      12-29-2012, 03:22 PM   #1563
dos1973
Drives: F30
Originally Posted by shawnsheridan View Post
Good deal.
So now you use the White Apple Y-Cable or not though?
Yes... only the white apple cable
      12-29-2012, 03:58 PM   #1564
dos1973
Drives: F30
and cover also are displayed ;-)
      12-29-2012, 05:24 PM   #1565
clarence
Drives: F30 328i M-Sport
So, it sure seems like it to me that he has 6NH and Combox.
So wht's the point of 6NK w/609 (i.e. combox in the boot) when they can just code the CIC from factory w/all the features of 6NK?
      12-29-2012, 05:27 PM   #1566
clarence
now I have all features i wanted
Can u take out the boot floor covering & see if u have a silver rectangular box on the left hand side of ur fusebox?
      12-29-2012, 05:34 PM   #1567
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
I have no idea. I just know his VO has only 6NH and 609, yet he has Combox in SVT that he coded.
I think 6NH without NAV gets you HU_ENTRY Head Unit and no Combox, and 6NH with NAV gets you HU_CICHB and Combox.
The Combox must be needed to support 609 so they include it, but they don't enable the enhanced BT functions since one is not paying the premium for 6NK.
      12-29-2012, 05:45 PM   #1568
dos1973
Drives: F30
sorry, please easy english... i'm german ;-)
this means I don't understand what to do for you
      12-29-2012, 05:57 PM   #1569
demge01
demge01's Avatar
Drives: F30 320ed
I have HU_CICHB but no NAV and have 6NH.
I have no COMBOX in the boot or MEDIA/COMBOX module in my CAF list...
      12-29-2012, 06:05 PM   #1570
shawnsheridan
Ok. So you then can have HU_ENTRY or HU_CICHB with no NAV, and no Combox, but add NAV, and you get Combox it seems, and NAV also may require HU_CICHB upgrade.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      12-30-2012, 01:10 AM   #1571
ewill858
Drives: 2013 335i M-Sport
First time coder here, and I'd appreciate any advice regarding the following:
I was successfully able to code several CAFD modules, but encountered both "Adaptive headlight malfunction" and "Active Blind Spot Malfunction" errors when writing my changes to the FEM_BODY module. These included the folding mirrors and unlock doors features.
I tried resetting the FEM_BODY to the default (via the "code" option on the ECU), and re-coding the changes, but the malfunctions occurred again.
Has anyone encountered these errors? I haven't had the chance to see if these errors manifest themselves as real issues in actual driving, but it's a bit unnerving seeing these.
On a related note, is it generally acceptable to change several settings within a CAFD at a time, and then write the changes together? Do I need to turn off/on the car between writes? I'm wondering if my problems were the result of trying to change too many things simultaneously.
Thanks!
      12-30-2012, 01:17 AM   #1572
shawnsheridan
Thanks!
Generally, if the FDL Codes are know to me and proven to work, I make all the FDL Changes for the whole module, and then write them all at once.
If I am testing unknown or unproven FDL Codes, then I do only at one at a time to see the impact of just that single FDL Code.
So are all your errors cleared now, or do you still have problems?
      12-30-2012, 01:51 AM   #1573
clarence
Entfernen Sie bitte die Kofferraumboden, Sie haben eine silberne kasten neben dem Sicherungskasten?
      12-30-2012, 01:52 AM   #1574
ewill858
Appreciate the quick reply, Shawn! I went out to try again, but now e-sys can't read the VIN from the car. I tried restarting the car/laptop but still no luck. The ZGW_SEARCH tool shows the same loss of communication. I double-checked my homemade cable and all the solder joints still look solid, so I'm a bit at a loss, since everything was communicating fine earlier this evening.
Has anyone ever encountered a sudden loss of communications with e-sys, and then found a way to get it to work again? BTW, I'm on Windows 7/64. I saw some posts about compatibility issues, but I never saw any problems. I've been running all apps "as administrator".
Thanks!
      12-30-2012, 02:34 AM   #1575
ewill858
Thanks!
Update: Rebooted PC, disabled as many background apps as possible, and waited after connecting ENET cable until it was done "thinking" about the connection, and communications are up again.
I'm still seeing the Adaptive headlight / Active Blind Spot Detection Malfunctions upon coding the FEM_BODY modules.
The thing that is concerning me at this stage is that even when I reset the module (by applying "code" to the ECU), I still see one or both malfunctions upon completion of the code.
Additional information: I'm coding an F30/335i M-sport with ZDA
One more question: if I want to try restoring all my changes, is there a convenient way to do this efficiently? Or do I have to apply "code" to each ECU that has changed?
Thanks!
      12-30-2012, 11:00 AM   #1576
shawnsheridan
Thanks!
You can VO Code the entire SVT in one shot. See my post here:
http://www.f30post.com/forums/showpo...postcount=1498
If you have residual errors on you car, you can use Tool32 to try and clear them. See my post here:
http://www.f30post.com/forums/showpo...postcount=1262
      12-30-2012, 11:30 PM   #1577
MacBlack335i
MacBlack335i's Avatar
Drives: 335i
Shawnsheridan, Can you please PM me the link for the E-Sys program.
Thanks!..
      12-30-2012, 11:42 PM   #1578
shawnsheridan
Thanks!..
PM sent.
      12-31-2012, 01:48 AM   #1579
johnnytyler24
Drives: BMW 3-series
Shawn could you please PM me the E-sys file and latest data files. Thanks.
      12-31-2012, 08:31 AM   #1580
shawnsheridan
PM sent.
      12-31-2012, 03:25 PM   #1581
dos1973
Drives: F30
Yes, I have one...
      12-31-2012, 03:39 PM   #1582
shawnsheridan
Yes, I have one...
And that my friend is a HARMAN ECE BMW Combox Blutooth Module, P/N 9 257 150-01.
So, now we know your E-Sys SVT wasn't lying to you.
You have 6NH Bluetooth Basic and a Combox.
      12-31-2012, 03:57 PM   #1583
dos1973
Drives: F30
is this the same, as when i would have ordered the extenden BT?
This means all feture of the exteneded bT would be codable?
actually Office function should work also with this? isnt't it
      12-31-2012, 04:04 PM   #1584
shawnsheridan
This is the same Combox unit that comes with 6NK, so you should be able to code Office as well. Of course you will need a phone that supports Bluetooth Message Access Profile (MAP).
