      11-20-2012, 08:53 PM   #1255
Yobyot
Yobyot's Avatar
490
Drives: MY19 X3 M40i
Originally Posted by shawnsheridan View Post
FYI. The difference from 47.5 to 48.1 for the CAFD folder only is one file removed and 45 added:
Left base folder: D:\ISTA-P_v.47.5_SPdZData\psdzdata
Right base folder: D:\ISTA-P_v.48.1_SPdZData\psdzdata
Left Orphan Files (1)
cafd_00000ded.caf.001_010_004
Right Orphan Files (45)
cafd_000000ae.caf.005_005_002
cafd_000000b5.caf.010_004_002
cafd_000000b6.caf.010_004_002
cafd_000000f9.caf.007_003_002
cafd_000000f9.caf.007_003_020
cafd_000000f9.caf.007_003_022
cafd_000000f9.caf.007_003_167
cafd_00000a3f.caf.005_001_012
cafd_00000a07.caf.002_011_000
cafd_00000a08.caf.003_010_001
cafd_00000b0a.caf.000_022_000
cafd_00000b0a.caf.000_023_000
cafd_00000ddc.caf.001_011_004
cafd_00000ddc.caf.001_012_004
cafd_00000ded.caf.001_020_006
cafd_00000ded.caf.001_020_106
cafd_00000e69.caf.001_020_006
cafd_00000f9b.caf.001_005_102
cafd_000001a7.caf.000_012_000
cafd_000006c6.caf.002_009_003
cafd_000007a1.caf.005_022_031
cafd_000007c8.caf.006_006_002
cafd_000007c8.caf.006_008_003
cafd_000007c8.caf.006_008_007
cafd_000008a2.caf.000_003_010
cafd_000009ef.caf.000_019_001
cafd_0000012f.caf.012_003_014
cafd_00000014.caf.004_051_001
cafd_0000067b.caf.002_003_138
cafd_00000069.caf.009_000_050
cafd_0000106d.caf.012_007_010
cafd_0000106d.caf.012_007_011
cafd_0000124f.caf.000_003_014
cafd_00000223.caf.013_008_002
cafd_00000694.caf.003_003_040
cafd_00000794.caf.004_124_037
cafd_00000794.caf.004_124_038
cafd_00000794.caf.004_124_042
cafd_00000832.caf.002_012_000
cafd_00000893.caf.006_050_003
cafd_00000896.caf.006_023_002
cafd_00000911.caf.003_001_001
cafd_00001016.caf.001_001_004
cafd_00001082.caf.008_000_059
cafd_00001083.caf.008_000_059
For those of us who still don't quite understand the intricacies of coding, what does "removing" and "adding" a CAFD file mean.
Does the removed file represent a control unit or option that is no longer supported? What if your car has one of the now-unsupported devices?
On the other hand, does adding new files mean that there's new hardware that isn't in an older car that is now codeable? Or, maybe that existing hardware now has newly exposed functionality?
I often see people asking here for "missing" CAFD files. Does that mean they have hardware they cannot access for coding until they acquire the file?
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29
MY19 X3 M40i:
Produced: 2018-08-15; Delivered 2018-08-22
      11-20-2012, 09:05 PM   #1256
shawnsheridan
shawnsheridan's Avatar
Once released, I have no idea why BMW ever removes a CAFD file from subsequent releases, but for some reason, not often, some drop out. The affected modules are still supported, just not at that firmware version. If you have a module that is currently using an orphaned CAFD, you need to either find the CAFD file from an older PSdZData release, or somehow get the car programmed so that module gets it's firmware updated. The latter is better, but is never the easiest.
The added CAFD's are for existing modules with newer firmware, or entirely new modules for new Chassis or Model Year changes.
If you are missing a CAFD, E-Sys [C012] error, you can not code the module.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      11-21-2012, 05:18 PM   #1257
akeresztes
Drives: 2013 335xi (F31)
Anyone know how to reset check engine light on F30?
I redid my coding on HUCIC module to resolve the HD radio issue (don't think it was a real issue - my reception may just be poor since it works for some stations and not others that were working earlier on other side of town).
Anyways after fixing that, I did some coding on KOMBI module (playing with HUD settings) and when I started car next time the check engine/emissions light was on. I drove to work and back and car seems fine.
Ill be restoring the KOMBI settings but don't though if that will reset the light. Anyone have any tips on how to do that?
      11-21-2012, 05:35 PM   #1258
lokito
lokito's Avatar
Puerto Rico
Drives: 335i ///M Sport
E-Sys v.3.18.4 and v.47.7 PSdZData Torrent Link:
http://www.sendspace.com/file/ngwhjf
So got the files an installed E-sys, no prob. However, can't extract the pdszdata files using Winrar. I got a PSDZDATA 47.7 folder with 30 files (about 20.4Gb total). All files have the same size (700Mb) except the last one (658Mb). The files are named as follows:
psdzdata.7z.001
psdzdata.7z.030
So there's no files extension associated with winrar, Win 7 thinks the 3-digit number portion of the files is the file extension. I'm I supposed to rename every single file in a specific way or add an extension to each file so it will work with Winrar?
Any help will be appreciated.
2013 335i ///M-Sport |6MT|Mineral Grey|DHP|PDC|HK|
      11-21-2012, 07:53 PM   #1259
BikerPilot
Drives: From M6 to ActiveHybrid 3
HUD changes
I traded my 2009 M6 for an Active Hybrid (don't ask, but it has to do with spousal approval...).
Really like the car, but I'm disappointed with the HUD in the Active Hybrid. I need it to show RPM's and current gear selection. Any way to do that? I drive the same route every day and listen to the same radio station every day, so my HUD only shows..... speed.... how boring is that!
I also want the auto folding mirrors, but have seen that that is already possibly by re-coding.
Anyone any success with HUD changes? I'd be more than happy to be the guinea pig? I made coding changes to my M6, so, I'm not unfamiliar.
      11-21-2012, 09:48 PM   #1260
Frogman
Drives: 2012 F30 328i
psdzdata.7z.001
psdzdata.7z.030
They are compressed using 7-zip. You need that to decompress.
The files are broken up into multiple parts. You may need to join them into a singel file. 7-zip may do that for you, I don't know.
I combined the files manually and used WinRAR to decompress.
      11-22-2012, 02:31 AM   #1261
lokito
lokito's Avatar
Puerto Rico
That did the trick! I've been a Winrar fan for years and never used 7-Zip before, wasn't familiar with the extension for it. Now I got go to the electronic store and see if I can find the connector and resistor. Then wait for the car. Thanks a lot for the help.
      11-22-2012, 02:40 AM   #1262
shawnsheridan
Try this.
Assuming the fault condition no longer exists, to clear the fault code.
1) Launch C:\EDIABAS\Bin\TOOL32.EXE
2) Hit F3
3) Load C:\EDIABAS\Ecu\F01.PRG
4) In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL
5) Hit F5
6) "Results" window should show "JOB_STATUS = OKAY"
Hopefully, Problem Solved.
Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
      11-22-2012, 07:49 AM   #1263
BikerPilot
Link
PM Sent.
Shawn, could you please send me the link to E-sys and data files as well? Just traded my M6 for an ActiveHybrid 3 (don't ask!).
      11-22-2012, 09:00 AM   #1264
shawnsheridan
Read this:
Huge thanks to Telefax for sharing this and providing the files.
I've never created a torrent before, this is my first one, so hopefully it works.
The torrent file can be downloaded from here: http://www.sendspace.com/file/ngwhjf
I'm leaving my computer on with it seeding so hopefully we can get the ball rolling for everyone. Let me know how it works. Thanks!
      11-22-2012, 10:09 AM   #1265
SamS
Drives: Tesla M3 Perf + '18 X3 M40i
Rest east, brother. I traded in my '12 M3 for the ActiveHybrid 3
      11-22-2012, 01:28 PM   #1266
vkoprivica
Drives: 2018 BMW g30
Hi, each and every time when I start the engine of my F30, the climate control starts blowing the air. I tried turning off the climate control before I shut the engine off hopping that car will remember last settings but it did not. Is there a way to make computer remember the last setting other than coding?
Thank you.
      11-22-2012, 09:06 PM   #1267
shawnsheridan
Thank you.
Other than coding? No.
      11-22-2012, 09:29 PM   #1268
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
door handle lights in reverse???
i am seeing that in some cars when you put the car in reverse the door handle LED's turn on to light up the ground for the top view cameras. does anyone know how to code this? this function isnt turned on in my car.
      11-23-2012, 02:42 PM   #1269
dos1973
Drives: F30
Could someone please share the link to download the current programs E-Sys? and datafiles for the F30?
please by email: dos1973 at live.de
because i can't get PM (I think)
thank you in advance
      11-23-2012, 08:31 PM   #1270
shawnsheridan
Or you could just scroll up 5 posts to #1264...
      11-24-2012, 03:34 AM   #1271
avgor123
avgor123's Avatar
Russian Federation
Drives: F30 320D Sport
Hello, Shawn,
Can I read and clear ECU errors by the instrumentry of this set in along with coding?
      11-24-2012, 04:50 AM   #1272
kon
Singapore
20
Drives: F30 310i > G20 310i
Anyone manage to download the latest psdzdata 47.7 via torrent? Downloaded the torrent file, but none of the tracker is working...
      11-24-2012, 08:18 AM   #1273
shawnsheridan
Originally Posted by avgor123 View Post
Hello, Shawn,
E-Sys requires EDIABAS to run, and is packaged with it. As I wrote above in Post 1262, you can launch Tool32, F01.prg, fs_lesen_funktional job to read fault codes, and FS_LOESCHEN_FUNKTIONAL job to clear fault codes.
      11-24-2012, 10:22 AM   #1274
avgor123
avgor123's Avatar
Russian Federation
Thank you very much! I'll try this tomorrow.
Do you have a manual about Tool32 and another .PRG files and jobs?
      11-24-2012, 10:25 AM   #1275
shawnsheridan
Sorry, but I don't. There is a general .hlp file available from Tool32, but the .PRG's and their jobs within are not documented that I have ever seen.
      11-24-2012, 09:08 PM   #1276
kon
Singapore
20
Shawn and all,
Could you help this newbie why I couldn't read coding data from my ride?
I'm pretty sure I can find the CAFD file in the psfzdata folder, but it seems my esys program is not reading it
Transaktions-Report: Aktion: Codierdaten lesen
HU_CIC [63] [FXXXXXX]
readCPS o.k.
cafd_000000f9-007_003_007 Fehler:
File for "cafd_000000f9-007_003_007" not found! [C012]
FEM_BODY [40] [FXXXXXX]
readCPS o.k.
cafd_00000794-004_122_082 Fehler:
File for "cafd_00000794-004_122_082" not found! [C012]
