VIBE Motorsports
      10-26-2012, 02:26 PM   #1145
rolandleth
Drives: F30 328i
Originally Posted by shawnsheridan View Post
Yes, you will know because after the dealer update, the ECU CAFD file name will be newer.
Right. Thanks! I will come back with an error report when trying to "Code" the FEM_BODY module.
      10-26-2012, 02:55 PM   #1146
demge01
demge01's Avatar
Drives: F30 320ed
MDRIVE
Today I switched on the MDRIVE to aktiv in the HU folders.
Got rather excited at first as it appears that you can customise:
DSC (off, DTC, DSC)
STEERING (comfort, sport, sport+)
THROTTLE (comfort, sport, sport+)
You can have any combination of the above.
However I couldn't get any changes to register.
Anyone?
      10-26-2012, 03:27 PM   #1147
rolandleth
Drives: F30 328i
That's what it says in the cheat sheet, as well, you shouldn't have gotten excited, hehe:
Shows M Drive menu in iDrive, cannot seem to select settings, needs testing.
Would be nice indeed if anyone tested it further, though.
      10-26-2012, 03:48 PM   #1148
demge01
demge01's Avatar
Drives: F30 320ed
Ah yes I see it now.
      10-26-2012, 06:25 PM   #1149
rolandleth
Drives: F30 328i
Update for high beam assistant:
The F10 code for auto highbeam assistant is FLA_AUTO_AKTIV in the FRM module.
The F30 has no FRM module, so I searched in the FEM_BODY for "FLA_" and I found FLA_AKTIVIERUNG, which has Kommentar: "Fernlicht Assistent:0 - FLA (oder KAFAS) nicht verbaut1 - FLA (oder KAFAS) verbaut; Aktivierung bei Lichtschalter in Stellung A (Auto) moglish 2 - FLA (oder KAFAS) verbaut; Aktivierung bei Lichtschalter in Stellung A (Auto) ODER 2 moglich"
There are 3 values for it: LDS_IN_A_oder_2, nicht_aktiv, LDS_in_A (was the default one, I changed it to oder_2 one).
Then I went in the HU_CIC and found HIGH_BEAM_ASSISTANT (Kommentar: Light Settings High Beam Assistant (Fernlichtassistent) and changed it to aktiv. Now i have a checkbox under setings-lights named Highbeam Assistant.
Still no high beam assistant auto start, the checkbox does nothing. Anyone that has more knowledge than me can give his oppinion on my findings, please?
      10-26-2012, 09:31 PM   #1150
sudyawi
Drives: 320i Luxury Line
link request
Greetings from Indonesia!!
I was wondering if anyone would be kind enough to share the download links to e-sys software and data files? Since i am nubie with zero post, had to trouble u by sending them to my email address, sudyawi@gmail.com
Many thanks and hope i can contribute more in the future.
Awi
      10-26-2012, 09:48 PM   #1151
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Awi
PM Sent.
      10-27-2012, 12:56 AM   #1152
clarence
Drives: F30 328i M-Sport
I think it requires additonal hardware which only exist if u spec with adaptive bi-xenons.
      10-27-2012, 12:58 AM   #1153
clarence
Maybe it only works on M-cars.
      10-27-2012, 01:23 AM   #1154
demge01
demge01's Avatar
Drives: F30 320ed
Yes maybe. However the different drive modes (comfort, sport etc) are only really selecting predetermined settings of what is possible to customise in MDRIVE.
I can't see it being a hardware thing.
      10-27-2012, 03:04 AM   #1155
mokwai
Drives: 116
Thanks shawn for the email.
      10-27-2012, 05:47 AM   #1156
rolandleth
Drives: F30 328i
And I do have adaptive bixenons. So that's not it
I DO have high beam assistant, I just want it to auto start when starting the car.
      10-27-2012, 09:49 AM   #1157
shawnsheridan
On the F10's, with older firmware, FRM/3050/FLA_AUTO_AKTIV could be set to "aktiv"; which worked perfectly.
For reasons unknown, on newer firmware it was changed from "aktiv" to "automatik".
With "automatik", FLA automatically turns on when switching on the lights (manually) or if they automatically come on. However, High Beam Assistant is not active when starting the car in the dark (i.e. when the lights automatically turn on with the engine).
Maybe on the F30 it can still be set to "aktiv".
      10-27-2012, 12:33 PM   #1158
rolandleth
Drives: F30 328i
Well, you're right; this is what i want as well, I didn't express myself properly, sorry. Of course the assistant won't start during daylight and with dipped beams off, only when I manually turn them on (or they auto start by keeping lights on (A)). However, this does not happen after changing the above FLA_AKTIVIERUNG.
On the F30 there is no FRM module, nor a FLA_AUTO_AKTIV anywhere else, just the
FEM_BODY/3060(i think?)/FLA_AKTIVIERUNG which only has LDS_IN_A_oder_2, nicht_aktiv, LDS_in_A as values (I wrote a few posts above its Kommentar which I can not really translate).
Aww, that's plain silly, if the car can detect the dipped have to stay on because it's dark, it should be possible to auto turn HBA on as well. Yea, I'm lazy, haha
      10-27-2012, 02:21 PM   #1159
martinf79
martinf79's Avatar
62
Drives: F30 335i M Sport
Sorry .. finally decided I would give this "coding" thing a try.
I disabled my wifi connection - I then connected the cable to my ethernet port, then to the car (car off), nothing, couldn't get a connection.
Tried again (this time w/ the car on). Still nothing.
Tried to run "ZGW_Search.exe". Get an error (given I don't have a connection).
Any thoughts??? What am I doing wrong?
2013 335i ///M-Sport | + 2015 X3 28i xLine
      10-27-2012, 02:24 PM   #1160
shawnsheridan
Is the car ignition turned on?
Where did you get your ENET cable?
Is you LAN Adapter settings set for Auto IP etc.?
What is the laptop OS?
      10-27-2012, 02:30 PM   #1161
martinf79
martinf79's Avatar
62
Ignition is on (actually tried w/ car off, ignition on, car on)
I bought the cable off of another forum user (Raspartan)
Not sure how to check LAN Adaper settings? Please advise and I will check.
Running Windows 7
      10-27-2012, 02:37 PM   #1162
shawnsheridan
I bought the cable off of another forum user.
Running Windows 7
Change TCP/IP settings:
http://windows.microsoft.com/en-US/w...CP-IP-settings
Make sure IP and DNS are set to Auto.
Win7 32-Bit or 64-Bit?
      10-27-2012, 02:43 PM   #1163
martinf79
martinf79's Avatar
62
Both set to auto.
64 bit
      10-27-2012, 02:47 PM   #1164
shawnsheridan
Both set to auto.
64 bit
Let's start there. ZGW_Search.exe will not run on 64-Bit OS. Right-click on it, go to properties, and set it to run in the XP SP2 Compatibility mode.
Launch ZGW_Search.exe, and give it a few minutes to populate.
ZGW_Search.exe though is an informational tool only, and is not needed at all for E-Sys to fucntion. So, regardless of ZGW_Search.exe working or not, launch E-Sys, and see if you can connect to the car.
      10-27-2012, 03:06 PM   #1165
martinf79
martinf79's Avatar
62
it worked! Thanks!
Got ZGW_Search to work. Tried running E-Sys, and was able to connect. Now only problem is, I don't see F30 as a Target option?? lol
You must be getting annoyed by now (apologies, but new at this). lol
      10-27-2012, 03:07 PM   #1166
shawnsheridan
it worked! Thanks!
F020 psdzdata covers the F20 1-series and F30 3-series.
