Extreme Power House
      10-23-2012, 03:07 AM   #1123
ilhan1103
ilhan1103's Avatar
Drives: f30 318 2012
2012 318D  [0.00]
Originally Posted by shawnsheridan View Post
Yes, but what is standard in Belgium isn't always standard elsewhere, hence really the whole premise or coding ones car. So, behind your standard iDrive option lies an FDL code that must be set to enable that option on non-Belgium cars, that others outside of Belgium will have to code.
True, should have thought about that, my mistake.
Shawnsheridan, would you be so kind as to send me the esys links as well? I'm still not allowed to send or receive pm but I was hoping you could mail it to me?
laraake @ gmail.com
      10-23-2012, 04:20 AM   #1124
rolandleth
Drives: F30 328i
Right-Click on the ECU, select Add or maybe it's New, and then navigate to your corresponding .NCD file to add it. Then select it, and FDL Code the ECU.
Awesome, thanks, yet again!
As for:
1. I modified V_SCHWELLE_1 and V_SCHWELLE_2 within REM_01 AND from within PMA, but the rear view camera and the top view camera still can't be activated at high speeds.
2. In the F10 cheat sheet there is FLA_AUTO_AKTIV under FRM module, it sets High Beam Assistant to Automatic On. Is there a way to do this on the F30? The F30 has no FRM module and I have no idea which one is its "counterpart".
Anyone? Any ideas, please?
      10-23-2012, 08:42 AM   #1125
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
laraake @ gmail.com
You can Receive, just not Send yet. PM Sent.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      10-23-2012, 10:57 PM   #1126
dport
Drives: 2015 M3
Hi,
Can I get a PM w/ a link to the software and data files? Thanks in advance!
      10-23-2012, 11:16 PM   #1127
jjg
Singapore
Drives: f30 320i
Hello & greetings from Singapore. Can I get the link to the E-Sys program & datafiles as well? Thanks, Jeff.
      10-23-2012, 11:21 PM   #1128
shawnsheridan
Originally Posted by dport View Post
Hi,
PM Sent.
      10-23-2012, 11:22 PM   #1129
shawnsheridan
With only 1 Post, you can't receive PM's, so provide an email, or wait until you have more forum posts.
      10-23-2012, 11:26 PM   #1130
jjg
Singapore
Drives: f30 320i
hello shawnsheridan, my email is jefferyjoel@gmail.com Big txs in advance.
      10-23-2012, 11:32 PM   #1131
shawnsheridan
Email sent.
      10-24-2012, 11:33 PM   #1132
dinnef30
Drives: F11 528i
As for:
I did following coding with my 328i Jul-2012 Build and I can confirm that activation of the cameras using the Parking button works at high speeds.
REM-7A1 3203 PdcParkMasterVar V_OFF_PF_R UNKNOWN FF
REM-7A1 3203 PdcParkMasterVar V_SCHWELLE_1 UNKNOWN FF
REM-7A1 3203 PdcParkMasterVar V_SCHWELLE_2 UNKNOWN FF
REM-7A1 3203 PdcParkMasterVar D_SCHWELLE_1 UNKNOWN FF
REM-7A1 3203 PdcParkMasterVar D_SCHWELLE_2 UNKNOWN FF
PMA2-BCE 3003 PdcParkMasterVar V_OFF_PF_R UNKNOWN FF
PMA2-BCE 3003 PdcParkMasterVar V_SCHWELLE_1 UNKNOWN FF
PMA2-BCE 3003 PdcParkMasterVar V_SCHWELLE_2 UNKNOWN FF
PMA2-BCE 3003 PdcParkMasterVar D_SCHWELLE_1 UNKNOWN FF
PMA2-BCE 3003 PdcParkMasterVar D_SCHWELLE_2 UNKNOWN FF
PS: I'm as well interested in automatic-High-Beam-Assitant. No solution found yet.
      10-25-2012, 07:17 PM   #1133
rolandleth
Drives: F30 328i
I actually tried that, changing the values in BOTH modules and it worked. But only the TopView, the rear view camera still didn't work at high speeds. Oh well, I reverted them back to stock anyway, not interesting enough
Now ... I got another little problem.
I was stupid enough to try "Code Default Values" because "Code" gave me an error (no idea why, tried multiple times, some ECUs worked, some not) and I got lots of dumb errors like windows not working, collision detection not working, front camera not working, stuff like this (probably because values were set to "no options on the car"-state). I restored from the latest saved files, now everything is running with no problems.
BUT, I read somewhere about these so-called shadow errors ... Will the dealer see I had all those dumb, theoretically without logic, errors? How can I remove them, if so?
Thanks.
      10-25-2012, 10:47 PM   #1134
shawnsheridan
Thanks.
1) Which modules gave you an error with CODE? Some module have no codeable data like ZGW, RDC, etc., so maybe that is the reason. If the ECU has no CAFD, it has no codeable data, so you won't be able to FDL Code or VO Code it.
2) DON'T EVER HIT CODE DEFAULTS! This codes the ECU to a factory floor condition, and does not use your VO at all. If you mistakenly hit CODE Defaults, then the solution is to CODE afterwards to VO Code the ECU based on your specific vehicle order.
3) I have never heard of "shadow error codes", and I wouldn't worry about them. If the car isn't throwing and error code on the Instrument Cluster or an iDrive Control Message, you should be fine.
      10-25-2012, 10:59 PM   #1135
mokwai
Drives: 116
Hi, can someone email me lawrencetoh@gmail.com the link for E-Sys program & datafiles as well? Thanks in advance. My cable is ready, waiting for the software to proceed.
      10-25-2012, 11:05 PM   #1136
shawnsheridan
Email sent.
      10-25-2012, 11:34 PM   #1137
fgalanda
fgalanda's Avatar
Drives: 2017 F30 330i M Sport EBII
2002 BMW 325i  [0.00]
2006 BMW 325i  [0.00]
2013 BMW 328i  [0.00]
2015 BMW 328i  [0.00]
2017 BMW 330i  [0.00]
Yes, If during dealer programming, the ECU CAFD was updated to a new version, that should be read and backed up as "original", then FDL Coded and backed up "as coded". If the CAFD was not updated, then the last "as coded" backup .ncd could be restored.
Could I have the links for the files as well? Thank you.
I have a question regarding this ^^ because I am not completely sure if I understand your comment. Are you saying that if I code the car and dealer upgrade my ECU CAFD while service, I might not be able to restore it back to original? Does it mean if I want to go back I just have to do it all over again and"manually" code it back? Can you please explain it to me? Can the car be bricked when dealer does update? THANK YOU.
      10-25-2012, 11:51 PM   #1138
shawnsheridan
When the dealer programs your car, and the firmware of an ECU is updated, that is the "new original". There is no going back to the "previous original", nor would you want to. If prior to that you had FDL Coded that ECU, and backed it up, you would not want to restore that .ncd data because it is based on the older firmware. Instead, you would just FDL Code the ECU again, and back it up afterwards. You should only restore .ncd data if the ECU CAFD is currently the same version as the backed up version.
An ECU can be bricked any time it is flashed if something goes wrong, but that has nothing to do with whether or not the module was coded by you or not.
PM Sent.
      10-25-2012, 11:57 PM   #1139
fgalanda
fgalanda's Avatar
PM Sent.
Thank you So basically those back ups are just in case I want to try new things or if I do mistake somewhere so I can go back right away to last known configuration - but in the long run car firmware will get updated eventually anyway, so I might have to code everything again? Thank you.
      10-26-2012, 12:02 AM   #1140
shawnsheridan
That's pretty much it.
      10-26-2012, 04:57 AM   #1141
rolandleth
Drives: F30 328i
Yes, I realized how dumb I was right after, good thing I just had backedup just in case i just restored from the backup, I suppose this was ok too, right?
The FEM_BODY and REM(this doesn't matter anymore, I've done them manually) gave me an error when trying to "Code". I mean it went through the whole process but after clicking "close", in the window that pops at the end where t tells you everything went ok and you can save the report, it told me there was an error, in red fonts. Should have saved it, I guess so I can paste it here
As for shadow codes, there are many talking about them even on these and e90post forums. It's an error that showed up then got fixed by itself so to say, but it remains stores somwhere for the dealer to see it (in the good way, so they can see there was a glitch and might need further investigating).
Also, about what you just explained, about the dealer updating the ECU, how will I know that? That long number of the saved ncd file going to be different than the ECU's, right?
Thanks!
      10-26-2012, 12:38 PM   #1142
jmh
Internet Crash Test Dummy
jmh's Avatar
Drives: F10 M5/F32 435xi
Link to e-sys files
I'd appreciate a link to the E-Sys files/data as well .
jmh at janixworld.com
Thx in advance,
Jan
13 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / Color matched side and front grills (lightly tinted LEDs) / Akrapovic Evolution Exhaust / Hartge Springs / HRE S107
      10-26-2012, 01:10 PM   #1143
rolandleth
Drives: F30 328i
Thx in advance,
Jan
Sent.
      10-26-2012, 02:06 PM   #1144
shawnsheridan
Thanks!
Yes, you will know because after the dealer update, the ECU CAFD file name will be newer.
