      01-18-2013, 12:31 PM   #2113
clarence
Drives: F30 328i M-Sport
Originally Posted by kon View Post
I doubt 8SC (National Specific Regulations for Teleservice) is required, at least I don't see it in mine, we have 615 (Extended BMW Online Info) - not sure what this do coz there is no obvious feature that we can find, but it came pre-equipped with all car bound for Singapore.
demge01 got BMW Live working by just doing FDL coding. His car has those 3 VOs I quoted from the factory, he doesn't have 614 or 615 tho.
Maybe we can try adding a "national version" VO fom countries that officially have BMW Live (e.g. UK).
      01-18-2013, 01:53 PM   #2114
protocolor
Drives: BMW F30 with Nav, no assist
You need to pair a 'compatible' phone to see "Messages". If you're using Blackberry, make sure MAP is enable.
If you're using iPhone, try repairing your phone (delete then add again) in the telephone menu. Then wait for a while, make sure you also enable "Show Notifications" in your iPhone bluetooth menu.
yeah i have an iphone 5 (latest ios 6) with show notifications enabled in the bluetooth settings (and all notifications on for messages in notification center), but all i have so far is that single contacts menu. are you saying there is nothing left to do as far as coding the car goes?
      01-18-2013, 05:07 PM   #2115
ramonE90-NL
Netherlands
Drives: bmw F30 320iA
i have just coded the internet HU_CIC 3003 - ONLINE_BROWSER_LIVE. it doesnt work yet, the function is available in the menu but after a while when its trying to connect it displays 'Go to BMW.com/bluetooth' For a BT connection setup i think.
I have the data transfer enabled with the enhanced bluetooth. Is this what should appear? a few posts ago it was said it could take a couple of hours for it to work, is this what you should see?
      01-18-2013, 08:04 PM   #2116
kon
Singapore
Drives: F30 316i
All we know is that by coding HU_CIC will enable the feature... but it also depends on what else is there in your car.
And no, seeing the BT connection setup is not normal, we typically see something like "Unable to connect at this time", after a complete shutdown and a couple of hours later, it will start working.
Do you also have the latest bluetooth firmware? Maybe that is what it's trying to say?
      01-18-2013, 08:06 PM   #2117
kon
Singapore
Drives: F30 316i
You might want to scan through HU_CIC if SMS email display is activated...
For me at least, when i check HU_CIC FDL, all the office features were active, but we cannot access the Office menu as it is restricted in our country by way of 8LS country controller, removing it enable everything for us without additional coding, for US it could be slightly more complicated.
      01-18-2013, 08:24 PM   #2118
ramonE90-NL
Netherlands
Yes i installed the latest BT firmware last week. I will check it again in the morning (its the middle of the night over here in the Netherlands)
      01-18-2013, 09:45 PM   #2119
Casualvic
Drives: 328i xdrive
If this question has been asked feel free to stone me!! For all of us with non xenon headlights, is there coding to be able to run xenon if all parts are purchased? I saw a member say he has all the hardware, when connected, only low beams work and no corona rings or turn signals, help
      01-19-2013, 12:42 AM   #2120
kon
Singapore
Drives: F30 316i
There are specific VO code (522) for Xenon lights, so coding that shouldn't be difficult provided you do have every single part that is needed.
      01-19-2013, 02:07 AM   #2121
kon
Singapore
Drives: F30 316i
Originally Posted by shawnsheridan View Post
Well, in this case since the I-Level changed, you can read your I-Step in E-Sys and see if you have:
ISTA/P 2.48.0 F020-12-11-502
ISTA/P 2.48.1 F020-12-11-502
ISTA/P 2.48.2 F020-12-11-504
ISTA/P 2.48.3 F020-12-11-505
If you have F020-12-11-505 I-Level, then you have 48.3.
Having problem using 48.3 on F020-12-11-504. It could read OK, but when trying to code fdl, it throw some kind of error (sorry didn't save the actual error), but the log file has this:
19 10:56:10,282 [INFO] [vin:VIN-DELETE - ecu:IHKA - da:0x78] com.bmw.psdz.resources.internal.PrioritizedResourc e: released resource BusResource(K_CAN), capacity old=1, new=2, max=2 [SchedulerAsync-0]
13-01-19 10:56:10,282 [INFO] [vin:VIN-DELETE - ecu:IHKA - da:0x78] com.bmw.psdz.resources.internal.PrioritizedResourc e: released resource BusResource(ETHERNET), capacity old=254, new=255, max=255 [SchedulerAsync-0]
13-01-19 10:56:10,282 [INFO] [vin:VIN-DELETE - ecu:IHKA - da:0x78] com.bmw.psdz.resources.internal.PrioritizedResourc e: released resource TaChannelResource(interface = Ethernet, bus = ETHERNET, TACategory = CODING_TA), capacity old=2147483646, new=2147483647, max=2147483647 [SchedulerAsync-0]
13-01-19 10:56:10,282 [WARN] [vin:VIN-DELETE - ecu:IHKA - da:0x78] com.bmw.psdz.tasks.base.scheduler.RunnableTask: task com.bmw.psdz.tasks.base.scheduler.RunnableTask@160 30f9 returned with TaskReturnCode "failed" [SchedulerAsync-0]
13-01-19 10:56:10,282 [WARN] [vin:VIN-DELETE - ecu:IHKA - da:0x78] com.bmw.psdz.api.internal.ExceptionHandler: the following exceptions occured during task execution: [SchedulerAsync-0]
13-01-19 10:56:10,298 [WARN] [vin:VIN-DELETE - ecu:IHKA - da:0x78] com.bmw.psdz.api.internal.ExceptionHandler: ERROR:1. exception = Exception occurred: job failed with negative response error:
code: written data does not match read data
description: no detailed description available; ECU: IHKA_78_ETHERNET
severity: ERROR
Timestamp: Sat Jan 19 10:56:09 SGT 2013
ErrorCategory: VEHICLE_ERROR ID: 433
Class: com.bmw.psdz.vehicle.connection.util.ResultUtil
ExecutionContext={category=TAL, ecuid=(IHKA,0x78), TA_CATEGORY=cdDeploy, PROGRAMMING_STATUS=prepareECUforCoding}
SessionId: default
ErrorCategory: VEHICLE_ERROR ID: 813
Class: com.bmw.psdz.programmer.helper.PSdZCommunicationEx ceptionFactory
ExecutionContext={category=TAL, ecuid=(IHKA,0x78), TA_CATEGORY=cdDeploy, PROGRAMMING_STATUS=prepareECUforCoding, TALLINE_ID=1} [SchedulerAsync-0]
severity: ERROR
No problem coding the same car with 48.2
      01-19-2013, 02:15 AM   #2122
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
severity: ERROR
I had the same issue and the same error message. I could not code a pre- 12-11-505 F30 with 48.3.
I reverted to 48.1 and everything worked fine.
I have not encountered an F30 with 12-11-505 yet, so I don't know if 48.3 will even work or not.
      01-19-2013, 07:03 AM   #2123
ykau
Drives: F30 320I
same encounter..i also reverted back to 48.1.
      01-19-2013, 07:50 AM   #2124
dinnef30
Drives: F11 528i
I would used 48.3.
@Sean: Is there any upgrade possibility from 2.47.5, just the new CAFDs or so?
      01-19-2013, 08:31 AM   #2125
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Send a message via Yahoo to john08135i
severity: ERROR
SessionId: default
severity: ERROR
Ditto. Where I can I dl 48.2
M Sport Line Estoril Blue
      01-19-2013, 08:45 AM   #2126
kon
Singapore
Drives: F30 316i
It's 48.1 plus a few new CAFDs from Shawn ... he hasn't given us any permission to share the file/link...
I'm sure he'll pop up soon
      01-19-2013, 08:51 AM   #2127
john08135i
john08135i's Avatar
I talk to him almost daily... could you just pm me thanks..
I am going on a long trip in a few days and the dealer flashed my car yesterday and i lost all my settings.
      01-19-2013, 09:27 AM   #2128
demge01
demge01's Avatar
Drives: F30 320ed
DVD Query..
My car has S698A AREA-CODE 2 Area-Code 2 for DVD from the factory according to BMW VIN.
But I don't have a DVD player - anyone know what this is for?
      01-19-2013, 09:35 AM   #2129
clarence
It's on every car.
      01-19-2013, 09:40 AM   #2130
demge01
demge01's Avatar
Drives: F30 320ed
Originally Posted by clarence View Post
It's on every car.
Ah ok thanks.
      01-19-2013, 10:38 AM   #2131
john08135i
john08135i's Avatar
I cant code anything now..
i get this error.
HU_CIC [63]
cdDeploy ProcessedWithError
cafd_000000f9-007_003_020 Not Executable
      01-19-2013, 11:27 AM   #2132
john08135i
john08135i's Avatar
FEM_BODY [40]
cafd_00000794-004_124_042 Not Executable
      01-19-2013, 12:00 PM   #2133
Frogman
Frogman's Avatar
Lots of people are having issues coding F20/F30 cars with 48.3.
There is a thread going on another site that is saying that there are some additional checks in 48.3 that prevents coding an F20/F30 without an updated token. This has not been confirmed yet.
So for now, if your car is at integration level below F020-12-11-505, you can continue to code with 48.2.
Has anyone here been able to code an F30 at integration level F020-12-11-505 with 48.3?
      01-19-2013, 12:06 PM   #2134
ramonE90-NL
Netherlands
The BT phone software is installed on my car udp1006. But the coded internet still doesnt work.
The screen im getting when trying to start internet is telling me to check my phone settings or if its compatibel with data transfer. Im using an iphone 4s
