Evolution of Speed
      01-09-2013, 01:35 PM   #1915
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by stom_m3 View Post
I will be getting my 335 in a week. Can someone please send me a link via PM or email to the latest psdz and Esys files. Thank you!
email - stom_m3@yahoo.com
PM sent.
      01-09-2013, 01:36 PM   #1916
protocolor
Drives: BMW F30 with Nav, no assist
Originally Posted by shawnsheridan View Post
Coding does not brick modules. Flashing new Firmware when it goes wrong bricks modules.
If you mess up a module coding it, just VO Code it to reset it.
so there's no real risk if i just want to make a few small behavioral changes (eg bluetooth functionality)?
      01-09-2013, 01:51 PM   #1917
shawnsheridan
Yes, no "real risk" of bricking an ECU in just coding.
      01-09-2013, 01:53 PM   #1918
protocolor
thanks a million shawn. can i get a link to the correct files for my F30? Not sure if it should be the absolute latest or the recommended installer in the first page of this thread. I don't know if my PMs are locked out. You can try there or protocolors@gmail.com. Thanks so much!
      01-09-2013, 02:11 PM   #1919
TonyS
Drives: F30 335i
Originally Posted by demge01 View Post
Sure it can be coded so that you can switch them on or off in the iDrive under settings > lights.
I'm based in the UK and have successfully coded this on mine
I'd be interested begin able to control the DRLs too - care to share what you did to enable it?
      01-09-2013, 02:14 PM   #1920
howiegu
Member
howiegu's Avatar
Drives: 16' 340xi Msport
Corona Ring Intensity
I have noticed that when the Corona Ring as DRL's they are very bright; once the headlight turned on, the Corona Rings dim.
Is there anyway to code the Corona Ring intensity so they won't dim when the headlights are on?
TIA
      01-09-2013, 02:14 PM   #1921
shawnsheridan
DRL_MODUS
0: DRL disabled
1: DRL_H via beam, halogen U.S. (without lights)
2: DRL_L via low beam
3: DRL_S via separate TFLeuchte; U.S. Xenon (rings + bottom)
4: TFL_S via separate TFLeuchte; ECE Xenon (rings + bottom)
5: TFL_ECE (North Country Comfort)
6: DRL_S_ohne_SL via separate TFLeuchte without taillight / tail lights, U.S.
7: TFL_S_ohne_SL via separate TFLeuchte without tail light / rear light, ECE
      01-09-2013, 02:14 PM   #1922
shawnsheridan
TIA
+1
      01-09-2013, 02:16 PM   #1923
shawnsheridan
Email sent.
      01-09-2013, 02:37 PM   #1924
TonyS
Drives: F30 335i
DRL_MODUS
0: DRL disabled
Great stuff. Thanks Shawn.
      01-09-2013, 02:40 PM   #1925
shawnsheridan
Originally Posted by fsfikke View Post
Ok, but... do you also have these for the F10?
Here are your full lists of E-Words and K-Words for F10 Chassis:
Name:  F10 - E Words - 01.png
Size:  23.8 KB Name:  F10 - E Words - 02.png
Name:  F10 - K Words - 01.png
Size:  21.2 KB Name:  F10 - K Words - 02.png
      01-09-2013, 02:40 PM   #1926
shawnsheridan
Originally Posted by simonchs View Post
Shawn, would you please share the K-words of F20? wanna make my F20 M performance brake retrofit more perfect
Here are your full lists of E-Words and K-Words for F20 Chassis:
Name:  F20 - E Words.png
Size:  17.2 KB Name:  F20 - K Words.png
      01-09-2013, 02:58 PM   #1927
1.fresh.f30.335
Drives: 2014 535xdrive M-Sport
I've been an Audi guy until my 335i and the fact that this is so much cheaper than the 350-500 for vagcom is awesome!
'12 335i Sport Apline White w/black... Totaled
'14 535i xdrive M-Sport Carbon Black w/Mocha Nappa
      01-09-2013, 03:00 PM   #1928
1.fresh.f30.335
PM sent.
Could you forward those to me as well?
      01-09-2013, 05:36 PM   #1929
protocolor
A couple things here.
1) Your SALAPA-Element's are your vehicle's unique option codes (e.g. 205 Automatic Transmission, 609 Navigation Professional, 2VL Sport Steering, etc,)
2) You cant add or code anything "on" that requires hardware you physically do not have, whether through FA (VO) Coding or FDL Coding.
3) You can accomplish everything via FDL Coding if you know what you are doing, although it can be more tedious when there are many changes required. But for instances where you don't fully know all the required FDL Codes to enable a feature, or for ease, if you have the required hardware, you can alter your VO Option Codes, and then VO Code a module(s), which will code the entire module, all at once, making all the FDL changes for you to support every Option Code in your VO.
So for example, removing 6NH from your VO and replacing it with 6NK won't automatically get you Enhanced Bluetooth functionality unless you physically also have a Combox.
shawn, so when i look to start coding, since all i want is my bluetooth extended functionality (audio profile, etc) and usb without y cable (as dos verified works), would it be easiest to just follow the supplement part 3 and change my vo from 6nh to 6nL and let it code the module options for me? i have a combox media already.
      01-09-2013, 05:57 PM   #1930
demge01
demge01's Avatar
Drives: F30 320ed
Sure no problem:
CAF [HU_CICHB] > 3000 HMI, 78 > DAYDRIVING_LIGHT > standard
      01-09-2013, 06:10 PM   #1931
TonyS
Drives: F30 335i
Sure no problem:
Thanks! That's just what I was after.
      01-09-2013, 06:42 PM   #1932
clarence
Drives: F30 328i M-Sport
.....would it be easiest to just follow the supplement part 3 and change my vo from 6nh to 6nL and let it code the module options for me? i have a combox media already....
For combox media u should use 6NK instead of 6NL.
      01-09-2013, 06:48 PM   #1933
protocolor
awesome, thank you. ill try to update my fa by removing 6nh and adding 6nk rather than individually coding fdl and let you know how it goes!
      01-09-2013, 06:51 PM   #1934
shawnsheridan
PM sent.
      01-09-2013, 07:10 PM   #1935
hrosenberg33
Drives: BMW 328i Xdrive Sport Line
Hello everyone, first of all I wanted to say thanks to everyone for their input on this thread. It is a loooong but interesting ~80 pages to read.
I would love to start doing some coding but I still find it extremely challenging to figure out exactly what I would be doing once I get my cable. I was wondering if anyone might be able to put together a short video of how they do the coding (from opening the programs --> connecting to the car --> to making a change, saving it, etc). I know that this is a big request but I seem to be a better learner when it's video or audio as opposed to text. This is a selfish request but if anyone has the time/patience to do this I would be be forever grateful.
Thanks for even considering the request!!!
      01-09-2013, 09:41 PM   #1936
kon
Singapore
Drives: F30 316i
Well, I am sure the iDrive BMW Logo is an image file stored on the CIC Hard Drive.
So, here is what you need to do. Telnet into the Head Unit, crack the login password, and then use the QNX Developer Software Kit to access the file structure. From there, you can write your own image file of the same size and name to the Hard Drive, replacing the existing one.
Post pictures when your are done.
Before I can even start to explore this, I think i need to first attend some sort of Computer Programming & Networking class as well as automotive engineering stuff, which might take me well over 10-15 years (given my academic incompetency)..... so please wait for this to happen, I'm sure I'll get to it, eventually
