      01-19-2013, 12:48 PM   #2135
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Unhappy 48.3 Problems - New Security - New Updated Patch / Token Needed
Originally Posted by shawnsheridan View Post
It is a mystery, but I have heard from several people who all of a sudden are having connection issues, but returning to the older PSdZData solves the problem. I can connect to my F10 fine with 48.3 PSdZdata, and I think most F30 owners can too, but it seems some brand new F30's are having problems with 48.3.
Well, bad news folks.
I am told that new security was added to the 48.3 F20 PSdZData related to E-Sys and the Token validity, which is causing both the inability to save FDL Changes and in some cases the inability to even connect to F20 / F30 cars.
So, a new updated Patch / Token is needed to use the new 48.3 PSdZData. That said, I do not think we will see again a "Free" token like the Code Away.EST was made, so get used to the idea of having to pay something (annually) going forward for an E-Sys Patch / Token.
If anyone is interested in buying a new updated Patch / Token, PM me. I have a source, and the cost for one version of E-Sys (e.g. E-Sys 3.22.5) with Patch / EST Token Valid for 1 Year from issue date is 50 Euro / $65 USD.
Oddly, F10 does not seem affected yet, but I assume it is coming.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      01-19-2013, 02:18 PM   #2136
steve@codemybimmer
steve@codemybimmer's Avatar
Drives: 2016 M235i xDrive Cabriolet
If anyone is interested in buying a a new updated Patch / Token, PM me. I have a source, and the cost for one version of E-Sys (e.g. E-Sys 3.22.5) with Patch / EST Token Valid for 1 Year from issue date is 50 Euro / $65 USD.
How often do dealers update the software on the car when you take it in for service? When I took mine in for the FEM update back in December, I was still able to code my car with 48.1. Looks like if they update mine t o 48.3, I'll have to go that route.
      01-19-2013, 02:42 PM   #2137
mikefrance
Drives: f30
hi friends
it's possible to added 6NR in HU_NBT ?
      01-19-2013, 03:43 PM   #2138
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Send a message via Yahoo to john08135i
Can we use an older version of PZdata then for free still?
I am stuck..and i MUST have my features back.
M Sport Line Estoril Blue
      01-19-2013, 04:35 PM   #2139
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
Yes, you can used the older version of psdzdata until your car is updated to integration level F020-12-11-505.
Once you are there, you won't be able to read any of the updated modules with the older dataset.
Can you confirm that you are at 12-11-505, or are you at a lower level and just trying to use 48.3?
      01-19-2013, 04:41 PM   #2140
john08135i
john08135i's Avatar
How can i determine my level my car is at now?
      01-19-2013, 04:42 PM   #2141
shawnsheridan
Originally Posted by mikefrance View Post
hi friends
Yes, but same as CIC, you need a 9C FSC Code, and if you also want Video / iPod Out GUI, you need to have FBAS Video Line from either 6NF Base Plate or a modified 6FL USB Port.
      01-19-2013, 04:43 PM   #2142
shawnsheridan
See my earlier Post #1403 here:
http://www.f30post.com/forums/showpo...postcount=1403
      01-19-2013, 04:46 PM   #2143
shawnsheridan
It isn't common, in fact, Dealers try and avoid programming a car. If there is a SIB (Service Bulletin) that requires new software, they will program it, and if you are having problems with the car, and ISTA troubleshooting directs them to program the car, then they will. Other than that, you won't get new software.
      01-19-2013, 04:59 PM   #2144
john08135i
john08135i's Avatar
I am
istep current f020-12-11-504
last f020-12-07-533
shipment f020-12-07-530
      01-19-2013, 05:08 PM   #2145
shawnsheridan
I am
last f020-12-07-533
F020-12-11-504 = 2.48.2.
Whatever update they did yesterday, it was not full programming or you would have F020-12-11-505.
That said, 48.2 may also have the new security in it. All I have heard is switching back to 48.1 if you can solves the issue, but no one I know has switched back to 48.2, probably because 48.3 was released so soon after 48.2, most people skipped 48.2 when they updated.
So, 48.2 may have the same issues as 48.3.
      01-19-2013, 05:10 PM   #2146
mikefrance
Drives: f30
coding FA 6nr and buy FSC code ???
      01-19-2013, 05:13 PM   #2147
shawnsheridan
Yes. In my F10, I bought 9C FSC Code, had it imported and activated in CIC, added 6NR, and 6NF since it is required for 6NR, to my VO, wrote VO to car, and coded HU_CUC and CMB_MEDIA, or on this case only HU_NBT.
      01-19-2013, 05:25 PM   #2148
john08135i
john08135i's Avatar
Ok i tried all differnet ways to make my new coding work again..
I bought the new ESYS token and it works!! i am happy.. i was willing to pay for being able to code in the first place..so i am fine with the $65..
Thank you shawn and ANDY
      01-19-2013, 05:28 PM   #2149
shawnsheridan
Thanks for confirming it fixed your FDL Save issue.
Hopefully soon someone with the connection problem will also score the update Patch / Token and confirm it solves that problem too.
      01-19-2013, 05:37 PM   #2150
mikefrance
Drives: f30
ok thank you shawn
      01-19-2013, 05:40 PM   #2151
john08135i
john08135i's Avatar
So where is the NEWEST cheat sheet.. since it cost me money i am going to code everything possible.
      01-19-2013, 08:13 PM   #2152
RASHID007
Drives: 2014 535d X-Drive
Well that explains a lot.
Dammit I just spent the entire morning re-reading everything and programming my car with 48.3 to be baffled as to why there was no errors and I know how to do it as I'm experienced with it and yet still no coding would stick. I see your post about the recent changes.
I will have to check my integration level and if it's low enough can you please point me to 48.1 data files by PM?
If it's not, how do I buy E-Sys 3.22.5 and a 1 year token from your source? How quickly can I get the link and the token as tonight may be the only free night I have for a while to do this coding. Again, PM please and thank you.
Thank you again.
      01-19-2013, 08:16 PM   #2153
shawnsheridan
Thank you again.
PM sent.
      01-19-2013, 08:17 PM   #2154
RASHID007
I used the PDF and Google Docs from this post as they appear to be the most updated.
http://www.f30post.com/forums/showpo...postcount=1822
      01-19-2013, 08:19 PM   #2155
RASHID007
PM sent.
Excellent, thank you again!
So as long as I don't have integration level F020-12-11-505 then I am good to use 48.2 or 48.1 and the existing E-Sys 3.18.4 and existing token?
      01-19-2013, 08:22 PM   #2156
shawnsheridan
Not necessarily. As I wrote above, 48.2 may also have the increased Token Security. It was barely around long enough before 48.3 came out, so there just isn't many users nor feedback on it.
