European Auto Source
      01-06-2013, 10:13 AM   #1805
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Originally Posted by john08135i View Post
Does anyone keep the cheat sheet updated!
ilhan1103 does:
https://docs.google.com/spreadsheet/...Ia3ZmbUE#gid=0
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      01-06-2013, 10:22 AM   #1806
kon
Singapore
Drives: F30 316i
does anyone know what's the use of "Show pictures" in the bluetooth menu used for? it shows up right after i turn off country control (to get office)
update: answered my own questions, found this documented in the owners manual, to display contact pictures, just need to figure out how to use this (as if I needs it!) LOL!
      01-06-2013, 10:31 AM   #1807
shawnsheridan
I think these are the pictures that come over from your Phonebook.
      01-06-2013, 11:52 AM   #1808
kon
Singapore
Drives: F30 316i
Has anyone tried VO code this to their F30s yet?
S231A Deleted: 250 km/h limitation
Which ecu/module need to be coded after adding VO?
      01-06-2013, 03:36 PM   #1809
clarence
Drives: F30 328i M-Sport
this one? http://www.steel-mate.com/en/web/a/Products/TPMS/
seems like still need sensor in the wheel, and an additional display... i think the guys just wanted to use OEM display, otherwise, orange is cheap & widely available here...
http://eeboohk.com/index-2.html
U can hide the display by closing the ashtray lid. It's too much work to retrofit oem TMPS, if at all possible.
      01-06-2013, 03:42 PM   #1810
shawnsheridan
Unfortunately, it wont work, nor will adding S840A Increased Speed Limiter, nor will changing VMAX settings directly.
      01-06-2013, 05:46 PM   #1811
Yobyot
Yobyot's Avatar
30
Drives: MY12 F30 ZSL
Anyone tried this in KOMBI?
GPS_UHR
Kommentar=Uhrsynchronisation ueber GPS aktivieren
Google translate:
Comment = Clock synchronization by GPS enabled
Thanks! My 2009 Honda Civic does this and I've often wondered why my F30 didn't.
I coded this today (it was a snap to do). Just for people who try this themselves: in my car, it wiped the date, time and timezone and issued the check control message, "Set date/time."
This along with the "poor man's M performance pack" (KOMBI==>3000==>BMW_LOGO) just made my day.
MY12 335i ZSL with a deep dive into the options list
Produced: 2012-06-22
ED: 2012-07-19; Arrived in Jersey City: 2012-08-23
Redelivered: 2012-09-12
      01-06-2013, 05:48 PM   #1812
shawnsheridan
Attachment 804008
Any time that KOMBI is coded, the Date and Time need to be reset afterwards.
      01-06-2013, 05:54 PM   #1813
Yobyot
Yobyot's Avatar
30
Good to know. It's similar to the response you get when you code FEM_BODY. That generates an error about the adaptive lights. It freaked me out the first time -- even though the cheat sheet notes it.
      01-06-2013, 09:39 PM   #1814
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Send a message via Yahoo to john08135i
Where do i code BT data transfer?
M Sport Line Estoril Blue
      01-06-2013, 10:21 PM   #1815
shawnsheridan
That only shows up when the car is coded for Internet over Bluetooth.
      01-06-2013, 11:03 PM   #1816
kon
Singapore
Drives: F30 316i
Hmmm... I *touch wood*, when I code fem_body, I haven't got this error yet...
      01-06-2013, 11:25 PM   #1817
johnnytyler24
Drives: BMW 3-series
Thanks Shawn for the files, how do you get internet over blu tooth working?
      01-06-2013, 11:49 PM   #1818
shawnsheridan
I only know how to get it working in a U.S. spec'd car if it has a dedicated Combox.
You can read what I did to get Internet / BMW Live working in my F10 here:
Can someone make a tutorial, how to enable internet over bluetooth to work in bmw f10 ?
I have Bmw f10 2012 with:
S612A BMW ASSIST
S614A Internet preparation
S616A BMW ONLINE
S6AAA BMW TELESERVICES
S6VCA COMBOX
Change your VO as follows:
- 612 (or 633 or 639 if present)
+ 644
+ 614 (Required but already present)
+ 615
+ 6AL
+ 6AB
VO CODE HU_CIC
VO CODE CMB_MEDIA
FDL CODE CMB_MEDIA:
- TELEMATIK_VIN = Coding_VIN
FDL CODE CMB_MEDIA:
Use modified VO with VIN that has factory options 614 and 615 as explained in my earlier Post # 45:
http://www.bimmerfest.com/forums/sho...5&postcount=45
*** Use only to FDL Code CMB_MEDIA; DO NOT write this FA to the Car
1) Enable Data Transfer Option Under Phone
2) Enable Bluetooth Data Tethering on Phone
3) Under Connected drive; Update services (should show BMW Live and Internet services)
4) Go to BMW Live and Internet and make sure it it working
After it is working:
Use original VO with car VIN:
FDL CODE CMB_MEDIA:
- TELEMATIK_VIN = MOST_VIN
Read CMB_MEDIA and verify Short VIN in brackets [xxxxxxx] is car VIN.
DO NOT update services again or you will loose BMW Live and Internet.
*** If you do not return the Combox VIN to car VIN, you will encounter problems with future dealer programming, as the Combox will not be recognized, and programming will hault.
      01-07-2013, 12:46 AM   #1819
clarence
Can u use bmwvin.com & pm me ur option codes?
      01-07-2013, 12:47 AM   #1820
clarence
Can u also use bmwvin.com & pm me ur option codes?
      01-07-2013, 03:02 AM   #1821
svache
svache's Avatar
Drives: 2012 F30 328i
It even shows in the headsup display lol, pretty cool
Edit, I also noticed the clock synchronization by GPS, what does this do? Keep track of the correct time and adjust if necessary?
F30 328i Luxury w/ Mojave metallic, beige interior (timeline)
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread
      01-07-2013, 03:13 AM   #1822
svache
svache's Avatar
While this has quite a few new things for me, it also misses quite a few things, isn't it?
I was actually trying to update my own cheat sheet, so I was skimming through the pages (am currently at page 41 lol) and added the stuff listed in it to the cheat sheet I listed on here before.
I'll add what I have so far as attachment, will continue at a later point I guess
      01-07-2013, 03:44 AM   #1823
kon
Singapore
Drives: F30 316i
funny, the logo doesn't show up in my HUD.... and anyone figured out how to change the big BMW logo on the 8.8" yet? That would be really cool... hahahaha
GPS clock, yes, it does sync & correct accordingly, but the time difference should be just a couple of mins, i set it to 10 mins difference earlier hoping it would auto-correct but it won't... but right now, it is sync 99.9% with my iphone which sync with apple time server
      01-07-2013, 03:55 AM   #1824
kon
Singapore
Drives: F30 316i
Clarence/AWHK
Just wanted to continue our discussion with Asian language enabling:
Just saw this in CIC code today:
LANGUAGE_UPDATE
Kommentar=Kern Britta, EI-40
steuert, ob neue Sprachen nachträglich hinzugefügt werden können
nicht_aktiv
Google translate:
controls whether new languages ​​can be added later
not sure if this might work, but even if we do enable this, at best it prep the system to receive font, we still need to find how to import the asian font in?
      01-07-2013, 09:10 AM   #1825
kon
Singapore
Drives: F30 316i
While helping a friend to code his car, I notice in FA editor that there's a section for "Aftermarket_Fitment", it sems the option code listed (per the image) - OMSA & SPBR were listed under HO-Wort and not SALAPA-Element, I tried manually adding it (for the fun of it to my own vehicle FA), and it works (the options were listed after recalculating FA)
Wondering is this something that we could code ourselves? Or do we need ISTA/P for this? I remember retrofitting M-performance brake require ISTA/P coding, just surprised we could see this item listed in E-Sys as well.
The OMSA is meant for ASS last memory coded by the dealer
      01-07-2013, 09:53 AM   #1826
shawnsheridan
You can can add or remove W-Wort (aka E Words) and HO-Wort (aka K Words) using E-Sys the same as you would to add an SALAPA-Element (aka SA Words).
Usually E Words are battery related, and K Words are for official BMW Retrofits.
So what you have there is
W-Wort:
A090 - Batterysize 90AH AGM
EZSF - Deletion of Pull Sensor Function
LEDE - Leather Trim
HO-Wort:
OMSA - Without Engine Start & Stop
SPBR - Sport Brake
