      01-15-2013, 06:50 PM   #2047
KeenDriver
Drives: 2013 335i M-Sport
Yes and Yes. I also tried to copy and replace the SWE folder from PSTDATA to C:\ESysData\SWE
Originally Posted by shawnsheridan View Post
You are connecting to F20 Target PSdZData without the _DIRECT after it, and via VIN?
Did you delete and replace your existing PSdZData folder with the 48.3 one, or did you copy it on top of your old one?
      01-15-2013, 06:52 PM   #2048
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
C:\ESysData\SWE can, and should, be empty.
Do you still have 48.1? If so, can you nuke 48.3, copy 48.1 back, and see if you can connect?
      01-15-2013, 07:01 PM   #2049
KeenDriver
The version I have before 48.3 is 47.5...just and FYI, this was recoded by the dealer last week. Everything read fine with 48.3. It's just coding the FDL where I have the problem.
I'll remove the SWE items, but I'm sure that will just save me HD space
      01-15-2013, 07:04 PM   #2050
shawnsheridan
Are you using the Code Away.est EST Token?
      01-15-2013, 07:08 PM   #2051
KeenDriver
yup. Everything is the same (other than pstdata) as when I last coded in Oct.
I just thought of one or two more things to try that may have caused a problem, but I don't expect it to act any different.
      01-15-2013, 07:28 PM   #2052
shawnsheridan
If it is me, I would completely uninstall E-Sys, and my PSdZData, and reinstall them.
      01-15-2013, 07:40 PM   #2053
KeenDriver
I'll try that after the other two things.
      01-15-2013, 10:45 PM   #2054
KeenDriver
ok so I got it to work by returning to my older PSdZData (47.5) and then moved the specific/missing CAFDs to the correct folder within. Not sure why this worked fine, but it did... hopefully this will help someone else out.
      01-15-2013, 10:51 PM   #2055
shawnsheridan
It is a mystery, but I have heard from several people who all of a sudden are having connection issues, but returning to the older PSdZData solves the problem. I can connect to my F10 fine with 48.3 PSdZdata, and I think most F30 owners can too, but it seems some brand new F30's are having problems with 48.3.
      01-16-2013, 04:28 AM   #2056
kon
Singapore
Drives: F30 316i
Question... is there a quick way to use e-sys to "read coding data" for all ECU at one go (so that the FDL file will be generated and store in the computer locally)?
Right now I'm right clicking each and every CAFD to get the file.
      01-16-2013, 04:30 AM   #2057
shawnsheridan
What happens if you right-click on the top of the SVT where you VIN is? You can VO Code all ECU's from there, but I can't recall if you can read them all too.
      01-16-2013, 05:39 AM   #2058
kon
Singapore
Drives: F30 316i
This is already in my "to-try" list...
In addition, here's what I've compiled on the abbreviations, not complete, but is what I got so far:
ACSM : Advanced Crash Safety Module
AMP_TOPHB : (Amplifier settings)
CMB_MEDIA : Combox Media
DME : Digital Motor Electronics
DSC : Dynamic Stability Control
EGS : (Transmission Control Unit)
EKPM2 : ??
EPS : Electric Power Steering
FEM_BODY : Front Electronic Module
FEM_GW :
FLA3 : (High Beam Assistant)
FZD : (Sunroof control panel)
GWS : (Gear Selector Switch)
HU_CIC : Head Unit - Car Infotainment Computer
ICM : Integrated Chassis Management
"IHKA : Integrated Automatic Heating and Air - Intergriertes Heizung und Klima Automatic"
KOMBI : (Speedo Cluster related)
REM : ??
SM : ??
TRSVC : (Rear View & Other Camera related)
VDC1 : ??
ZBE2 : ??
      01-16-2013, 08:30 AM   #2059
shawnsheridan
EKPM2 : ??
FEM_GW :
REM : ??
SM : ??
VDC1 : ??
ZBE2 : ??
EKPM2 - Electronic fuel pump control
FEM_GW - Gateway Module
REM - Rear Electronics Module
SM - Seat Module
VDC1 - Vertical Dynamics Control (Suspension)
ZBE - Central control unit
      01-16-2013, 10:27 AM   #2060
kon
Singapore
Drives: F30 316i
awkh / clarence - could you share what were the default languages enabled for Hong Kong radio/idrive?
Just wanted to try a theory re displaying Asian language (not sure if anyone tried before).
Reading other forum, apparently the US guys can only display 3 language, only when they change the main language to English_UK, then they could add other languages in.
So, I wanted to try to just stick to the few languages that Hong Kong is enabled for and see if it works... lol
Previously, I've added the Asian language at the bottom of the list, so it practically used up all 16 slots, so I wanted to keep it simpler this time...
      01-16-2013, 11:57 AM   #2061
awhk
Drives: 2018 M3 CS LRG
We have English (UK), Chinese Traditional and Chinese Simplified.
      01-16-2013, 01:27 PM   #2062
mikefrance
Drives: f30
hi
I have problems with bmw live BT DATA
message NBT (data communication not possible . activate bleutooth data communication )
I have an iphone 5 with hotspot activ
help plz
      01-16-2013, 02:44 PM   #2063
steve@codemybimmer
steve@codemybimmer's Avatar
Drives: 2016 M235i xDrive Cabriolet
Thanks to all your help, I managed to make my 6NH behave like a 6NK. After changing the VO, I also had to code COMBOX MEDIA as well so that it would take the white iPhone cable. I can finally use my iPhone 5 on this car without any complications!
Album art all shows up and it's working as if I bought the $800 option.
      01-16-2013, 02:46 PM   #2064
shawnsheridan
Originally Posted by Aritaurus View Post
Thanks to all your help, I successfully got AD2P Bluetooth streaming, iPhone syncronisation without the use of a Y-cable and album art!
      01-16-2013, 04:51 PM   #2065
steve@codemybimmer
Originally Posted by clarence View Post
It was me who asked dos to check for the existence of a combox, cos he had 609+6NH (i.e. no combox function) but he managed to code the 6NH into virtually a 6NK. We all know 6NH cannot do a 6NK w/o addtional hardware, so I asked him to see whether he really has combox with features deactivated.
Bearing in mind that dos is from Germany, the info from members from other countries such as CDN & USA who also have 609+6NH means so far that this spec combination will have a castrated combox.
I think the combox is required for voice control to work so that's why anyone who has the 609+6NH has one. When I took the 320i loaner with 606+6NH, there's no voice control or anything that seems to need a combox.
Now we just need to figure out how to get BMW Live and the internet to work.
      01-16-2013, 05:35 PM   #2066
949
Drives: ?????
if someone makes a usb cable i would buy it. i really dont like having two cables just to do one thing.
      01-16-2013, 05:39 PM   #2067
shawnsheridan
Two cables? What is the need or purpose of the USB one?
      01-16-2013, 05:42 PM   #2068
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
You're missing the point; the F-Series cars can only be programmed over Ethernet. If you plug into the car with a direct USB port, you won't be able to do anything.
You could always get a USB to Ethernet adapter for your computer. That would supply an Ethernet connection on your laptop.
