      12-26-2012, 06:39 PM   #1519
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by dos1973 View Post
There is a new BT/USB Update at BMW available
- UPD01006
Will this overwrite my codings...?
I have enabled BT Musik by coding...
Thnak you
Yes, but just your Combox coding.
      12-26-2012, 07:48 PM   #1520
dos1973
Drives: F30
Hi can someone with extendet bluetooh tell me what vaule is set to
HUCIC
hfp_audio_profile
Thank you
Please....
Thanks shawn for the info about updating..
      12-26-2012, 08:45 PM   #1521
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
HUCIC
hfp_audio_profile
Thank you
On my US 2012 F30 with BMW Assist, this is set to profile_5 (Werte=04).
      12-26-2012, 09:30 PM   #1522
dos1973
Drives: F30
Thanks frogman
Same by my german f30 model.
This solution with the 2nd phone is so stupid!
When the 1st phone isn't available the 2nd can only receive calls
Otherwise you hve to change in the settings...
Do i need more investigation on this, could you doublecheck this feature is correct?
      12-26-2012, 10:00 PM   #1523
zeezz
Drives: F30 328i Sport Line
Originally Posted by awhk View Post
Good news, I was able to find the taillight entries from module REF 01, the entries matches the F25 ones perfectly. Here is the chart showing the light entries of my F30 with the default Cold, Warm and LED settings (A = Active, NA = Not Active).
Thank you awhk!! Not sure if I have an older version, but my module was REM_01 (instead of REF_01). I was able to turn the cold/warm check off for my rear turn signals and now am pretty sure that they do not flicker at all! This made my week. Excellent work!
      12-26-2012, 11:01 PM   #1524
awhk
Drives: 2012 RS4
That's great to know. Did you change the bulb setting "IS LED" to active?
BTW, do you mind sharing which LED bulbs you are using? How are they performing against stock bulbs?
      12-26-2012, 11:32 PM   #1525
scottg61376
Drives: 08 M Coupe;14 M6;17 X6M;18 X5M
I have a 2010 750Li which I know that this will work for, but what about a 2013 X5...does that require the E series process since it hasn't been updated yet to "F" status?
      12-26-2012, 11:42 PM   #1526
shawnsheridan
The concepts are the same, but different tools are needed. Your E70 X5 requires a K+DCAN USB Interface Cable, and NCS expert Software to Code instead of an ENET Interface Cable and E-Sys Software.
      12-28-2012, 11:36 AM   #1527
dos1973
Drives: F30
Hi,
Can I get rid of the Y-cable (Iphone) during coding?
I there any hardware dependency? Do I have to change the USB/Aux plug?
What hard/software requirements are necessary to use the normal Apple usb cable?
Why:
I'd like to enable the coverart music from my iphone - This all I want.
After reading in several forum and sites I recognized, displaying coverart by Y-Cable is not possible, isn't it
I have in my f30 only Navi Prof, with the base BT.
I have NOT the extendet Bluetooth
I have CIC and I have the combox. (i think so)
I was able to code:
BT Musik streaming
2nd Handsfree phone
Coverart when using an USB Stick.
When connecting the iphone by Y-Cable I have only the "Placeholder" for the cover. Music playing is everything great.
(no connection possible with the white Apple cable)
please help me, and hopefully this is not to bad english ;-)
      12-28-2012, 12:20 PM   #1528
clarence
Drives: F30 328i M-Sport
Hi,
Why:
I was able to code:
BT Musik streaming
2nd Handsfree phone
U said u have combox, that means u have enhanced BT. If u have combox then no need for the Y-cable.
Can u PM me ur option codes using www.bmwvin.com?
      12-28-2012, 12:29 PM   #1529
shawnsheridan
Hi,
Why:
I was able to code:
BT Musik streaming
2nd Handsfree phone
Without BT Enhnaced, what did you code to get BT Streaming and USB Albumn Art?
      12-28-2012, 12:38 PM   #1530
dos1973
Drives: F30
@clarence
This is my vin:edited
@shawn, i have documented all values in an xls file. Maybe not everything is necessary ;-) But still works. Whats your mailadress, i'll send you the file
      12-28-2012, 12:59 PM   #1531
shawnsheridan
@clarence
This is my vin XXXXXXX
Thanks. I PM'd you it.
      12-28-2012, 01:10 PM   #1532
dos1973
Drives: F30
mail is out
      12-28-2012, 01:42 PM   #1533
shawnsheridan
@clarence
Interesting. According to your VIN, you have Basic BT, 6NH, but you also have 609 Nav Pro. I thought for 609 Nav Pro, you had to have BT Enhanced, 6NK/6NL.
      12-28-2012, 01:46 PM   #1534
Frogman
Frogman's Avatar
In the US, you can have 609 without the Enhanced BT combox.
      12-28-2012, 01:49 PM   #1535
Frogman
Frogman's Avatar
Thanks frogman
Yeah, I think you are right. There is a specific option to swap the primary and secondary phones. It might be tied to the fob, which would help. You can also probably program it to one of the buttons.
I agree that the whole way BMW handles BT and phones is a bit screwy and arcane.
      12-28-2012, 02:12 PM   #1536
dos1973
Drives: F30
No in Germany when u take 609 Navi Pro you'll get also 6nh
but what is blocking my white usb cable?
      12-28-2012, 02:21 PM   #1537
dos1973
Drives: F30
Thanks frogman
I have the button to switch, but only when both phones are available...
This could be so easy...
      12-28-2012, 02:25 PM   #1538
Frogman
Frogman's Avatar
Like Shawn said, you need the 6NK or 6NL combox to support the Apple white cable. It's a hardware thing. I don't think you can code around it.
      12-28-2012, 02:28 PM   #1539
shawnsheridan
Yes, and it seems [HU_CICHB] has built in Combox, as he has [Combox_Media] in his SVT.
The question remains how to enable BT Audio with 6NH and No 609 Nav.
For someone with 6NH and no 609 NAV, what is the name of your CIC Module? Is it also [HU_CICHB], or is it something else?
      12-28-2012, 02:31 PM   #1540
shawnsheridan
He has Combox built into his Head Unit with 6NH only, because of having 609 it seems.
