      12-05-2012, 03:13 PM   #1365
TonyS
Drives: F30 335i
Originally Posted by shawnsheridan View Post
Thanks to JEG23, we have Trip Import working using Google
Google Maps is a better and more efficient tool to generate routes than the BMW Navigation System. You have the flexibility to change routes as you wish and select specific roads from point A to point B. The attached manual (and program) describes how you can generate trip files that can be imported into your BMW Nav system. This is possible thanks to the great programing work of our fellow fester, Aussie40d, from the E70 forum. Enjoy.
JEG23
https://rapidshare.com/#!download|35...v.pdf|1505|0|0
https://rapidshare.com/#!download|67...3.xlsm|166|0|0
However, no luck so far on POI import, although it continues to be studied.
Thanks for that Shawn - looks like it's just a matter of time then.
I had a look at what JEG23 has been doing with trip imports and gave it a try just as a test, but it created a very strange route. It was basically correct in that it went down the roads I'd selected in Google Maps, but kept darting off down side roads for a short distance and then asking me to make a U-turn to go back onto the correct route. Very odd. I'll do a bit more playing about with it and then maybe contact him to see what's going wrong.
      12-05-2012, 03:15 PM   #1366
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Must have been in Drug Dealer Delivery Route mode.
      12-06-2012, 06:27 AM   #1367
TonyS
Drives: F30 335i
Damn - my secret is out
      12-06-2012, 08:27 PM   #1368
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
Originally Posted by ilhan1103 View Post
I uploaded a new list today it's one thread down from this one
On this spreadsheet it shows where you can turn on the door handle LED's in reverse. I tried to code this last night and it doesnt exist in the module anywhere. i looked and searched in the FEMBODY module. Am i missing something? Maybe only on newer software?
      12-06-2012, 08:35 PM   #1369
shawnsheridan
Door handle LED's in reverse? What is that exactly?
      12-06-2012, 08:41 PM   #1370
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
In some cars when the car is put in Reverse the LED lights under the door handles will turn on to light up the ground around the car. It seems that if you have your car updated with the ASS in Auto-off position by the dealer that function turns on along with that upgrade although some have it working without the update. Which leads to me to believe it can be coded. I saw that on this spreadsheet but couldn't find it when i was in E-sys last night.
Its a pretty neat feature and from what I hear is really good when you have the top view cameras and are backing up at night.
Here is link to the thread i started on it.
http://www.f30post.com/forums/showthread.php?t=773358
      12-06-2012, 09:41 PM   #1371
shawnsheridan
Interesting. This does not work on my F10 with 47.7 on the car.
      12-06-2012, 09:45 PM   #1372
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
yeah it seems to be an elusive trick that some have and some dont.
      12-07-2012, 01:28 AM   #1373
ilhan1103
ilhan1103's Avatar
Drives: f30 318 2012
2012 318D  [0.00]
Fembody 3070 OVT_BEI_RUECKFAHRLICHT
This is what enabled that on my f30. No idea where it would be on the 5 series, but like said before its nice to see the sides in dark area's
      12-07-2012, 01:49 AM   #1374
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
This value is aktiv by default on my US F30.
I'll have to see if the lights come on when I put it in reverse. I've never looked or noticed before!
      12-07-2012, 10:30 AM   #1375
shawnsheridan
And you are positive though that this is the code on yours that enables this?
What is the name your FEM_BODY CAFD?
      12-07-2012, 11:23 AM   #1376
ilhan1103
ilhan1103's Avatar
2012 318D  [0.00]
I am certain this did it on my car. It was the only value changed in that session if I'm not mistaken. Just for you, I will swap that value on and of this evening to confirm again.
My fembody file's name is CAFD_00000794_004_124_042
      12-07-2012, 07:19 PM   #1377
ilhan1103
ilhan1103's Avatar
2012 318D  [0.00]
Ok I just tested this again for Shawn.
Connected to car, opened fembody ecu. The ONLY thing I changed was the ovt_ruckfaerthingy to nicht aktiv ( the default value for me) save, disconnect etc.
I put the car in reverse and presto: no more door handle LEDs.
I connected again with esys and put the ovt to aktiv (again nothing else touched) save, close, ...
Viola: door LEDs when in reverse
      12-08-2012, 01:49 PM   #1378
Frogman
Frogman's Avatar
I confirmed this yesterday.
Engaging reverse lights up all 4 exterior door handle lights. Very nice! That should improve visibility to other drivers when backing out of parking spots at night.
      12-08-2012, 05:00 PM   #1379
shawnsheridan
Thanks! Not in F10 FRM or KAFAS ECU's though.
      12-09-2012, 03:44 PM   #1380
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
Can you give me the module again that this in? I know it says FEMBODY 3070 but i couldnt find it there. What version software is your car running? Does the headlights have to be on?
      12-09-2012, 04:05 PM   #1381
Untouchable69
Drives: X328D Carbon Black M-Sport
Hey guys, giving this a crack tonight. Just wondering if their is a newer cheat sheet or software than what's on the first page of this thread.
Your help is appreciated!
      12-09-2012, 06:45 PM   #1382
ilhan1103
ilhan1103's Avatar
2012 318D  [0.00]
Fembody - 3070 LciMaster, 17 - OVT_BEI_RUECKFAHRLICHT
Did you have the lightpackage? maybe the value isnt there if your car doesn't come equiped with the leds perhaps?
      12-12-2012, 03:44 PM   #1383
Quelque
Netherlands
Drives: F30 330e
Hi Ilhan,
I have looked up this interesting setting in my F30, but it is not there. I do have the lighting package like you have. I believe your car was flashed a couple of weeks ago? Do you recall if this OVT_BEI_RUECKFAHRLICHT was there before the car was flashed?
Below you can see my FEM_BODY 3070 LciMaster, 17, could you tell me where in between two other settings you have the OVT_BEI_RUECKFAHRLICHT? Maybe it is one of those UNBELEGT entries ;-)
I might have to upgrade the E-sys as well, maybe that helps, as your CAFD file name is slightly different too.
      12-12-2012, 04:04 PM   #1384
shawnsheridan
Originally Posted by Quelque View Post
Hi Ilhan,
A new E-Sys won't change anything. Either your CAFD has the FDL entry (or similar) or it doesn't. Flashing FEM_BODY though with new firmware could produce a new CAFD with the FDL entry.
      12-12-2012, 04:08 PM   #1385
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Send a message via Yahoo to john08135i
I wonder if we can code the door handle lights to work the entire time your headlights are on? I think that would look cool.
M Sport Line Estoril Blue
      12-12-2012, 04:14 PM   #1386
ilhan1103
ilhan1103's Avatar
2012 318D  [0.00]
Hi Ilhan,
Hiya mate.
It's odd you don't have the entry indeed. You do have those LEDs on your door handle don't you?
I'm willing to check it out for you if you send me your file. But of the top of my head I can't say anything that shawn didn't say.
I can always be wrong, but I had the ovt ruck gang thingy before the update.
PS: who showed you my Cafd file name?? its supposed to be a well guarded secret
