Vorsteiner
      01-18-2013, 01:39 AM   #2091
kon
Singapore
Drives: F30 316i
Originally Posted by Frogman View Post
I think that's the BMW logo splash screen that shows up when you open the car. The logo shows up in the instrument cluster, the main iDrive screen and the HUD too if you have it.
I assume the combined is the LCD area between the Speedo and Tach, right? Or is the combined the main iDrive screen?
I've coded the logo screen from BMW (with red background lines) to //MPerformance for a couple of people, but that only shows up in the instrument cluster and the HUD.
I wonder if this new setting will display //MPerformance in the main iDrive screen? Everyone that I coded wanted that too!
I did have the BMW Logo on the kombi cluster, and has changed to mperf logo. This particular background image settings is currently inactive, so I doubt it is related to logo.
As for the idrive BMW splash screen, if anything, it should be in HU_CIC as the kombi really only affect what shows up/functionality of the cluster only.
      01-18-2013, 01:41 AM   #2092
kon
Singapore
Drives: F30 316i
Originally Posted by shawnsheridan View Post
The full text from my F10 Cheat Sheet where it originated is:
"Replaces "Surround" on/off checkbox with "L7 Surround" Slider (-5/+5) on Settings=>Tone screen. - Slider still appears to function as off (full left) and on (any setting other than full left)".
Maybe on the F30 the slider is actually functional, but for F10, it was still effectively only an Surround Sound On/Off proposition.
think i did read somewhere that it is also not working for F30... so i didn't do much, but are waiting for more feedbacks if the bang & olufsen menu will do anything... my ear ain't that good, so even if I do that, i probably can't hear any difference
      01-18-2013, 08:55 AM   #2093
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Also from my F10 Cheat Sheet:
"Displays B & O sound menu - Removes "Surround" on/off Checkbox and Adds Bang & Oulfsen Menu to Settings=>Tone Screen with Studio and Expanded Settings - Nonfunctional"
So, if you want B&O, you got to pony up $3700 for the additional hardware.
      01-18-2013, 09:00 AM   #2094
kon
Singapore
Drives: F30 316i
WHERE is your cheat sheet?
      01-18-2013, 09:01 AM   #2095
kon
Singapore
Drives: F30 316i
What happens if you right-click on the top of the SVT where you VIN is? You can VO Code all ECU's from there, but I can't recall if you can read them all too.
Tried this earlier today, and it indeed generate all the CAFDs at one go
Qns: After the CAFDs is generated, can we still just VO code the car (to factory settings)? The reason I wanted to get all the CAFDs is partially to ensure it will read OK, so at least when it write, I don't expect any unexpected error
      01-18-2013, 09:05 AM   #2096
shawnsheridan
Version 3 is here:
F10_CheatSheet_V3.0.pdf
I am close to releasing Version 4, but the changes related to HU_NBT has complicated things.
      01-18-2013, 09:16 AM   #2097
shawnsheridan
Yes, you can VO Code the entire SVT, but since this will also include DME, the engine can't be running.
      01-18-2013, 09:22 AM   #2098
kon
Singapore
Drives: F30 316i
Originally Posted by clarence View Post
BMW Assist uses combox telematics (6NL) w/built-in simcard. BMW Live uses combox media & thru bt data transfer. Both are mutually exclusive.
Before u do anything, do u have bt data transfer available as a selectable option under ur bt settings? If u have then u should add 6AA, 6AB, 6AL & 8SC (shawn pls confirm) plus some codings (if necessary). U may also need to write a EU VIN to ur combox (ask shawn).
Don't change 609 into anything else cos u'll lose ur nav, & don't change 6NK.
I doubt 8SC (National Specific Regulations for Teleservice) is required, at least I don't see it in mine, we have 615 (Extended BMW Online Info) - not sure what this do coz there is no obvious feature that we can find, but it came pre-equipped with all car bound for Singapore.
      01-18-2013, 09:26 AM   #2099
kon
Singapore
Drives: F30 316i
Question again... anybody familiar with option code 861 - Modification Coding Dataset (aka Data record without EOBD)?
Is this something that keep record of what changes/coding were made/save to the vehicle? I randomly punch a few VIN in the vin decoder and notice this is not standard in all vehicles...
      01-18-2013, 09:27 AM   #2100
shawnsheridan
I think 615 is the added News, Weather, and Applications for use with BMW Assist, so it's 6AL without the Google Stuff (Street View, Panoramio, & Local Search).
      01-18-2013, 09:28 AM   #2101
kon
Singapore
Drives: F30 316i
Noted - thanks! Haven't done any code with the engine running yet
      01-18-2013, 09:30 AM   #2102
kon
Singapore
Drives: F30 316i
Then that would be really dumb for our local dealer to add in 615 without giving us 6AL? In anycase, I cannot verify, all I know is 615 is standard, but perhaps you are right.
      01-18-2013, 09:38 AM   #2103
shawnsheridan
Why? For U.S. spec'd cars like mine, I have 615, which goes through BMW Assist. I think only if you have 614 and 615, then you can have 6AL.
      01-18-2013, 09:39 AM   #2104
shawnsheridan
I have no clue on this one. :
      01-18-2013, 09:42 AM   #2105
kon
Singapore
Drives: F30 316i
Dumb for the dealer because they option in 614 & 615 for our car, but doesn't give us 6AL (which we obviously can code in ourselves)... and dumb because they option in feature that we cannot access (if we don't turn on 6AL)... in anycase, back to the original question, so yes I'd probably add in 615 if I want to activate BMW Live.
      01-18-2013, 09:55 AM   #2106
shawnsheridan
Yes, I don't know why if you have factory 614 & 615, you would not also have BMW Live, except that BMW Live is not made available in all countries, so Singapore is probably an excluded country. So when you code 6AL, you must lie and select Germany as your location.
      01-18-2013, 09:58 AM   #2107
kon
Singapore
Drives: F30 316i
We lied when we did the registration, I'm in UK coz UK get to see more apps & feature.
If we select Asia, I only see News & Weather.
UK get all the bell & whistle (News, Weather, Google Local Search, Streetview, Panoramio) plus 4 apps (Wiki Local, Yelp, and 2 other i can't remember at the top of my head)
      01-18-2013, 09:59 AM   #2108
shawnsheridan
Exactly. So in Asia you get only 615. In the U.K., you get 615 and 6AL.
      01-18-2013, 11:06 AM   #2109
dinnef30
Drives: F11 528i
I did quite some coding on my F30. I have pszdata 2.47.5 which is sufficent for me.
Now a friend of mine asked to to code his brand new
BMW 650i xDrive Gran Coupé
Production date should be between 29.Oct.12 and 09.Nov.12
What pszdata do I probably need? He'll be in next week and he cannot test on his own as he has neither the cable not the software.
      01-18-2013, 11:22 AM   #2110
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Send a message via Yahoo to john08135i
OK can we use USB instead of Ethernet cable?
M Sport Line Estoril Blue
      01-18-2013, 11:30 AM   #2111
shawnsheridan
I would used 48.3.
      01-18-2013, 11:31 AM   #2112
shawnsheridan
Supposedly you can use a modified K+DCAN interface, but I never looked into what the actual modification is.
