      12-31-2012, 04:59 PM   #1585
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
Originally Posted by dos1973 View Post
is this the same, as when i would have ordered the extenden BT?
This means all feture of the exteneded bT would be codable?
actually Office function should work also with this? isnt't it
I have 6NL (with Extended BT) on my 2012 F30.
My combox part number is 9 257 153-01.
      12-31-2012, 05:01 PM   #1586
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Yes, and you have a Telematics Combox (w/ BMW Assist), not a Media Combox.
There are no differences (e.g. Bluetooth) between the two except Telematics (BMW Assist).
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      12-31-2012, 06:58 PM   #1587
Yobyot
Yobyot's Avatar
30
Drives: MY12 F30 ZSL
Well, some interesting news others who are concerned about coding might find interesting.
I brought my car in for service because the hood wouldn't latch.
While in the shop, they applied a "recall" to the car, SIB 61 36 12. (Does anyone have access to the bulletin? I'd like to know what it was for.)
Two things: the reprogram wiped all the options -- disclaimer is back, weather band is gone, fob control of the mirrors is gone, etc. Second, the dealer didn't say a word about the coding and, apparently, the car took the "reset to factory" just fine.
So, those of you who are worried that your dealer will notice the coding need not worry any more.
MY12 335i ZSL with a deep dive into the options list
Produced: 2012-06-22
ED: 2012-07-19; Arrived in Jersey City: 2012-08-23
Redelivered: 2012-09-12
      12-31-2012, 07:23 PM   #1588
mdallas
Drives: 2016 F15 X5 35i
..so I had this the other day at the dealer:
"....and found fault code stored for coding DME and CAS moduls,performed test plans indicate to reprogram vehicle per SIB# 61 38 12
cleared faults and programmed vehicle."
...sounds like they know......
2013 F25 35i
      12-31-2012, 07:48 PM   #1589
chip2058
chip2058's Avatar
Drives: 2012 328i Sportline
Had this the other day too. It's a recall involving the FEM_Body module and electrical shorts due to the original coding (from my understanding). They rebuild the car to the latest version which unfortunately is 48.2 (which I don't believe is available yet).
They knew I had programmed the car because they commented on finding the OBD cable in my glove box while fixing trim. I don't think they care.
Well while I may have lost all my fantastic programmed options I now have the pleasure of seeing the BMW text logo on the dashboard when I unlock the car. What a fantastic recall! (sarcasm)
      12-31-2012, 08:05 PM   #1590
Yobyot
Yobyot's Avatar
30
Thanks.
I always had the BMW text.
Would I be foolish to try re-coding the options with the previous level of PSDZdata I have (not sure of the level)?
      12-31-2012, 08:59 PM   #1591
shawnsheridan
2013 F25 35i
No, it does not. Those fault codes can be caused by anything. They have no way of knowing if they were coding induced.
The car had fault codes as happens, and they cleared them and reprogrammed the car. This is normal stuff to them, coded or not.
      12-31-2012, 09:04 PM   #1592
shawnsheridan
Thanks.
No, you wouldn't be. Worst case scenario is that you will encounter a module(s) that you simply cant read the coding data from, and you will get a [C012] missing CAFD error in E-Sys; however, you can do no harm.
The newer the PSdZData you are using, the less likelihood of that occurring is, so you would want to use 48.1 if at all possible.
      12-31-2012, 09:11 PM   #1593
shawnsheridan
If you don't like the new BMW Logo, you can change it to the M-Performance Logo I think with KOMBI / BMW_LOGO = mpm:
      12-31-2012, 09:51 PM   #1594
Yobyot
Yobyot's Avatar
30
Thank you very much for the advice! I think I am using 46.3.
If you wouldn't mind PM'ing me with links for something more recent, I'd appreciate it.
Happy new year!
      12-31-2012, 09:52 PM   #1595
Yobyot
Yobyot's Avatar
30
Attachment 802118
Attachment 802119
Attachment 802120
This is so freakin' cool! Almost as good as actually having the M Performance package!
      12-31-2012, 10:40 PM   #1596
shawnsheridan
Happy new year!
PM sent.
      12-31-2012, 11:10 PM   #1597
Yobyot
Yobyot's Avatar
30
PM sent.
Thanks!
      01-01-2013, 03:53 AM   #1598
kon
Singapore
Drives: F30 316i
This is the same Combox unit that comes with 6NK, so you should be able to code Office as well. Of course you will need a phone that supports Bluetooth Message Access Profile (MAP).
Require fsc code for office? Or code in as new fa? Is there an option code for office?
      01-01-2013, 04:34 AM   #1599
kon
Singapore
Drives: F30 316i
Anyone tried this in KOMBI?
GPS_UHR
Kommentar=Uhrsynchronisation ueber GPS aktivieren
Google translate:
Comment = Clock synchronization by GPS enabled
      01-01-2013, 04:49 AM   #1600
demge01
demge01's Avatar
Drives: F30 320ed
Yes, I have one...
And that my friend is a HARMAN ECE BMW Combox Blutooth Module, P/N 9 257 150-01.
So, now we know your E-Sys SVT wasn't lying to you.
You have 6NH Bluetooth Basic and a Combox.
Shawn how easy are these to fit, set up and add the relevant CAF etc?
      01-01-2013, 04:55 AM   #1601
kon
Singapore
Drives: F30 316i
Attachment 802118
Attachment 802119
Attachment 802120
My next must have mod!
      01-01-2013, 06:22 AM   #1602
clarence
Drives: F30 328i M-Sport
Check the ETK, I think u may need a new headunit if u want to fit the combox cos the hardware structure is different between a CIC & L7 Entry headunit.
      01-01-2013, 06:23 AM   #1603
clarence
Should not. As I said before, on the F10 at least, if u remove the country controller from the VO the office menu reappears.
      01-01-2013, 06:25 AM   #1604
clarence
Attachment 802120
Wht are the other options apart from "mpm"?
      01-01-2013, 06:27 AM   #1605
clarence
Yes, u have most features that 6NK have, just that from factory the features of 6NK are reduced to 6NH by coding.
What do u have inside the front armrest apart from the usb & aux connectors?
      01-01-2013, 06:37 AM   #1606
demge01
demge01's Avatar
Drives: F30 320ed
Attachment 802120
"AG" or "MPM"
