Vorsteiner
      01-08-2013, 03:56 PM   #1893
svache
svache's Avatar
Drives: 2012 F30 328i
Originally Posted by ilhan1103 View Post
We do, and consider them equally ugly, hence the reference
lol I just realize that we have the hatchback in Europe... the sedan, imo, is actually not that bad looking
F30 328i Luxury w/ Mojave metallic, beige interior (timeline)
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread
      01-08-2013, 04:06 PM   #1894
fsfikke
Drives: 535d
Originally Posted by shawnsheridan View Post
Yes, that is correct.
Here are your full lists of E-Words and K-Words for F30 Chassis:
<images>
DO NOT ask where I got this from, as I have no comment on that.
Ok, but... do you also have these for the F10?
      01-08-2013, 04:06 PM   #1895
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by martinf79 View Post
Sorry ... forgive me ignorance. What is "KOMBI"? and how do I get it? lol
KOMBI = Instrument Cluster. You have one, but you do not have an M-Instrument Cluster, which is needed for M-HUD.
      01-08-2013, 04:49 PM   #1896
clarence
Drives: F30 328i M-Sport
KOMBI - Instrument Cluster. You have one, but you do not have ab M Instrument Cluster, which is needed for M-HUD.
Oh yes, cos the HUD takes the signal feed from the cluster.
      01-08-2013, 05:23 PM   #1897
ilhan1103
ilhan1103's Avatar
Drives: f30 318 2012
2012 318D  [0.00]
cheat sheet got a few minor updates again.
When jeroen stops drooling over ugly ducklings and puts everything in his pdf. we will not have 4 confusing files
      01-08-2013, 05:31 PM   #1898
martinf79
martinf79's Avatar
62
Drives: F30 335i M Sport
Ah... I see. Many thanks. Basically... its not possible then.
I can bascally give up hope then?
2013 335i ///M-Sport | + 2015 X3 28i xLine
      01-08-2013, 05:32 PM   #1899
protocolor
Drives: BMW F30 with Nav, no assist
I have an F30 with the combox Media BN2010 model (nav but no assist). Dos...were you able to successfully program to get a regular USB cable working properly for reading track info?
      01-08-2013, 05:44 PM   #1900
dos1973
Drives: F30
Currently i don't have access to my computer... Xls file
I can send it to you early next week.
Have a look to page 69/71...
      01-08-2013, 06:11 PM   #1901
theothernguyen
Drives: '12 Jet Black 328i Sedan
Hey Dos1973, I would like this too please! I am in the same situation as protocolor. I have the same set-up, BN2010 combox media in the trunk, I have taken a look at your previous posts, so thanks for that! Sounds like you have the right fix!
Many thanks!
      01-08-2013, 09:37 PM   #1902
simonchs
Drives: BMW 118i F20
Originally Posted by clarence View Post
For F30 they're the same thing - M-sport brakes/M-performance brakes.
For safety u should code it cos I think it changes the settings for ABS & DSC.
right, the M performance brake kit come with a note and stated "A DSC retrofit encoding must be performed via ISTA/P after installation of the BMW M Performance sports brake system."
      01-08-2013, 09:50 PM   #1903
simonchs
One is a factory fitted option that's exculsive to M-sport package & the other is a retrofit that's available to everyone.
They are coded identically but one's already coded from factory (former case) & the latter at time of retrofit.
i'm confusing on this, the size of front brake caliper/rotor are different between M sport brake and M performance brake.
so add the VO code "2NH" will do the same thing as add the K-words "SPBR"?
      01-09-2013, 12:49 AM   #1904
clarence
No, for F30, M-sport brake & M-performance brake are identical except for the caliper colours & slotted discs (purely cosmetic). Not sure abt F20, u'd better check the ETK to confirm part details.
For F30 2NH should be the same as SPBR, but wht either entry codes exactly I do not know.
      01-09-2013, 01:12 AM   #1905
shawnsheridan
Yes, at least until you do an F30 M3 KOMBI retrofit.
      01-09-2013, 03:21 AM   #1906
simonchs
hmm, right. the front caliper/rotor of F20 M sport brake have different size to M performance brake kit.
      01-09-2013, 03:21 AM   #1907
simonchs
Shawn, would you please share the K-words of F20? wanna make my F20 M performance brake retrofit more perfect
      01-09-2013, 09:47 AM   #1908
eminate
Norway
Drives: BMW 116i M-Sport
I believe the M performance brakes are bigger. I think you need 18inch wheels with those. With the M Sport brakes you only need 17inch. Am I right??
2013 BMW F20 -
B45-337-ZVA-ZVM-2NH-302-3AG-420-430-465-493-522-563-575-609-615-654-674-6NF-6UH-6VA-6WA-8TH
      01-09-2013, 12:39 PM   #1909
shawnsheridan
Originally Posted by kon View Post
I was wondering which ECU we need to "code" if we activate SPBR (of course assuming the brake itself was already retrofitted)
If you don't know for sure, and I don't, your best bet is to VO Code the whole SVT.
You can try and obtain the official "M performance brake kit Retrofit" bulletin, and see if it states in it which modules need coding.
      01-09-2013, 12:42 PM   #1910
clarence
For F20 that's correct.
      01-09-2013, 01:02 PM   #1911
shawnsheridan
...and anyone figured out how to change the big BMW logo on the 8.8" yet? That would be really cool... hahahaha
Well, I am sure the iDrive BMW Logo is an image file stored on the CIC Hard Drive.
So, here is what you need to do. Telnet into the Head Unit, crack the login password, and then use the QNX Developer Software Kit to access the file structure. From there, you can write your own image file of the same size and name to the Hard Drive, replacing the existing one.
Post pictures when your are done.
      01-09-2013, 01:08 PM   #1912
protocolor
what should i do in the instance that the car coding gets messed up and the unit gets 'bricked?' are there restore procedures? or can the unit be replaced? what's the cost?
      01-09-2013, 01:10 PM   #1913
shawnsheridan
Coding does not brick modules. Flashing new Firmware when it goes wrong bricks modules.
If you mess up a module coding it, just VO Code it to reset it.
      01-09-2013, 01:25 PM   #1914
stom_m3
Drives: Sequoia
I will be getting my 335 in a week. Can someone please send me a link via PM or email to the latest psdz and Esys files. Thank you!
email - stom_m3@yahoo.com
