sport+?
Is Sport+ the same drivetrain and chassis settings but with DSC turned off?
I've tried again with the FDS settings but can't get Sport + to select.
      10-04-2012, 08:20 AM   #975
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by demge01 View Post
Sorry Shawn totally forgot about this.
Is this what you need?
Thanks, but no. That is only one single ECU (HU_CIC). I am looking for the main screen that shows every ECU.
      10-04-2012, 11:47 AM   #976
KeenDriver
Drives: 2013 335i M-Sport
Took delivery on Monday and trying to set all this up. It looks like both versions of psdzdata I've downloaded were not the 47.x versions, which I need. Does anyone have a link to 47.4 psdzdata?
      10-04-2012, 11:57 AM   #977
Frogman
Frogman's Avatar
Send shawnsheridan a PM.
      10-04-2012, 12:16 PM   #978
shawnsheridan
PM Sent.
      10-04-2012, 02:33 PM   #979
dc_bmw
Netherlands
Drives: BMW 330e
If i hit ''open connection'' i see many typs but no F30. I got all 23 47.5 files installed. Do I need others? (please PM)
      10-04-2012, 02:38 PM   #980
Frogman
Frogman's Avatar
Pick F020 for the F30.
Do NOT pick the direct one.
      10-04-2012, 02:46 PM   #981
shawnsheridan
F020 psdzdata covers the F20 1-series and F30 3-series.
      10-04-2012, 05:09 PM   #982
demge01
demge01's Avatar
Drives: F30 320ed
Any good?
      10-04-2012, 05:34 PM   #983
shawnsheridan
Any good?
Yes, thanks. What are the CAFD Names for your HU_ENTRY, REM, FEM_Body, and FEM_GW?
      10-05-2012, 07:48 PM   #984
auptown
Drives: 2013 F30 328xi
Does anyone know if its possible to adjust the speedometer by coding? Mine, like I suppose everyone else's, reads high and I would love it to be accurate!
Andrew
      10-05-2012, 08:18 PM   #985
shawnsheridan
Andrew
BMW can advance the speedometer by 10% + 2.4 MPH per the attachment, which at higher speeds can be pretty substantial (85 MPH could read as high as 96 MPH).
Look for something like this in KOMBI:
BC_V_KORREKTUR = Correction for Analog Speed
BC_DIGITAL_V_KORREKTUR = Correction for Digital speed
      10-05-2012, 11:02 PM   #986
auptown
Great, thanks! I'll see if I can get it back to "accurate", which seems to be 2.4mph at any speed, and a few mph more at 70mph.
I hate having to do the correction in my head all the time, to figure out my true speed.
Cheers
Andrew
      10-06-2012, 01:31 AM   #987
Frogman
Frogman's Avatar
Did you ever try to code this? Did it work?
      10-06-2012, 01:42 AM   #988
friederbluemle
Drives: 2012 328i F30 MT
Does 47.5 psdzdata work fine for the F30? Or should I use 47.4
I also need links to download. shawnsheridan, can you please send me a PM? Thanks!
      10-06-2012, 02:32 AM   #989
kruemel
Switzerland
Drives: M3 Mineral White
This depends on your car's software release date.
If you have one early 533 you'l fine with 47.4 otherwise you need 47.5
Mine is from September and has 533
      10-06-2012, 06:22 AM   #990
dinnef30
Drives: F11 528i
Question
Originally Posted by dinnef30 View Post
Is following coding possible:
1) Adaptive Cruise Control (ACC) automatically pre-activated (the double orange bars in Cockpit display ON)
2) Default distance in ACC not 3 bars, but two bars?
really nobody ever tried this? especially 2) would be really helpful as I always switch to 2 bars after activating ACC.
At least, does anybody know which module is relevant for ACC? Then I would do some investigation on my own...
