Extreme Power House
      01-02-2013, 02:52 AM   #1695
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by awhk View Post
Thank you Shawn for the info and Kon for the testing!
Now for me to do some coding later today.
      01-02-2013, 02:59 AM   #1696
JonoNZ
New Zealand
Drives: F30 335i M Sport, M Perf
Originally Posted by cronek View Post
anyone else coding on the new HU's (HU_NBT, not CIC)? There are a lot of parameters that suggest support for WLAN/UPnP playback support (audio and video), as well as WLAN channel/ssid/encryption configuration parameters. I'll have to experiment some more with that.
That does sound interesting. My car is in transit to NZ and has NBT.
Are there any issues with coding a car with NBT and 48.1?
F30 335i M-Sport with Estoril Blue II, M Performance Aero Kit, M Performance Exhaust, M Performance PPK, Adaptive Suspension, Variable Sport Steering, Revised NBT Pro Nav, Sunroof, 19" 403M, HUD, Rear Camera, DAB+, Comfort Access (20121250 Build, Delivered 25 January 2013)
      01-02-2013, 03:01 AM   #1697
JonoNZ
New Zealand
Originally Posted by shawnsheridan View Post
PM Sent. I don't have 48.2 PSdZData yet. Soon I hope though.
Hi Shawn, I'd be keen on 48.2 when available.
Thanks for your contributions on here - so very useful and informative!
      01-02-2013, 03:09 AM   #1698
shawnsheridan
It's no different than it is for a car with CIC and 48.1.
The issue isn't the head Unit or any other hardware, rather it always a matter of what ISTA/P version was last used to program the car versus what PSdZData you have for E-Sys. So long as your PSdZData version is equal to or higher than the ISTA/P version on the car, there are no issues.
You can have car with older hardware, but newer software, so a car with CIC and 48.2 on it will have problems using 48.1 PSdZData, whereas a car with NBT and 48.1 on it won't.
      01-02-2013, 03:11 AM   #1699
shawnsheridan
When I have it, I'll open up a new thread listing the CAFD changes, so all will know.
      01-02-2013, 03:16 AM   #1700
JonoNZ
New Zealand
Cool, got it now. Do we know what PSdZData would have been used in a week 201252 car or is a bit or a lottery?
Is the version used on the car visible when I connect using E-Sys?
      01-02-2013, 03:18 AM   #1701
kon
Singapore
Drives: F30 316i
You will know they are incompatible when it can't read completely, missing CAFD files when you try to code, so no harm will be done (yet) since you can't even read, let alone code..
      01-02-2013, 03:18 AM   #1702
kon
Singapore
Drives: F30 316i
subscribing for sure!
      01-02-2013, 03:21 AM   #1703
demge01
demge01's Avatar
Drives: F30 320ed
Originally Posted by clarence View Post
As ur car have 6.5" screen & radio professional, so u physically have a headunit called "L7 Entry" (infotainment platform shared by F20). CIC is only physically installed if u have professional nav.
I think wht's happening here is, as basic BT function is built into the L7 Entry HU, if u have 6NH then there's no combox. If u have nav pro then, as it doesn't have built-in BT, if u have 6NH then it'll come with a combox with some features disabled.
For the combination of L7 Entry + 6NK/NL, the BT hardware is not present in the headunit as a combox is present, hence a different HU p/n is present.
This has never been clear to me, but is 606 Business Nav an option on the F30 in some markets, and if so, is Head Unit considered a CIC?
606 is business nav here in UK and I understand it has no combox.
I don't have 606 nav only 6nh Bluetooth.
      01-02-2013, 03:26 AM   #1704
shawnsheridan
I think based on the fact that 48.2 was released in November, and there is nothing newer that I am aware of, a December built car should have 48.2 on it:
ISTA/P 2.48.0 F010-12-11-501
ISTA/P 2.48.1 F010-12-11-502
ISTA/P 2.48.2 F010-12-11-503
When you get your car, you can read your I-Step (Integration Level), and you will see something like F010-12-11-503, which can be cross referenced to the ISTA/P version.
However, sometimes its not so easy to pinpoint the exact ISTA/P version, because the I-Step can be the same for multiple version of ISTA/P. As an example:
ISTA/P 2.47.5 F010-12-07-533
ISTA/P 2.47.6 F010-12-07-533
ISTA/P 2.47.7 F010-12-07-533
So your car has I-Step F010-12-07-533, but was it programmed with 47.5, 47.6, or 47.7? You can't know for sure without actually seeing the ISTA/P Measures Plan report.
I used F10 I-Steps here, but for all 6 listed, the F30 I-Step matched the F10, albeit beginning with F020 instead of F010.
      01-02-2013, 03:33 AM   #1705
JonoNZ
New Zealand
Cool, thanks. I'm not due to receive my car until early Feb so I will see what it has then, in the meantime I will continue reading and learning on here.
      01-02-2013, 03:38 AM   #1706
shawnsheridan
Yes, and often the local dealer reprograms it, so it may leave the factory with one version and be delivered to you with another version.
You can see that too in E-Sys. It will show your Current, Last, and Factory Original I-Steps.
      01-02-2013, 03:39 AM   #1707
shawnsheridan
From the ETK it looks like it, & it seems if ur pre-07/10 car w/606 have a HU hardware failure the dealer can replace the CIC-MID HU with a CHAMP2 HU.
Actually, wht are the hardware differences between the 2 platforms?
I wish I new brother.
I thought 606 Nav was always CIC-MID and that HU-CHAMP was used primarily in Mini's only, but it seems that is not the case.
      01-02-2013, 05:26 AM   #1708
clarence
Drives: F30 328i M-Sport
Originally Posted by ilhan1103 View Post
I do, but still no idea what motion maps are
It's the name of the mapping software (not the mapping data). "Motion" is for CHAMP & "Move" is for CIC-MID.
      01-02-2013, 05:28 AM   #1709
clarence
It looks like 606 for F25 is also using CHAMP2, maybe they're trying to streamline the platforms available.
      01-02-2013, 05:30 AM   #1710
clarence
I think the CHAMP2 headunit for 606 have basic BT already built-in (like the L7 Entry w/6NH), so for 6NH there's no need for a castrated combox to do the BT work.
      01-02-2013, 05:36 AM   #1711
demge01
demge01's Avatar
Drives: F30 320ed
Would coding of 606 be possible then with my HU?
Is the 606 HU the same as the 6NH HU?
Assuming I could get the update discs and FSC?
Also how do you add option codes?
Sorry for all the Qs.
      01-02-2013, 06:17 AM   #1712
awhk
Drives: 2018 M3 CS LRG
Removed country controller (Hong Kong) from the VO. Office is now working, album art surprisingly activated on my non-nav. However, Chinese characters (songs or messages) no longer showing in the English interface. Went to settings, noticed my other default languages (Trad. and Simp. Chinese) are still there. Changed the menu language to Trad. Chinese and all songs and messages are displayed properly. Question is how can I see Chinese characters again if I use English as language?
      01-02-2013, 07:28 AM   #1713
shawnsheridan
To Modify FA:
File Type: pdf E-Sys - Getting Started Supplement - Part 3.pdf (805.5 KB, 370 views)
      01-02-2013, 08:13 AM   #1714
kon
Singapore
Drives: F30 316i
lucky you! my car has to be left alone for half a day before the bluetooth option for Office & "Show Pictures" decided to show up.
Tried with both iPhone 4S and Blackberry Bold 9900, though i could view email & sms from both phone, these messages only comes from the primary phone (I typically use iPhone as the main phone & BB as additional phone).
Gut feels BB works better with Office, at the email address etc are laid out properly, whereas IOS always show unknown sender, with the sender name follows...
I don't know if it's normal, when we receive new message (text/email), there isn't any notification or gong or whatsoever, the message just sit in the message box, and have to manually trigger it to read.
And it only playback the message, does not support replies
While VO coding, I piggy back it with 6AL (BMW Live) and 6UH (Traffic Info). BMW Live works flawlessly, but the traffic doesn't seem so (when I check the FDL code, the option to make it work in Singapore was still not active - no biggy, just turn em on manually again)
      01-02-2013, 11:27 AM   #1715
clarence
U don't have 606 (bus nav), right? 606 HU is CHAMP2 whereas radio professional HU is L7 ENTRY, so they're physically 2 different headunits.
L7 ENTRY itself doesn't have any nav hardware built-in.
      01-02-2013, 11:31 AM   #1716
clarence
Yes, album art is there cos we have 6NK as std, just that the country controller disabled it.
See this post:
I get album art after remove 8LH.
It will affect display of Asian song names, but the problem can be fixed by change the "Country" under HU_CICHB from "ECU" to "Hong Kong"
If you want Hong Kong Country Controller, add S8LHA to your FA, and VO Code your Head Unit.
