      12-24-2012, 03:11 AM   #1497
zeezz
Drives: F30 328i Sport Line
Originally Posted by awhk View Post
Thanks for your input.
I think disabling the cold and warm checks won't affect the actual functions of the lights. The car just won't tell you which bulb is out.
TFL_L or R: front LED corona rings L or R
NSW_L or R: front fog lights
FRA_V_L or R: front turn signals
FRA_Z_L or R: most likely mirror turn signals as the setting is set to LED as default
AL_L or R: low beam
FL_L or R: high beam
POL_L or R: are LEDs according to the settings, maybe the parking light strips on the tail lights.
If the above is correct and AL/FL represents low beam/high beam, then BIX is free-up. The following 2 are either rear turn signals or brake lights? but there is also reverse and rear fog lights (maybe in the LCI entries)... hmm... need to do some testing over Christmas.
SML_L or R: not LED
BIX_L or R: not LED
LCI_0: LED
LCI_1: LED
LCI_2: not LED
LCI_3: LED
LCI_4: LED
LCI_5: LED
LCI_6: LED
LCI_7: LED
LCI_8: LED
I tried SML_L but it didn't fix my problem. Basically, the rear turn signals flicker since I changed them to "error free" LEDs... they work fine and are off most of the time, but upon starting the car they flicker very quick for 1 second (I'm assuming this may be the 'cold check') and then flicker every 5 minutes for a split second while the car is on (this may be the 'warm check').
Very odd that we don't have a FRA_H series (like the X3)... I checked both SML and BIX and they already have the warm/cold coding disabled even though they are not LED. Maybe I read that wrong.
      12-24-2012, 10:32 AM   #1498
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Originally Posted by kon View Post
Could you elaborate more on this procedure, don't quite get where to select the "VIN at the top of the SVT and selecting code"... Sounds like a good thing to learn in case I screw up and break something while playing with FDL...
I'm perfectly alright to recode those minor changes that I code using FDL, not that many
After you read VCM and activate FA, at the top of your SVT is your VIN. If you right-click on the VIN and select Code, you will VO Code the entire car (all ECU's).
Name:  SVT - VIN - VO Code.png
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      12-24-2012, 11:35 AM   #1499
kon
Singapore
Drives: F30 316i
Woo! Thanks Shawn!!!
      12-24-2012, 11:45 AM   #1500
imfloflo
France
Drives: F30 320d
Thanks, this topic was very usefull for my new 320D F30.
      12-24-2012, 11:52 AM   #1501
rolandleth
Drives: F30 328i
Originally Posted by shawnsheridan
A new E-Sys won't change anything. Either your CAFD has the FDL entry (or similar) or it doesn't. Flashing FEM_BODY though with new firmware could produce a new CAFD with the FDL entry.
How do you flash it with new firmare?
Suppose it's not a simple "use latest psdzdata files", right?
      12-24-2012, 12:51 PM   #1502
shawnsheridan
Flashing new firmware is possible with just E-Sys and the PSdZData.
Myself and a 3 other Bimmerfest members are working on a DIY Flashing Guide for this; however, it is incredibly risky. And while we have successfully flashed several modules, just last week we bricked a Head Unit.
So, until I am convinced the process is 100% documented and accurate, and all risk has been minimized, the DIY Flashing Guide will not be published.
      12-24-2012, 04:13 PM   #1503
dos1973
Drives: F30
Hi,
did somebody code this:
Another thing that the extended bluetooth option provides, is the ability to have 2 phones active at the same time.
Calls received from either phone will come through, but outgoing calls will go through the primary phone. The Bluetooth menu provides an option to swap primary and secondary to make outgoing calls on the other phone.
This in contrast to the 'basic' bluetooth where you can have 4 phones linked, but only 1 phone active at any point in time.
found something in the COMBOX_MEDIA
- handsfree_secondary, set this to aktive
and in HUCIC
hfp_audio_profile
but nothing happened?
Thank you
      12-24-2012, 04:43 PM   #1504
ilhan1103
ilhan1103's Avatar
Drives: f30 318 2012
2012 318D  [0.00]
Originally Posted by dos1973
Hi,
and in HUCIC
hfp_audio_profile
Thank you
I'll check those values on my car. But what you described was possible by default here and I don't have extended Bluetooth
      12-24-2012, 05:13 PM   #1505
dos1973
Drives: F30
This is what i'm looking for.
I'd like to enabel these feature.... If possible.
I have also only the "small" BT.
      12-24-2012, 06:51 PM   #1506
clarence
Drives: F30 328i M-Sport
Originally Posted by shawnsheridan View Post
Nothing is simple.
1) You would use FA Editor to add PDC Option to VO, then write the VO to the CAR. If you do not write it to the car's VCM, then future dealer programming will wipe it out.
2) I assume the retrofit kit comes with a module, so after connected, it should appear in your SVT, but you will need to use Detect CAF for SWE to add the CAFD to it, then VO Code the module.
3) You will also need to code other affected modules, which I imagine would be KOMBI and HU_CIC, and maybe FEM_BODY.
The easiest thing to do is VO Code the entire car to be safe, which you can do also by selecting your VIN at the top of the SVT and selecting CODE. Since VO Coding though codes the entire module, in this case every module, it will overide and FDL Coding you may have done, and you will need to come back afterwards and redo it.
This only applies to retrofits which involve additional hardware modules?
      12-24-2012, 07:20 PM   #1507
shawnsheridan
I'm sorry, but I do not understand your question.
You can use Detect CAF for SWE for adding newer CAFD's or determining which files to be used to create an SVT Target (SVT_soll) to flash new firmware, and of course you can VO Code any module or the entire SVT any time you want.
      12-25-2012, 06:44 AM   #1508
clarence
I mean if u retrofit stuff such as PDC u'll physically install an additional hardware module, whereas other "retrofits" are done to enable features that are market specific. So in the latter case do we still need to use detect CAF?
      12-25-2012, 09:20 AM   #1509
shawnsheridan
No. Only if a new ECU is added would you need to use Detect CAF for SWE.
      12-25-2012, 10:45 AM   #1510
kon
Singapore
Drives: F30 316i
Originally Posted by dos1973 View Post
Hi,
and in HUCIC
hfp_audio_profile
Thank you
Did you enable the feature in Bluetooth option? For us, we have to select/tick for the additional phone feature to work. Them when u pair a phone you'll select it as main or additional phone
      12-25-2012, 12:28 PM   #1511
dos1973
Drives: F30
I don't have any options. Can only pair the phone and tick audio/music. Nothing more :-(
Can you post me a screenshot how this looks like. Maybe i have to search for more values...
edit: got it :-)
you need:
HU_CIC
SECONDARY_HFP = aktiv
Combox_Media
HANDSFREE_SECONDARY = aktiv
now I'm able to support my iphone and BB by Bt, without the need to switch.
      12-26-2012, 01:08 AM   #1512
awhk
Drives: 2012 RS4
Good news, I was able to find the taillight entries from module REF 01, the entries matches the F25 ones perfectly. Here is the chart showing the light entries of my F30 with the default Cold, Warm and LED settings (A = Active, NA = Not Active).
EDIT: REF01 should be REM
      12-26-2012, 11:08 AM   #1513
dos1973
Drives: F30
edit: got it :-)
you need:
HU_CIC
Combox_Media
Hi can someone with extendet bluetooh tell me what vaule is set to
HUCIC
hfp_audio_profile
Thank you
      12-26-2012, 11:55 AM   #1514
Yobyot
Yobyot's Avatar
30
Drives: MY12 F30 ZSL
Wow...you guys are, as usual, expanding the frontiers of what's possible with coding. The whole community is grateful, even if you never publish the guide.
I just gotta ask: what happened with the bricked head unit? Was it possible to unbrick it by loading the original firmware?
MY12 335i ZSL with a deep dive into the options list
Produced: 2012-06-22
ED: 2012-07-19; Arrived in Jersey City: 2012-08-23
Redelivered: 2012-09-12
      12-26-2012, 12:24 PM   #1515
shawnsheridan
There is a way to generate the SVT Target file automatically, which is preferred, and of course it can also be done manually. In some instances, the automatic generation does not work, and we have no idea why, yet anyway, so the manual method must be employed, which is very risky. It is assumed that during this manual SVT Target creation, a mistake was made.
The car goes in for service today I think. I am not sure if it can be recovered with ISTA/P or if the unit will need to be replaced. We shall see.
      12-26-2012, 12:42 PM   #1516
Yobyot
Yobyot's Avatar
30
Well, I didn't understand the answer (my coding experience is limited to trying things from the cheat sheet -- the relationship of all the parts is beyond me) but I hope you get your head unit back!
      12-26-2012, 12:56 PM   #1517
shawnsheridan
Well, thankfully it is not my personal Head Unit, but we appreciate the sentiment.
      12-26-2012, 06:16 PM   #1518
dos1973
Drives: F30
There is a new BT/USB Update at BMW available
- UPD01006
Will this overwrite my codings...?
I have enabled BT Musik by coding...
Thnak you
