      01-11-2013, 12:10 PM   #1959
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Originally Posted by kylek13 View Post
My car is set to arrive in a couple weeks, I have a couple questions after reading this.
1)I found a torrent file that got me E-Sys3.18.4 and psdzdata 47.7, is this the latest version that will likely be on my car? Does it matter if the versions don't match up? When new psdzdata files come out should I continue using these or find the new ones?
2) 04) Copy "est" folder from "\\E-sys 3.18.4\est" to "C:\ESysData\e-sys est"
What was supposed to be in the "est" folder? The only things inside my E-sys 3.18.4 folder was E-Sys_EST Pin folder w/ some rar files? Is this a step for an older version?
3)To back up the original settings you need to save the ncd file for each ECU? How many are there in total? Maybe I read that wrong...
Thanks for the help, I tried searching for these answers.....massive thread.
And is there anyone in the Indianapolis area that has done this before possibly?
1) You should if possible always use the latest PSdZData if possible, but so long as your PSdZData version is >= to the ISTA/P version last used to program your car, you will be fine.
2) You need an EST Token File, and the PIN that goes with it. Check inside the .RAR file for a file named "Code Away.est", and put it in C:\ESysData\e-sys est\Code Away.est. The PIN file should show it is 2690.
3) The number of ECU's varies based on your car's options, and some ECU's have multiple CAFD's, and some are not codeable, so they have no CAFD. My F10 has 34 ECU's and a total of 39 CAFD's (.NCD).
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      01-11-2013, 01:29 PM   #1960
949
Drives: ?????
Originally Posted by svache View Post
To be honest, I'm truly amazed of how many parameters can be changed. So many parameters I will probably never even touch since I don't want to mess up the engine and such but, yes, I have seen a LOT of parameters and functions that indicate we should be able to do a lot to our cars.. it really covers everything of the car, the engine, safety issues, electronics.. it's really amazing
by reading this i dont think it has anything to do with the actual engine perameters. there doesnt seem to have any timing or fuel adjustments.
      01-11-2013, 04:19 PM   #1961
mastermayhm
mastermayhm's Avatar
Drives: F06 M6 GC
just to confirm...what are the latest psdz and Esys files?
M6 GC, the mod bug will bite
Mayhm's N54 Build Thread
      01-11-2013, 04:21 PM   #1962
shawnsheridan
E-Sys 3.18.4 (although versions 3.20.0, 3.22.4, and 3.22.5 exist)
PSdZData 48.2 (although some dealers are already running 48.3)
      01-11-2013, 05:28 PM   #1963
howiegu
Member
howiegu's Avatar
Drives: 16' 340xi Msport
Have you done this? If so, what's the outcome?
There was no choice for 100% as I can see.
Cheers
      01-11-2013, 09:37 PM   #1964
mastermayhm
Drives: F06 M6 GC
thanks shawn
      01-11-2013, 11:27 PM   #1965
justa3series
Drives: 2010 328xi
If your looking for later versions of E-sys or personal EST and PIN, please pm me.
      01-11-2013, 11:52 PM   #1966
shawnsheridan
Cheers
Done what?
      01-12-2013, 01:57 PM   #1967
demge01
demge01's Avatar
Drives: F30 320ed
Thinking of coding the inner brake lights to get them to light up under normal braking.
Just wondered what people's thoughts on this are?
Anyone tried it yet?
      01-12-2013, 03:39 PM   #1968
shawnsheridan
48.2 vs. 48.3 PSdZData CAFD Changes
FYI. The difference from 48.2 to 48.3 for the CAFD folder is 33 added and none removed:
Left base folder: C:\Users\SS09546.IT\Desktop\v.48.2_SPdZData
Right base folder: C:\Users\SS09546.IT\Desktop\v.48.3_SPdZData
Left Orphan Files (0)
Right Orphan Files (33)
cafd_000000f9.caf.007_003_024
cafd_000000f9.caf.007_006_006
cafd_00000a3f.caf.005_001_013
cafd_00000a07.caf.002_013_001
cafd_00000b0a.caf.000_025_000
cafd_00000b0a.caf.000_026_000
cafd_00000bce.caf.005_016_002
cafd_00000c77.caf.000_003_000
cafd_00000dbd.caf.001_004_000
cafd_00000ddc.caf.001_014_002
cafd_00000ded.caf.002_002_005
cafd_00000ed9.caf.002_000_005
cafd_00000f9b.caf.001_006_000
cafd_000001a7.caf.000_012_005
cafd_000005b6.caf.004_002_017
cafd_000005b7.caf.004_001_004
cafd_000006c6.caf.002_009_006
cafd_000007a1.caf.005_028_004
cafd_000007c8.caf.006_009_002
cafd_000009c8.caf.005_000_051
cafd_000009ef.caf.000_021_001
cafd_000019cc.caf.100_006_000
cafd_0000023f.caf.016_016_019
cafd_0000067b.caf.002_003_139
cafd_00000098.caf.000_008_091
cafd_0000157f.caf.007_000_002
cafd_00000160.caf.003_004_015
cafd_00000223.caf.013_008_003
cafd_00000760.caf.006_000_052
cafd_00000794.caf.004_228_003
cafd_00000832.caf.002_014_000
cafd_00000912.caf.003_007_005
cafd_00001148.caf.000_011_010
The F20 / F30 Integration Level has changed from F020-12-11-504 to F020-12-11-505.
      01-12-2013, 04:37 PM   #1969
theothernguyen
Drives: '12 Jet Black 328i Sedan
wow good pick. Do you have those files available separately? I presume the program you used checked for changes in the cafd files as well? thanks!
      01-12-2013, 05:15 PM   #1970
shawnsheridan
Based on a failed attempt to add newest 48.3 FEM_BODY CAFD to existing 48.2 PSdZData, it looks like some of the CAFD's need newer binaries (.dll, .jar., etc.), so I think using the full PSdZData is the wise move.
      01-12-2013, 07:36 PM   #1971
kon
Singapore
Drives: F30 316i
Could you share the files?
      01-12-2013, 08:48 PM   #1972
Yobyot
Yobyot's Avatar
37
Drives: MY12 F30 ZSL
But if I'm using 48.2 with no problems, there's no need to update to 48.3, correct?
All I wouldn't be able to do is code whatever is in the 33 new files, some of which might not even apply to my F30, right?
I'm still struggling to understand the relationship between the software level in the car, the level of PSdZData and the CAFD files.
MY12 335i ZSL with a deep dive into the options list
Produced: 2012-06-22
ED: 2012-07-19; Arrived in Jersey City: 2012-08-23
Redelivered: 2012-09-12
      01-12-2013, 09:06 PM   #1973
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
If you can do everything with 48.2, then you don't need 48.3 until the dealer updates your car again, or you start coding other peoples cars.
      01-12-2013, 09:09 PM   #1974
shawnsheridan
Yes, that is all true.
      01-12-2013, 09:13 PM   #1975
shawnsheridan
PM sent.
      01-12-2013, 09:41 PM   #1976
theothernguyen
How would you know what the dealer is using? I actually just took my car in recently for a programming recall and they programmed the fixed code in.
      01-12-2013, 10:02 PM   #1977
shawnsheridan
Well, in this case since the I-Level changed, you can read your I-Step in E-Sys and see if you have:
ISTA/P 2.48.0 F020-12-11-502
ISTA/P 2.48.1 F020-12-11-502
ISTA/P 2.48.2 F020-12-11-504
ISTA/P 2.48.3 F020-12-11-505
If you have F020-12-11-505 I-Level, then you have 48.3.
      01-13-2013, 01:23 AM   #1978
kon
Singapore
Drives: F30 316i
PM sent.
Thanks!
      01-13-2013, 06:50 AM   #1979
williammm
Drives: F30 328i
Originally Posted by avgor123 View Post
Maybe you will try this:
Fem_body>3062
MAPPING_STANDL_V_L_PWM_LEVEL_1
MAPPING_STANDL_V_R_PWM_LEVEL_1
set to 100% instead of 8%
I tried this yesterday.
But there isn't any option for me to choose 100%
      01-13-2013, 08:04 AM   #1980
dcg71
Australia
29
Drives: F30 335i Sport BSM
Set the werte value to 64 (100 in hex). The percentage value can't be edited directlty.
2012 F30 335i Sapphire Black Sport Line | ///M Performance Exhaust | ///M Performance Suspension | ///M Sport Front Bumper | ///M Sport 403M Wheels
2006 E92 325i Titan Silver
2000 E46 318i Cosmos Black
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
