European Auto Source
      11-16-2012, 07:30 AM   #1233
ilhan1103
ilhan1103's Avatar
Drives: f30 318 2012
2012 318D  [0.00]
Originally Posted by shawnsheridan View Post
Both. Many codes require more than one parameter alone to enable a feature. The codes work in conjunction with each other.
Thanks for clearing that up Shawn
      11-16-2012, 12:21 PM   #1234
Rene_CH
Drives: BMW M550xD
Yes, but those CAFD's are from 47.1, but is the problem that your car has 47.1 on it, or is it that your car has something newer than 47.5 on it?
What are your exact E-Sys "Missing CAFD [CO12]" error messages?
Thank you fro asking back!
My car was produced in Sept 2012 (MY13) and it is 47.5. However, I can not code some very simple features like e.g., HUD turn signals (even if I set the right values) and someone mentioned, that the reason for that could be these six missing files which where included in v47.1 and are missing for some reasons in 47.5.
I do not get any error messages while connecting with esys 3.18.4 to the car, and other features like automatic high beam control work very fine.
Thank you!
René
      11-16-2012, 12:30 PM   #1235
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Thank you!
René
If you need any CAFD file, you will get a [CO012] error message, and will not be able to code the module at all, so that is not the problem here.
I am not sure what is up with your HUD Turnsignals. After coding it, did you enable the checkbox in the iDrive HUD Options too?
      11-16-2012, 02:36 PM   #1236
Rene_CH
Drives: BMW M550xD
I think I set all parameters but this checkbox does not appear?
      11-16-2012, 02:40 PM   #1237
shawnsheridan
I don't know on the F30, but for the F10 it is:
CIC / HUD_TURNSIGNAL
KOMBI / BLINKER_HUD_ENABLE
The 2nd one adds "Turn indicator" Checkbox in Settings=>Heads-Up Display that must be checked to work.
      11-16-2012, 02:59 PM   #1238
Rene_CH
Drives: BMW M550xD
The version I use, it is HU_NBT / 3000 HMI, 98 - I can not find a CIC Module?
      11-16-2012, 03:03 PM   #1239
shawnsheridan
Oh....that explains it. You have the new iDrive system, HU_NBT. I didn't think it was in the F30 yet, but I guess it is, at least in Europe.
Well, the 2013 F10 owners with HU-NBT are having the same problem, so there is something about the new Head Unit where it isn't working. Hopefully it can be figured out or a new BMW Firmware will fix the problem.
      11-16-2012, 03:07 PM   #1240
Rene_CH
Drives: BMW M550xD
Well, the 2013 F10 owners with HU-NBT are having the same problem, so there is something about the new Head Unit where it isn't working. Hopefully it can be figured out or anew BMW Firmware will fix the problem.
Oh I see - THANK YOU SO MUCH!!!
Best wishes from Switzerland,
René
      11-16-2012, 05:55 PM   #1241
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
René
I can't get the HUD turn signals to work on an F30 with a CIC either. I don't know of anyone getting them to work on an F30 yet.
      11-16-2012, 07:35 PM   #1242
shawnsheridan
Well, without a working previous MY 2012 F30, it is difficult to know if it is just not possible on the F30, or if it is due to some new or changed parameter in 2013 models.
      11-17-2012, 01:26 AM   #1243
akeresztes
Drives: 2013 335xi (F31)
Has anyone found the module and code on the F30 to be able to close the trunk from key fob or inside button? This is listed in the F10 cheat sheet and I've heard of similar changes in F30, but I couldn't find these settings.
HKFM > SCH_FBD - Button on key fob will be enabled to CLOSE the trunk
HKFM > SCH_TOEHKI - Button on driver-side will be enabled to CLOSE the trunk
Anyone who got this working, any tips?
      11-17-2012, 01:46 AM   #1244
Frogman
Frogman's Avatar
Sorry, the F30 doesn't have a trunk motor like the F10 does. The F30 just has a spring, so even if you coded it, there isn't any hardware to talk to.
      11-18-2012, 06:56 AM   #1245
dos1973
Drives: F30
coding questions
Hi Guys,
I'm writing from Germany, so sorry for the bad english.
1st of all, yo're doing a great job with this thread ;-)
I have an F30 only with xenon lights without any light assist systems.
Therefore my lights power switch contains only ON/OFF and Parklights, no "A" Automatic Mode.
I get the welcome lighs only when my lights Powerswitch is set to ON.
Is there a code to get the welcome lights no matter the switch is to ON/OFF?
Speedometer lightning:
Is there also code for the Cockpit Speedometer light (Instrumentebeleuchtung), should be always ON no matter if the Lights switch is set to ON or OFF?
would be grateful, to get some codes to achieve this,
Thank you all in advance
bye from Frankfurt
Dos
      11-18-2012, 02:55 PM   #1246
lokito
lokito's Avatar
Drives: 335i ///M Sport
Software source
I'm new to the forum and got a 335i on order and coming in a few weeks, my first BMW! I've been reading around the forum and this is by far is the most interesting and detailed DIY thread I've came across. I wanted to ask if someone could please send me a PM with instructions on how to get the current E-Sys program and datafiles required so I can fire up my laptop and start making modifications once I get the car. I see most of the links have been removed. Any help will be greatly appreciated.
2013 335i ///M-Sport |6MT|Mineral Grey|DHP|PDC|HK|
      11-18-2012, 03:26 PM   #1247
shawnsheridan
E-Sys v.3.18.4 and v.47.7 PSdZData Torrent Link:
http://www.sendspace.com/file/ngwhjf
      11-18-2012, 03:54 PM   #1248
lokito
lokito's Avatar
Awesome! Will give it a shot. Thanks!
      11-19-2012, 07:03 PM   #1249
ivangoh75
Drives: F10 2011
Smile Error in FEM_body module
hi
i got this error while trying to read from FEM_body module
FEM_BODY [40] [NP02424]
readCPS o.k.
cafd_00000794-002_020_029 Fehler:
File for "cafd_00000794-002_020_029" not found! [C012]
Can anyone send me this missing file?
Thanks
      11-20-2012, 12:52 AM   #1250
akeresztes
Thanks Shawn and everyone for the great information on this thread! Did some coding this weekend and got a lot of the changes I wanted, such as unlocking the doors when car is turned off, got rid of disclaimers, automatic start/stop remembering last setting, weatherband, TPMS, and a lot of other changes.
I've had a few problems that I ran into though with some changes that didn't really stick that are related to HUD and wondering if anyone had any luck with those...
1. HUD display time
KOMBI > HUD_CC_MAX_DISPLAY_TIME
- I tried changing werte to 28 which should be ~4 secs, but it seems like 8 was still being used which is the default
2. HUD turn signal
HU_CIC > HUD_TURNSIGNAL > aktiv (werte = 01)
KOMBI > HUD_BLINKER_ENABLE > aktiv (werte = 01)
- I set this up and got the checkbox to show up in iDrive and enabled it, but didn't really make a difference.
3. One thing I also noticed is that while the HD radio checkbox is on for FM and it used to work before, I no longer get the HD broadcasts now or the station information broadcast about the songs. Has anyone had similar problems? I may need to revert to the prior CAFD file for now to see what is up.
      11-20-2012, 06:45 AM   #1251
dcg71
Australia
51
Drives: F15 X5 25d / Ducati Monster
Another thanks for the great info in this thread, particularly to shawnsheridon and svache.
Successfully coded:
- Legal disclaimer removal
- DVD in motion
- ASS remember last setting
- Rear DRLs
Only complication was not having a laptop, so instead I used a power line ethernet adapter to connect the car in the garage to the desktop PC in the house.
Rear DRLs
2015 F15 X5 25d Space Gray | Pure Excellence | Dakota Leather/Brushed Aluminium | Anthracite Head Liner | Fender Flares | Connected Drive + Real Time Traffic
2012 F30 335i Sapphire Black
2006 E92 325i Titan Silver
2000 E46 318i Cosmos Black
      11-20-2012, 08:55 AM   #1252
shawnsheridan
Originally Posted by ivangoh75 View Post
hi
readCPS o.k.
Thanks
I can't PM you. Please provide an email address.
      11-20-2012, 09:00 AM   #1253
shawnsheridan
1. HUD display time
2. HUD turn signal
It seems no one has got the HUD Turn Signals to work on an F30, and for the 2013 Model F10's, it isn't working either. Not sure why yet either.
I have never heard of an HD Radio issue before. You can try and reset your CIC by right clicking on the ECU itself (not the underlying CAFD) and selecting CODE to reset it, and see if it comes back. If it does, redo any CIC FDL Coding you want, one at a time, and check your HD Radio functionality after each change and make sure it continues to work.
      11-20-2012, 08:32 PM   #1254
shawnsheridan
47.5 vs. 48.1 PSdZData CAFD Changes
FYI. The difference from 47.5 to 48.1 for the CAFD folder only is one file removed and 45 added:
Left base folder: D:\ISTA-P_v.47.5_SPdZData\psdzdata
Right base folder: D:\ISTA-P_v.48.1_SPdZData\psdzdata
Left Orphan Files (1)
cafd_00000ded.caf.001_010_004
Right Orphan Files (45)
cafd_000000ae.caf.005_005_002
cafd_000000b5.caf.010_004_002
cafd_000000b6.caf.010_004_002
cafd_000000f9.caf.007_003_002
cafd_000000f9.caf.007_003_020
cafd_000000f9.caf.007_003_022
cafd_000000f9.caf.007_003_167
cafd_00000a3f.caf.005_001_012
cafd_00000a07.caf.002_011_000
cafd_00000a08.caf.003_010_001
cafd_00000b0a.caf.000_022_000
cafd_00000b0a.caf.000_023_000
cafd_00000ddc.caf.001_011_004
cafd_00000ddc.caf.001_012_004
cafd_00000ded.caf.001_020_006
cafd_00000ded.caf.001_020_106
cafd_00000e69.caf.001_020_006
cafd_00000f9b.caf.001_005_102
cafd_000001a7.caf.000_012_000
cafd_000006c6.caf.002_009_003
cafd_000007a1.caf.005_022_031
cafd_000007c8.caf.006_006_002
cafd_000007c8.caf.006_008_003
cafd_000007c8.caf.006_008_007
cafd_000008a2.caf.000_003_010
cafd_000009ef.caf.000_019_001
cafd_0000012f.caf.012_003_014
cafd_00000014.caf.004_051_001
cafd_0000067b.caf.002_003_138
cafd_00000069.caf.009_000_050
cafd_0000106d.caf.012_007_010
cafd_0000106d.caf.012_007_011
cafd_0000124f.caf.000_003_014
cafd_00000223.caf.013_008_002
cafd_00000694.caf.003_003_040
cafd_00000794.caf.004_124_037
cafd_00000794.caf.004_124_038
cafd_00000794.caf.004_124_042
cafd_00000832.caf.002_012_000
cafd_00000893.caf.006_050_003
cafd_00000896.caf.006_023_002
cafd_00000911.caf.003_001_001
cafd_00001016.caf.001_001_004
cafd_00001082.caf.008_000_059
cafd_00001083.caf.008_000_059
