      10-10-2012, 03:00 PM   #1013
dc_bmw
Netherlands
Drives: BMW 330e
Originally Posted by shawnsheridan View Post
What do you show as the name of your CAFD file under CMB_MEDIA?
do you mean the entry i see in esys?
See the first line of the error message.
      10-10-2012, 03:01 PM   #1014
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Originally Posted by dr_squalo View Post
Hello shawnsheridan,
cause I'm really not sure if I need 47.4 or 47.5 for my F10 (09/12).., can you PM me please the links for 47.5?
Thanks a lot in advance.
BR
PM Sent.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      10-10-2012, 03:07 PM   #1015
shawnsheridan
Open CAFD_000005b6_004_002_010.ncd in C:\ESysData\CAF using E-Sys FDL-Editor.
Search on "FF,FF," and tell me if you find something.
      10-10-2012, 03:08 PM   #1016
dc_bmw
Netherlands
Drives: BMW 330e
i could only succesfully read the CAFD under FEM_BODY. All others resulted in a timemout. The car was switched off during my attempt. No contact, no engine running.
      10-10-2012, 03:10 PM   #1017
dc_bmw
Netherlands
Drives: BMW 330e
the file is not there. It contains only 1 ncd file from the FEM_BODY i was able to open.
      10-10-2012, 03:14 PM   #1018
shawnsheridan
Why is your car off? You can't have a connection to it unless it is powered up and maintaining 13.6 Volts. I leave mine Running when I code, except for coding the DME module.
      10-10-2012, 03:21 PM   #1019
dc_bmw
Netherlands
Drives: BMW 330e
Well, i left it off as the guide did not tell me to start it.
I simply unlocked it, waited a few seconds for the DRLs to turn off, got in, and connected succesfully.
I understand i have to try again with a running engine... will be back in a few minutes.
      10-10-2012, 03:41 PM   #1020
dc_bmw
Netherlands
Drives: BMW 330e
Oke, running the engine solves the timeout problem succesfully.
I've read all CAFDs available. Time to code
      10-10-2012, 04:42 PM   #1021
dc_bmw
Netherlands
Drives: BMW 330e
It worked!
      10-10-2012, 04:58 PM   #1022
dr_squalo
Drives: F10
PM Sent.
Thanks a lot!!!
And I want to mention, that this time the download of the files was rather rapid
4h instead of 10days!
      10-10-2012, 09:04 PM   #1023
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
Guys can you help me out with a quick step by step process to restore my car to its original state? I made a copy of all of my original files before doing any coding. I just wrote a really long letter to BMWNA because my car has MANY issues and i know they are going to tear it apart now. (Issues where there BEFORE coding).
Thanks
      10-11-2012, 02:05 PM   #1024
Quelque
Netherlands
Drives: F30 330e
Export .ncd to text to compare
I would like to compare a certain NCD file of 2 different, yet very similar cars to figure out why a feature does not work on mine but it does on his car. Does anybody have a suggestion how to do this?
If I could somehow export the contents to a text file would already make comparing a lot easier!
      10-11-2012, 02:19 PM   #1025
shawnsheridan
It can't easily be done. The .ncd files are in Motorola S-record Format and require CAFD file data for interpretation. I know someone working on this, who has made some progress, but nothing soon is coming.
For now, the best bet is to open two separate E-Sys sessions with one .ncd file opened in one, and the other .ncd file in the other, and view the FDL Coding side-by-side (it helps to have dual monitors).
      10-11-2012, 02:34 PM   #1026
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Send a message via Yahoo to john08135i
Thanks
Don't remember what you coded? then just go in and change values back to default.
i kept an excel of the ones i changed
M Sport Line Estoril Blue
      10-11-2012, 02:40 PM   #1027
shawnsheridan
Thanks
The easiest thing for you to do (assuming you have not modified your VO in any way) is to simply Read you VO, Read VCM, and then highlight each ECU one at at time, Right-Click on it and select CODE. This "VO Coding" (as opposed to "FDL Coding") will restore each ECU to it's as delivered condition.
      10-11-2012, 11:24 PM   #1028
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
Just a quick question...
Can the Adaptive Light Control feature be enabled on Canadian cars by coding or is hardware required? My car has auto leveling but not Adaptive Light Control.
Originally Posted by Frogman View Post
These are in the 3067 LceTmsCoding2 section:
AHL_DRIVER is AHL, Werte is 01
LWR_DRIVER is initwerte, Werte is 01
AFS_DRIVER is initwerte, Werte is 00
2013, AW, xDrive35i, M Sport Package, Technology Package, Dynamic Comfort Package, Premium Package, 3M Clear Bra, Euro foglight switch, a few coded fixes
      10-12-2012, 01:33 AM   #1029
demge01
demge01's Avatar
Drives: F30 320ed
I had been trying to code this. The fogs as cornering I enabled but no luck with the adaptive Xenons.
This was a while ago and since then
another member has confirmed to me that the hardware is different between adaptive and non adaptive xenons.
      10-12-2012, 07:51 AM   #1030
john08135i
john08135i's Avatar
I really want the cruise control set to ON enabled by default when you start the car..how please?
      10-12-2012, 09:26 AM   #1031
lbjgh
lbjgh's Avatar
Thank you for the info demge01.
It's too bad Canadians are second class BMW owners from BMWNA's perspective.
      10-12-2012, 10:01 AM   #1032
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
Thanks
Gotcha. Thanks a lot.
      10-12-2012, 12:48 PM   #1033
clarence
Drives: F30 328i M-Sport
Are the cheatsheets & other related info on the 1st post in this thread updated after 47 pages of posts?
      10-12-2012, 03:31 PM   #1034
a_k
Drives: F31 328i
Got my cable today and tried read data from my car. It almost went well. I got one error - File for "cafd_000007c8-006_006_002" not found! I assume that car is too new for my data files...
