Extreme Power House
      10-12-2012, 03:37 PM   #1035
dc_bmw
Netherlands
Drives: BMW 330e
Interesting, the FEM_01 ECU contains a settings called:
steuerung_vibration_lenkrad, which in English means: control vibration steering wheel.
It is initialized to 1.
Would the wheel be vibrating even more when set to false? Any volunteers to test his? (i will not )
      10-12-2012, 03:45 PM   #1036
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by a_k View Post
Got my cable today and tried read data from my car. It almost went well. I got one error - File for "cafd_000007c8-006_006_002" not found! I assume that car is too new for my data files...
What Integration Level (I-Step Current) do you show for your car in E-Sys?
      10-12-2012, 04:06 PM   #1037
a_k
Drives: F31 328i
I am not sure. I have to look for instructions for checking it (I know I have seen them in this thread). But I checked the cheat sheet for F30 and I did not find HU_CIC module in my data. There is HU_NBT. I will post I-Step as soon as I find out.
      10-12-2012, 04:09 PM   #1038
demge01
demge01's Avatar
Drives: F30 320ed
Originally Posted by shawnsheridan View Post
The easiest thing for you to do (assuming you have not modified your VO in any way) is to simply Read you VO, Read VCM, and then highlight each ECU one at at time, Right-Click on it and select CODE. This "VO Coding" (as opposed to "FDL Coding") will restore each ECU to it's as delivered condition.
Very useful tip that plus the one about recommending coding with engine running. Would be good to include these in the getting started PDF if Svache is still about.
      10-12-2012, 04:09 PM   #1039
shawnsheridan
Sweet! HU_NBT is the new Head Unit with the upgraded iDrive / Navigation.
Go to Expert Mode, VCM, select the VCM Master Tab, and read Your I-Step, and tell me what I-Step Current shows.
      10-12-2012, 04:20 PM   #1040
a_k
Drives: F31 328i
F020-12-07-533
Regarding HU_TNB - I figured that it would be the new nav, as several functions were with same name as HU_CIC.
      10-12-2012, 04:23 PM   #1041
shawnsheridan
F020-12-07-533
When did you pick your car up from the Dealership?
      10-12-2012, 04:25 PM   #1042
a_k
Drives: F31 328i
Last week. It is F31 328i. September build.
      10-12-2012, 04:29 PM   #1043
shawnsheridan
Well, 47.5 has only 006_006_001 in it. I suspect that the 006_006_002 you have is part of 47.7, which was just pushed to the Dealers, and that your Dealer reprogrammed you car.
What do you show for I-Step Last and I-Step Shipment?
      10-12-2012, 04:31 PM   #1044
dc_bmw
Netherlands
Drives: BMW 330e
I tried to get BMW live working.
My car is equiped with prof nav, enhanced blue tooth, hardware preparation for BMW Assist and BMW onlie.
I change the value of ONLINE_BROWSER_LIVE to aktiv, and tried to combine this (second attempt) with SIM_ENABLED_MB -> CSIM.
THe menu with BMW services (EN: connected drive?) changed. Internet was replaced by BMW live, but it reported it could not show the start screen.
When renewing the service capabilities (last option in menu) a connection to my iPhone 3GS with iOS6 was established (thetering), but the connection was never ever created again.
Apparently, some other setting instructs the car to not use my iPhone. Don't know what that is, but as the car can connect to my phone, i assume the required setting must be somewhere.
Also tried to see RC_DEFAULT_UNLOCK_AT_OPEN_LID1 could keep the car locked when unlocking the boot. But there was no effect: car unlocks completly (the comment on this setting suggests otherwise). Or maybe a sedan has a LID2 instead of a LID1?
      10-12-2012, 04:35 PM   #1045
a_k
Drives: F31 328i
Same F020-12-07-533 in all three boxes.
      10-12-2012, 04:51 PM   #1046
shawnsheridan
Ok. So that is inconclusive.
I believe for the F20, I-Level F020-12-07-533 could be achieved with either ISTA/P 2.47.5 or ISTA/P 2.47.7, which is a common occurrence where one I-Level has multiple ISTA/P's. So, I think the factory put 2.47.5 on it and the dealer updated it to 2.47.7, but the Integration Level was, and remains, F020-12-07-533.
My F10 has 47.7 on it, and it too is at Integration Level F010-12-07-533.
So, now it's a waiting game until the 47.7 PSdZData becomes available.
      10-15-2012, 01:30 AM   #1047
kon
Singapore
Drives: F30 316i
Could someone please share the link to download the programs E-Sys? and datafiles?
THANKS!!!
      10-15-2012, 05:45 AM   #1048
shawnsheridan
THANKS!!!
PM Sent.
      10-15-2012, 11:06 AM   #1049
kon
Singapore
Drives: F30 316i
PM Sent.
Thank you again, much appreciated.
      10-15-2012, 11:10 AM   #1050
Kaitain
Drives: Estoril Blue II F30 M Sport
Shawn,
My car goes into production soon, so now it is time I ask for the files link also please. Thank you very much ahead of time! :-)
      10-15-2012, 11:53 AM   #1051
shawnsheridan
Originally Posted by Kaitain View Post
Shawn,
PM Sent.
      10-15-2012, 03:23 PM   #1052
tigreonak
Drives: 2012 328i Sport Line (F30)
Shawn,
Can you please pm me also the links to e-sys program and data files.
Thanks
      10-15-2012, 03:31 PM   #1053
shawnsheridan
Originally Posted by tigreonak View Post
Shawn,
Thanks
PM Sent.
      10-15-2012, 06:16 PM   #1054
DietCokeOfEvil
DietCokeOfEvil's Avatar
-57
Drives: F10 M5
I am having an issue reading the CAS module on a F10 using PSdZ 47.5 and E-sys 3.18.4 - I can read other modules and have successfully reprogrammed their codes.
Code:
Transaktions-Report:       Aktion: Codierdaten lesen
CAS [40] [C772755]
readCPS o.k.
cafd_0000000f-005_024_221 Fehler:
File for "cafd_0000000f-005_024_221" not found! [C012]
      10-15-2012, 06:55 PM   #1055
auptown
Drives: 2013 F30 328xi
I'm also having a "missing file issue". I'm missing:
cafd_000000794_004_122_077.
My I-step level is F020-12-07-533.
Any ideas for me?
Otherwise I am loving coding!
cheers
Andrew
      10-15-2012, 07:37 PM   #1056
shawnsheridan
Code:
CAS [40] [C772755]
readCPS o.k.
cafd_0000000f.caf.005_024_221 is one of 6 files that were part of the 47.1 release and orphaned when 47.4 was released. I can help you, but I can't PM you with only two posts. Post an email here, and I'll send you a link for what you need.
